Zilko HT Build - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By readthis13
post #1 of 3 Old 06-17-2014, 02:39 PM - Thread Starter
readthis13's Avatar
Zilko HT Build
I've been putting my HT together since we bought the house in March.
The layout was mocked up (by me for me) here. It's rough, but you get the idea.
To view larger images, use this link
The setup is as follows,
  • 680 series B&W speakers 8.1
  • Panasonic PT-AE8000U
  • 158" 2.35:1 1.0 Gain Screen (acoustically transparent)
  • Denon 3808CI
  • Mac MINI HTPC w/ Plex
  • Roomie w/ wifi IR repeater (to controll all AV & lights from the next room over)
The room started out as follows,
Untitled by azilko, on Flickr
Then the framing,
(The AV I IR light switches will go on the other side of the wall on the left where the water tanks are)
Electrical Started,
(Surround) Speaker boxes being created,
Ran a conduit to the front (behind the screen),
Sound Insulation Installed,
Ran power into the center of the room for the theater chairs,
readthis13 is online now
post #2 of 3 Old 06-17-2014, 02:39 PM - Thread Starter
readthis13's Avatar
More of the room,
This is the room all the AV equip will go, and be controlled through the wifi app on my iOS devices,
Outside of the theater room, there'll be two sconces going into it,
Sheetrock going up,
Area going into the theater,
Sheetrock Up,
AV Area,
Mud & Tapped,
Painting Started - base coat of black,
And, the doors are going up today so they can be pulled and painted.
More to come...
post #3 of 3 Old 06-19-2014, 10:09 AM - Thread Starter
readthis13's Avatar
The paint scheme (not sure I like it though, may need to redo as the red is way brighter than it was supposed to be),
ellisr63 likes this.
