Solution needed for odd room shape - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 8 Old 06-24-2014, 12:10 PM - Thread Starter
neworder71's Avatar
I have a generally rectangular room, which I'm thinking about moving my theater into. However, the room isn't a true rectangle, it is more like 2 spaces a 13x13 square and a 11x10 square. The right sides align and the left sides don't. A bathroom takes a chunk out of the rear of the room.
My layout would have a triple row of recliners in the front with a non recline loveseat behind on a riser in the narrow part. So the left hand recliner will be offset and around the corner from the left side of the loveseat. The aisle will be along the full length right wall.
Given the narrow width, I can't think of a way to place the left hand surround speaker to be viable for both rows of seating.
To complicate things the roof pitches up starting at the 5' mark, it is a space above a 3 car garage. So going higher doesn't work either.
Any ideas on how to make this work?
neworder71 is offline
post #2 of 8 Old 06-25-2014, 10:30 AM - Thread Starter
neworder71's Avatar
Here is a floorplan. You can see the issue on the left
Name:	room layout.png
post #3 of 8 Old 06-25-2014, 12:30 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3036 Post(s)
Liked: 2969
That's a tough one. About the only thing I can think of is to frame in that area on the left so it is a rectangle. You could install your A / V rack and equipment in that new wall, and perhaps Blu Ray / CD storage etc. Then you could mount surround speakers.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4 of 8 Old 06-25-2014, 12:57 PM
OtterGA's Avatar
It looks like its not that uncommon. Check out the the vortex thread with the same room shape. I also have this issue in my soon to be theater. I was planning on putting an acoustical treatment on the wall that cuts into the room and placing the surround on the corner in question.
I also don't know the perfect location for the left surround, but here are some options I've been tossing around:
1.) Use in ceiling surrounds
2.) Moving everything to the right and use a bipolar speaker on the corner
3.) Leave everything as is and put the person I like the least in the far left seats
Share what you learn here and I'll do the same.
OtterGA is offline
post #5 of 8 Old 06-25-2014, 03:15 PM
Quoted: 3255 Post(s)
Liked: 2743
I have a similiar situation add a pole and the mother of all ducts here is a in progress shot. If possible center the front row and just consider the back row as overflow.
eRob likes this.
post #6 of 8 Old 06-26-2014, 07:06 AM
OtterGA's Avatar
Big, thank you for sharing! That is a rather inconvenient pole location. I like the idea of reducing the harsh 90 wall by framing a 45 angle. Where will the right (looking at screen) surround will be placed?
OtterGA is offline
post #7 of 8 Old 06-26-2014, 06:13 PM
Liked: 2743
right where the wire is hanging down
post #8 of 8 Old 06-27-2014, 09:39 AM
OtterGA's Avatar
I don't know how I missed seeing the wires! Thank you.
OtterGA is offline
