CrimsonBlue dedicated home theater build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 06-21-2014, 03:06 PM - Thread Starter
crimsonblue's Avatar
Quoted: 72 Post(s)
Liked: 44
Grey Home Theater
Hi all, I recently moved into my dream home and it didn't take more than a month for me to convince the wife to let me take over one of the basement halves. The room is narrow (11.5 feet wide) but it's fairly long (26 feet).
The previous owners used it as a rec room, and it has a sliding glass door to the outside, a small utility closet, a cedar closet for storing clothes etc., and floor-ceiling mirrors (three 5'x8' solid panels) on one wall. On the opposite wall there are weird stickers that look like iPod dancers. I asked her if I could do anything I wanted to the room, and she said yes so I'm off to the races on turning this into the best theater that my imagination and the space constraints will allow!
Here is the room as it was when we moved in. I'm planning some major changes! I don't have the ability to take off much time from work, so I've hired a contractor to come and do some electrical work in the walls. I know the least about that, and it will save me a lot of time.
The equipment that I already have:
Epson 8350 projector
Denon 4311 receiver
Denon 2500BTCI blu-ray
PS4, Apple TV, etc.
Infinity speakers:
Beta 50 floor speakers
Beta C250 center
Beta ES250 bi/dipole (4 total)
Beta SW12 12" subwoofer
Crappy JBL height channel speakers
Less crappy JBL 8" ceiling speakers (I will matrix these with the height-channels)
ID:	129754   Click image for larger version
ID:	129762   Click image for larger version
ID:	129770   Click image for larger version
ID:	129778   Click image for larger version
crimsonblue is offline
post #2 of 27 Old 06-21-2014, 08:24 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Demolition begins!
The first step was ripping out the small closet near the sliding doors. A crow bar and a reciprocating saw helped, but I still managed to draw blood within the first few hours by yanking a metal stud off the wall that had some sharp nails stuck to it. The closet suffered more damage than I did, so day 1 is a success.
Looking more carefully at these mirrors, tomorrow is going to be a huge pain in the butt trying to get those off. They are on tracks with no room at the top or bottom to give, and they can't be slid horizontally. I think I may have to dig the tracks apart to try to get the mirrors off the wall.
_______________________
Home theater build 1.0 | Black & Grey Theater (Mark II)
3x 1099 speakers + 2x UM18 = sonic bliss.
post #3 of 27 Old 06-22-2014, 02:18 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
I grossly underestimated the weight of these glass panels. Each one has to weigh at least 200 pounds and they are jammed tight into the tracks and then stuck to the wall via some serious glue. I think they were suction-cupped lifted onto the wall then the tracks were put it to keep them from every being moved. We ended up breaking one (always wear protective eyewear...) and the others were salvageable. The local glass and mirror shops didn't want to take it from me - even for free! I was surprised at that, but they are up on Craigslist now to be given to whomever can haul them away. Even in the first hour, the responses have been plentiful, especially from the woman asking if three of them would fit in her Honda Civic. I don't think that entire car is 5'x8' but you have to appreciate her willingness to try!
I'm trying to get the remaining glue off of the walls without damaging too much. You can see from one of the photos that I've already started taping off where my screen will be. I'm going with a 135" screen, which won't leave much room on the sides, but since I have so much depth in the room, I thought I'd get the biggest screen I could comfortably fit.
ID:	131250   Click image for larger version
ID:	131258   Click image for larger version
ID:	131266   Click image for larger version
post #4 of 27 Old 06-22-2014, 03:00 PM
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
I love demo.....
I'm guessing since you're being so careful with the walls you're not tearing out the drywall?
jefftr is offline
post #5 of 27 Old 06-22-2014, 03:06 PM
Quoted: 2496 Post(s)
Liked: 2123
You are lucky, I am surprised how little glue they used on the drywall. If it ends up being a mess removing the glue you could throw up a layer of 1/4 inch drywall and just finish that normally.
post #6 of 27 Old 06-22-2014, 03:13 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Since I'm a newbie to home ownership, and don't have a ton of experience with building projects, I'd like to keep things as simple as possible for now! Ripping out the drywall is something I've considered every single day, but I'd rather not do it if I don't have to.
