Need help with loose cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-12-2014, 08:27 AM - Thread Starter
filetandrelease's Avatar
Hey guys-
I havent posted in awhile, but I need some advice- I'm guessing this has happened to others and there's a quick fix. I bought my HDMI cables from mono price- and they are huge in diameter- where they come out of the wall in my equipment room, it has to turn about 8 -10 inches to the left- then plugs in back or receiver.
The problem is, its such a thick cable that it tends to pull itself towards the bend and/or straighten itself out - and if its not aligned 100% I get no picture to my projector. Do they make any kind of clamps that would hole it on tight?
CM
filetandrelease is offline
post #2 of 3 Old 05-12-2014, 08:51 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
walterappleby is offline
post #3 of 3 Old 05-12-2014, 09:56 AM - Thread Starter
Great, thanks!
