SoundProofing Next Theater - Green Glue & Quiet Rock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-25-2014, 12:50 PM - Thread Starter
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 94
I'm pre-planning my next theater and I'm trying to determine the STC level of using a double wall, with 5/8" QuietRock, Green Glued to 5/8" DryWall on both sides, with a 6" air gap between the walls.
I've seen lots of "Green Glue vs QuietRock" threads, but not one combining both.
Also, is standard bat insulation the way to go, or high density fiberglass a better choice to stop bass from radiating out?
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #2 of 17 Old 04-25-2014, 12:56 PM
Quoted: 3255 Post(s)
Liked: 2743
Thats because it doesn't make sense from an economic or a stop the bass perspective. You are giving up mass at 4x the cost. If you can apply Green Glue in the field there is no reason to have a factory do it for you and ship it cross country.
Mfusick likes this.
post #3 of 17 Old 04-25-2014, 01:04 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 94
Sorry, I don't follow. I'm talking about combining the two.
For example: A wall would be 5/8" drywall - Green Glue - Quiet Rock
Plus, from what I understand, Quiet Rock 545, has a layer of cement board sealed to gypsum, adding even more mass.
post #4 of 17 Old 04-25-2014, 01:19 PM
Liked: 2743
post #5 of 17 Old 04-25-2014, 01:30 PM - Thread Starter
Quoted: 202 Post(s)
Liked: 94
According to the Green glue website, the "Best" is 3 tubes per 4'x8' sheet of drywall.
A case on Amazon is $192, so it will cost $48 per sheet of drywall.
post #6 of 17 Old 04-25-2014, 05:29 PM
jjslegacy's Avatar
Get a price on quietrock and you may change your mind
JJ
jjslegacy is offline
post #7 of 17 Old 04-25-2014, 07:42 PM
Liked: 2743
You buy 5 gallon pails from SoundproofingCompany.com apply it at the recommend 2 loads per sheet and it will run you about $20 a sheet for the green glue.
post #8 of 17 Old 04-25-2014, 10:02 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
I bought 3 buckets and applied with a small notched trow. Much cheaper than buying the expensive glue gun they sell.
Cksqurd is online now
post #9 of 17 Old 04-26-2014, 01:47 AM
jjslegacy's Avatar
Also I believe they say exactly to not do that. The glue-gun is not very expensive when buying GG. I think I would rather do the recommended and tested approach when spending the money on the product.
JJ
post #10 of 17 Old 04-26-2014, 05:25 AM
Liked: 2743
I think the gun is $29 when you buy the buckets.
post #11 of 17 Old 04-28-2014, 04:37 AM - Thread Starter
Quoted: 202 Post(s)
Liked: 94
If more mass is better, can someone explain the examples in #6 where having two LESS layers of drywall improves STC substantially?
http://www.stcratings.com/assemblies.html
post #12 of 17 Old 04-28-2014, 11:29 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
Decoupling! With double walls you actually have 8” total between the two rooms walls. The walls are totally decoupled from each other and 1” space between them. On my billiard room side I just did 2 layers of 5/8” drywall on my theater side I attached the wall to the joist with IB-3 clips (decoupled) and have 19/32”OSB/GG/5/8”DW. So like the last example.
SimpleTheater likes this.
cw5billwade is offline
post #13 of 17 Old 04-29-2014, 06:34 AM
Quoted: 328 Post(s)
Liked: 184
Just never do the first example in #6 that is tripple leaf
post #14 of 17 Old 04-29-2014, 07:20 AM - Thread Starter
Quoted: 202 Post(s)
Liked: 94
This stuff isn't terribly priced @ $67/sheet for 4 x 10.
http://www.lowes.com/ProductDisplay?partNumber=89013-272-GB10011000&catalogId=10051&storeId=10151&langId=-1&productId=3045179
If these values are trustworthy, then the value is quite good.
http://www.nationalgypsum.com/products/..%5CFile%5C09%2029%2000-173.pdf
post #15 of 17 Old 04-29-2014, 07:37 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
STC may be quite good - I'll take your word for it. The catch is that STC doesn't capture the difference.
STC and virtually every other tested parameter of sound transmission does not measure low bass. The facilities that would be required to measure performance at that low a frequency simply are not available. (I don't think I've seen results below 125Hz)
The only way to meaningfully improve transmission losses for low bass is to push down the natural resonant frequency of the wall. Mass is the way to do that.
HopefulFred is offline
post #16 of 17 Old 04-29-2014, 08:09 AM
jjslegacy's Avatar
That would quite get expensive fast compared to a couple of type-x 5/8 for a fraction of the cost and some pales of GG. I think i have almost 80 12ft sheets of drywall in my theater and at your plan that would be near 5000 in materials. I can tell you I didn't pay anywhere near that for my type-x and GG and likely have a better system.
If there were better products, better ways to do it , cheaper options- people would be doing it.
You also have to factor in what the pure mass is worth as STC isn't telling you how it will do at all with LFE.
JJ
post #17 of 17 Old 04-30-2014, 07:41 AM
Quoted: 328 Post(s)
Liked: 184
What he said this is $12.25 per sheet so two layers would be 24.50 and then the GG now you have 1 2/8" mass. Much better. Why is mold protection needed?
