Staging... - AVS Forum
post #1 of 15 Old 05-22-2014, 04:59 PM - Thread Starter
Eric Sands's Avatar
Would the projection screen wall typically sit on top of a 6 inch high stage? Or would the stage go up to the screen wall (without touching it)?
Eric Sands is offline
post #2 of 15 Old 05-22-2014, 05:42 PM
Quoted: 268 Post(s)
Liked: 611
usually on top of the stage
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
PROJECTS:
BIGmouthinDC is online now
post #3 of 15 Old 05-22-2014, 09:42 PM - Thread Starter
Eric Sands's Avatar
OK thanks.
Would that be true as well if the speakers were on the stage, in front of the projection screen wall?
post #4 of 15 Old 05-22-2014, 10:15 PM
Quoted: 268 Post(s)
Liked: 611
then what happens behind the screen wall stays behind the screen wall. Do what you want.
PROJECTS:
post #5 of 15 Old 05-23-2014, 11:38 AM - Thread Starter
Eric Sands's Avatar
One more question...
I know risers should be isolated and not touching the rear wall. Is the same true for a sand filled stage? Should there be any space between the stage framing and the drywall behind?
post #6 of 15 Old 05-23-2014, 11:50 AM
Quoted: 268 Post(s)
Liked: 611
You have that backwards it is the stage where you should leave a space. The riser only needs it if you will be installing sub-woofers or other devices that will cause the riser to vibrate.
PROJECTS:
post #7 of 15 Old 05-25-2014, 03:45 PM - Thread Starter
Eric Sands's Avatar
Thank you!
One more quick question... I'm planning on a 2x12 perimeter, with 2x8 stringers, 12" on center. For decking, is one layer of 3/4 OSB sufficient? Some people seem to be doing two layers. I'd like a 1.5 inch thick bullnose lip to wrap carpeting around, but I can do this by screwing/gluing a 2nd OSB strip under only the lip. Is the 2nd layer of OSB over entire riser really necessary for stability?
post #8 of 15 Old 05-25-2014, 04:45 PM
Quoted: 268 Post(s)
Liked: 611
Multiple layer tops are not about being strong enough to hold the furniture, it is about trying to keep it quiet. My stages have been either 2 layers of 3/4 or 3 layers of 5/8. Green Glue between layers is the deluxe approach, roofing felt was used before GG was on the market and is a fall back.
PROJECTS:
post #9 of 15 Old 05-26-2014, 09:44 AM - Thread Starter
Eric Sands's Avatar
Thank you!
post #10 of 15 Old 09-03-2014, 02:22 PM - Thread Starter
Eric Sands's Avatar
One more question regarding this...
I've already placed insulation loosely inside the riser. But I know there should be some openings/registers to allow the riser to breathe. Any suggestions on size and position of these registers? My riser will be supporting 5 recliners, and is about 80 inches deep.
post #11 of 15 Old 09-04-2014, 06:36 AM
oman321's Avatar
Quoted: 21 Post(s)
Liked: 37
Usually you only open up the riser with registers for the purpose of using the riser as a bass trap. The openings have to be strategic for that purpose, otherwise just leave it sealed.
oman321 is offline
post #12 of 15 Old 09-04-2014, 02:55 PM - Thread Starter
Eric Sands's Avatar
I actually had built it as a bass trap... isolated from all walls, and open bays inside that are not touching the floor. I realize it's not an exact science, but maybe some registers on the sides? Or in the back?
post #13 of 15 Old 09-05-2014, 05:57 AM
oman321's Avatar
Quoted: 21 Post(s)
Liked: 37
Riser as Broad Band Bass Trap
Some old and newer info in this thread. Worth a read, then decide if you want to chance it.
Further info available here as well.
http://forums.musicplayer.com/ubbthr...ad#Post2032618
oman321 is offline
post #14 of 15 Old 09-05-2014, 07:12 AM
mikeyd17's Avatar
How big of a space? 1/8"...1/4" ?
mikeyd17 is offline
post #15 of 15 Old 09-06-2014, 04:09 PM
Quoted: 268 Post(s)
Liked: 611
I start with 1/2 in case it moves a bit. I actually slide scrap pieces of wood down from the top and then pull them out, put a screw in the top so they can't slip into the gap forever.
PROJECTS:
User Tag List