I need to get into the walls/ceiling for a few reasons so far:
1. Running 800 feet of speaker wire!
2. Two new sconces on each side wall
3. New ceiling lights (the fluorescents have to go!)
4. Projector cabling in the ceiling
5. Ceiling speakers that I plan to matrix with the front Heights
Now, that seems like the perfect reason to yank out the drywall! Well, I'm still shy about that, and I plan to solve that problem by solving a different problem at the same time. There is an HVAC soffit on the upper left side (as you face the sliding door) and it is a huge eyesore to me. I can't get rid of it, so I'm going to enhance it! The plan is to build a boxed frame all the way around so that the soffit disappears and I have a boxed pipeline all the way around the room to run cabling. Because some of the work involves electrical (which I am not comfortable with at this point) I have enlisted the help of a local contractor to help build that box and do the electrical (while teaching me a few tricks of the trade so I can do it myself going forward).
The contractor thinks my design is completely nuts, and he doesn't really understand what I'm trying to do. Because we'll be building it together, he'll understand soon enough!
post #7 of 27 Old 06-22-2014, 07:25 PM
Liked: 2123
a little on building soffits with minimal effort:
Has anyone ever decoupled soffits?
post #8 of 27 Old 06-23-2014, 10:30 AM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
a little on building soffits with minimal effort: Has anyone ever decoupled soffits?
Big, I'm both disheartened and relieved with your post. I thought I had developed a novel idea to solving the random soffit problem, but it appears that plenty of other folks before me came up with the same plan (hence, the relief). I didn't do as much homework on AVS as I should have before starting this project, as I just wanted to implement what I thought was a great solution for the narrow width space. Now I'm pouring through old forums trying to soak in as much knowledge as possible. I think the design for the initial room redesign is set, but I will have many more iterations that will need help.
We're half way through building an empty box around the room to run wires and make the existing soffit invisible. I'll post more later, but it looks like I'm on the right track.
No matter how much planning and design I do, I have a feeling that my first real theater will go through many iterations as I learn enough to be truly dangerous/adventurous with dry wall!
post #9 of 27 Old 06-23-2014, 07:02 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Things got real messy today. My brilliant idea (which turned out to be common sense on these threads) was to build a box all the way around to make the soffit disappear and give a channel to run my speaker wires.
I also took down the two fluorescent lights and put in 4 Cree 65W (2700k temp). I don't plan on using these much, but they were a much better replacement for the eye sore fluorescents.
Getting rid of the glass was harder than I thought, but someone is picking them up soon. There is a dance studio in the DC area that serves kids in a pretty rough school district so they will get three new 8'x5' mirrors for free! It's so wonderful to be able to give away things and make someone's day.
I'm pulling the remainder of the wire tomorrow (900 feet on hand) so that will be a big task. Everything is run from the cedar closet room, which I just got wife clearance to add my rack poking through the wall, instead of just in the closet itself.
The plan is to have two rows of 3 seats, and I went with some of the slimmer models from TheaterSeatStore.com. Real leather, full motorized recline -- I'm not planning on buying any more for a decade! The riser is tough because there isn't a ton of space in the room width-wise. I can only walk on the left side, so the chairs will be ever so off center, but it shouldn't make much difference.
ID:	133025   Click image for larger version
ID:	133033   Click image for larger version
ID:	133041   Click image for larger version
post #10 of 27 Old 06-23-2014, 07:49 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Drawing of the room, for reference:
post #11 of 27 Old 06-26-2014, 04:52 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
More progress. Wiring is essentially finished and I have currently made allowances for the following speakers:
Front Height
Front Main
Center
Front Ceiling (midway between screen and listening position)
Surrounds (2 left and 2 right, matrixed together via Behringer Ultralink MX882 I could split the outputs normally, but I want to be able to control the 2nd bay of surrounds independently.
No Rears at this point, but the surrounds are dipole/bipole and I ran quad wire to all of them so I can switch to having rears if needed.
