Help with an open starwell - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-13-2014, 10:04 AM - Thread Starter
Canadian Noobie's Avatar
First off, I'm a first time poster but the information on this forum has helped me greatly so far. Great Community!
So I'm 50% complete the renovation in my basement for my man living room and theater area. I have a pretty good understanding of what I need to do to soundproof the walls and ceiling. My problem is an open stairwell into the basement. The open stairwell is great for the basement is great for looks and feel (makes it feel like a main level room. The cost and impact of making this closed off would require to much money and structural changes, so closing it off permanently is off the table.
Is there any options for treating the walls or stairs to help minimize the sound transfer. A paint to minimize sound bouncing up the opening or something like a bass trap? I have thought of a curtain system to pull across the stairwell opening when the theater is in use.
Canadian Noobie is offline
post #2 of 6 Old 05-13-2014, 01:33 PM
Quoted: 3267 Post(s)
Liked: 2751
How about a sliding door (partition) at the bottom of the stairs? Do you have a picture of the stairwell?
http://www.finehomebuilding.com/how-to/articles/install-a-sliding-barn-door.aspx
post #3 of 6 Old 05-13-2014, 10:41 PM
MrEscu's Avatar
Quoted: 32 Post(s)
I'm pretty sure that most residential codes require a landing at the bottom of the stair (minimum 3', I think), so you can't install a door directly at the bottom. Of course, requirements vary from jurisdiction to jurisdiction.
MrEscu is offline
post #4 of 6 Old 05-14-2014, 05:51 AM
Liked: 2751
that is why we need a picture
post #5 of 6 Old 05-14-2014, 04:29 PM - Thread Starter
I have access in behind the all the walls of the stairwell. Everything around in the basement will be moderately soundproofed (insulation and double drywall), but I really don't know what to do with that opening.....I know I can't eliminate sound transfer, but would like the minimize it.
Anythoughts?
PS don't mind the mess, I'm currently working on other rooms in the basement.
post #6 of 6 Old 05-14-2014, 05:14 PM
Liked: 2751
for under $500 you could create a vestibule with a door
