Quiet Rock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-24-2014, 03:16 PM - Thread Starter
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Quiet Rock
Ok before everyone comes back and says DD>GG and hat channel, hear me out. I know the benefits of that method, I have studied it relentlessly, unfortunately, It just is not going to happen. I would love to do it, but it is just not going to work this time around. The next theater I build will certainly be done with an architect and all the proper soundproofing for sure. I certainly understand that thread on here "what you would do different next time". LOL, I have a whole list.
I got a price today for Quiet rock 1/2" 4X8 sheet for $50. It is actually $15 bucks cheaper than the guy next door quoted me and it is in stock. So my question is, has anybody used quiet rock? I wanted to hear any feedback on how the room sounds with the quiet rock for anyone who has used it/using it.
I was just going to use 1/2" sheetrock or maybe 5/8" with Roxul insulation, but figured maybe quiet rock would give me a little more soundproofing vs just one single layer of drywall. Also I am getting the 1/2" thickness that I wanted. I know it is a little more money, but for the size of the room it is fine.
So I guess the question is, will there be any benefit what so ever using the quiet rock vs a single standard sheet of 5/8" drywall? One thing to point out is that the room has one wall attached to the house. There is nothing over head and the room sits off the house. I appreciate any feedback good or bad.
Reef
Reefdvr27 is offline
post #2 of 8 Old 06-25-2014, 10:48 AM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
What's your issue with using clips/channel?
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #3 of 8 Old 06-25-2014, 11:36 AM
sgolko's Avatar
You should use DD + GG + clips + channel instead
Sorry, haven't used it, can't provide any useful feedback.
sgolko is offline
post #4 of 8 Old 06-25-2014, 11:50 AM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
I don't have an issue. However I have windows in my room, a pocket door and also an entry door from outside. My feeling is that the room is a poor room to build a theater in, so why invest time and effort to a room that will just loose sound anyway. On the flip side I am going to hope and gamble that the quiet rock will give a little acoustical value and also help keep some of the bass inside with respect to my neighbors. If not for the neighbors, I would have just used regular rock. The neighbor left owns many exotic cars, he has a Cobra that sounds like a Nascar. He fires it up in the morning and I jump out of my pants. Does not bother me, so I feel a little bass would not bother him, but I will try to easit bit. We all have Harley's to, so the neighbor hood is used to loud machines and power equipment. Never any complaints about anything.
To late
post #5 of 8 Old 06-25-2014, 12:01 PM
BllDo's Avatar
Quoted: 575 Post(s)
Liked: 373
There's no reason that you can't use double drywall and green glue without clips and channel. Have you done the math to see which would be cheaper?
BllDo is offline
post #6 of 8 Old 06-25-2014, 12:07 PM
Quoted: 435 Post(s)
Liked: 312
To late
Sound isolation is only as good as the weakest link. Here's what I would suggest: figure out the lowest STC component in your room (that'll be the pocket door, I'm pretty sure) and don't go much higher for the wall assemblies.
Note that for interior acoustical performance having damped drywall is actually a good thing. Single layer sheetrock on normal 16" on center stud spacing has a nasty resonance around 65Hz. Quietrock 500 is such a product.
post #7 of 8 Old 06-25-2014, 12:48 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
Thanks for the post. It is funny you posted in here, I was referred to you for an HTPC. That is a little ways off, but your the same guy that does that right?
post #8 of 8 Old 06-25-2014, 01:13 PM
Quoted: 435 Post(s)
Liked: 312
Yes, we build custom HTPCs - MS2 - and design, supply equipment, install and calibrate home theaters as well as acoustical consulting.
