LED Rope lighting in soffits - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: How do youinstall your LED rope lights
Just clip them to the frame of the soffit 3 42.86%
Use a reflective tape to even the flow 1 14.29%
Other... please explain in a post 3 42.86%
Voters: 7. You may not vote on this poll
 1Likes
  • 1 Post By Schlemstar
post #1 of 17 Old 06-23-2014, 11:40 AM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
How do you in stall it in uor soffits?
Do you use any kind of reflective tape,... Or do you just clip it to the frame?
tia,
Ron
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #2 of 17 Old 06-23-2014, 12:03 PM
Quoted: 3255 Post(s)
Liked: 2743
post #3 of 17 Old 06-23-2014, 12:11 PM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Gravity
How do you keep the light output in a straight line? Do you use anything to make it more reflective? We have our shelf for the LED rope lights at about 4" from the ceiling... Is that about right?
ellisr63 is offline
post #4 of 17 Old 06-24-2014, 09:19 AM
Schlemstar's Avatar
Quoted: 28 Post(s)
Liked: 24
I placed mine behind crown moulding on blocks that I cut at an angle to fit behind the crown. I used ziptie mounts attached to the blocks to hold the rope light. Check out my build thread for pictures. Hope that helps!
-Schlemstar
ellisr63 likes this.
Schlemstar is offline
post #5 of 17 Old 06-24-2014, 10:37 AM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I did the first set of rope lights yesterday... Since we only had 4" to work with and our rope lights are rectangular shaped LEDs... I ended up using a paint stick for a guide and screwed the clips into the rear wall of the rope soffit. When we make our fabric panels for the soffits we will use a 1x6 for the top board instead of a 1x2 ... This should make it easier to get at the rope lights if we ever have a failure.
ellisr63 is offline
post #6 of 17 Old 06-24-2014, 01:35 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
I first laid down reflective tape and allowed gravity to set rope light into place at bottom of crown.
LED's didn't give me the light output I wanted........saved a few bucks on that decision........besides, rope lights aren't on very much so longevity is not a concern.
doublewing11 is offline
post #7 of 17 Old 06-24-2014, 04:05 PM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
What did you use for reflective tape?
ellisr63 is offline
post #8 of 17 Old 06-24-2014, 04:23 PM
Quoted: 229 Post(s)
Liked: 938
Good ole' 4" reflective duct liner tape........big box or any HVAC distributor will have it.
post #9 of 17 Old 06-24-2014, 05:24 PM
robinsj's Avatar
I will be using these:
http://www.amazon.com/LEDwholesalers...+under+cabinet
They work great, and look great and are small enough you can't see them, and plenty bright and dimmable. Have used them under cabinets, and they look good....
robinsj is offline
post #10 of 17 Old 06-24-2014, 07:44 PM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Do you have a dimmable transformer for them since they are 12v?
I went with this one... http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 They are dimmable too, but I had to use this http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 to get them to turn off. They will dim all the way down to 1% without any flicker at all.
ellisr63 is offline
post #11 of 17 Old 06-24-2014, 09:08 PM
robinsj's Avatar
Yes, I use a dimmable transformer with them..
robinsj is offline
post #12 of 17 Old 11-23-2014, 11:07 AM
dmbandtimmy's Avatar
Quoted: 38 Post(s)
where did you get your dimmable transformer and which one did you get. I just ordered the LED strip light for 11.77 on amazon. Thanks!
dmbandtimmy is offline
post #13 of 17 Old 11-23-2014, 11:13 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
Are people using the strips of LED's or actual rope lights? I was looking at these.
http://shop.ledwholesalers.com/index...product_id=572
Diesel 48 is offline
post #14 of 17 Old 11-23-2014, 05:02 PM
Quoted: 38 Post(s)
It looks like this is the same thing. I would like to know this as well. I looked at a video on youtube and some guy had it changing colors to music. That would be a cool added bonus. I'd 99% likely use it on the white and classy look, but it would be cool to have options.
http://www.amazon.com/LEDwholesalers...d+ribbon+light
post #15 of 17 Old 11-23-2014, 05:04 PM
Quoted: 38 Post(s)
http://www.ebay.com/itm/5M-SMD-RGB-5...item4170393a22
I found this also. Looks like a lot of them have been sold...
post #16 of 17 Old 11-23-2014, 06:17 PM
WIKED's Avatar
Quoted: 73 Post(s)
Liked: 44
I have a 20m one of those (10m x 2) off ebay for my soffit. Works great
Sent from my GT-N7105T using Tapatalk
WIKED is online now
post #17 of 17 Old 11-24-2014, 09:08 AM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 190
I got mine at LEDROPELIGHTSANDMORE.com. You can see in my build thread with pictures how it worked out.
7channelfreak is offline