ID:	137353   Click image for larger version
ID:	137361   Click image for larger version
post #12 of 27 Old 06-26-2014, 05:58 PM
dhendriksen's Avatar
Quoted: 18 Post(s)
Liked: 30
When are you removing the door?
dhendriksen is offline
post #13 of 27 Old 06-26-2014, 07:06 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
That's next. It's just going to be ripping out the sliding door, putting in studs/insulation, and then drywalling the inside. Outside may be a little trickier in making it not look like it was just ripped apart.
post #14 of 27 Old 06-30-2014, 08:14 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
The tray ceiling is complete, and the outside door has now been completely removed and made into a wall with insulation etc. Making the outside look semi-natural was a challenge, and originally the contractor thought I would want vinyl siding (the rest of the house is brick with some siding, but vinyl siding would look out of place here). I decided to do a wooden square frame with three panels (pics later this week of the outside)
ID:	143242   Click image for larger version
post #15 of 27 Old 07-01-2014, 09:07 AM
69glamboy's Avatar
Quoted: 106 Post(s)
Liked: 34
Your room is coming along nicely. I haven't yet begun to build , but my room dimensions are almost exact. Can't wait to watch your progress. Keep up the good work!
Conrad from Canada.
69glamboy is offline
post #16 of 27 Old 07-02-2014, 07:49 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Let there be paint! I went with a grey, which I like a lot so far. I need color on the walls (posters, etc.) to balance it, but it feels good right now. Sconces from Home Depot, and a rope light around the try ceiling.
ID:	146113   Click image for larger version
ID:	146121   Click image for larger version
ID:	146129   Click image for larger version
ID:	146137   Click image for larger version
post #17 of 27 Old 07-05-2014, 12:48 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Aside from the seats, everything is finished! I need to add some serious wall decor to balance out the white-grey-black coloring, but I am very pleased. The platform is about 9 feet across and probably the same depth, at a riser height of 8.5 inches.
Two sets of curved leather seats are on their way!
post #18 of 27 Old 07-05-2014, 02:18 PM
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
jefftr is offline
post #19 of 27 Old 07-06-2014, 06:22 AM
Liked: 0
You are lucky, I am surprised how little glue they used on the drywall. If it ends up being a mess removing the glue you could throw up a layer of 1/4 inch drywall and just finish that normally.[IMG]http://*******/Prn9DS[/IMG]
rtisansndot is offline
post #20 of 27 Old 09-08-2015, 12:04 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
A year later, I'm just getting around to posting the final pics of the build. The Palisair chairs came (they're awesome) and I decided to build my own bar. I completely over-engineered it for the weight it needed to hold according to the stone guys, but I figure better safe than sorry!
ID:	930090   Click image for larger version
ID:	930122   Click image for larger version
ID:	930138   Click image for larger version
ID:	930146   Click image for larger version
ID:	930162   Click image for larger version
ID:	930170   Click image for larger version
post #21 of 27 Old 09-08-2015, 01:56 PM
Quoted: 48 Post(s)
Liked: 6
Turned out really nice! Looking forward to starting my own build sometime next year.
brazensol is offline
post #22 of 27 Old 09-15-2015, 05:50 PM
DavidK442's Avatar
Quoted: 390 Post(s)
Liked: 248
Turned out great. That long narrow room is just BEGGING for a wider acoustically transparent screen though.
DavidK442 is online now
post #23 of 27 Old 09-15-2015, 06:33 PM
blake050's Avatar
Looks great. I really like how the soffit turned out.
blake050 is offline
post #24 of 27 Old 09-15-2015, 08:06 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
Last Saturday...I made mess and decided to start planning some upgrades.
Looks like Home Theater 2.0 is on its way!!
post #25 of 27 Old 09-15-2015, 09:56 PM
DavidK442's Avatar
Quoted: 390 Post(s)
Liked: 248
Yeeha! You won't regret it. What are your screen plans? Size? Material? How far off the wall will it be and what will be the resulting viewing distance to the front row?
post #26 of 27 Old 09-16-2015, 07:31 PM - Thread Starter
Quoted: 72 Post(s)
Liked: 44
I had a 135" standard screen from Elite which I was very happy with so I'm going to go with a 135" Elite AT screen - it's $899 from the company direct, which seems to be quite reasonable for that size.
I'm going with 16:9 (gasp!) because I watch a lot on my AppleTV, and do some occasional playing on a PS4.
The stage is built on 2x10s. It's about 40 inches deep and 11.5 feet wide. The screen will be about 24" off of the wall to accommodate my soon-shipping 1099 LCRs and two 18" Stonehenge subs.
post #27 of 27 Old 09-16-2015, 10:01 PM
DavidK442's Avatar
Quoted: 390 Post(s)
Liked: 248
Nice!
taboola here
