Building a Home Theater & Listening Room - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 32 Old 07-03-2014, 06:34 AM - Thread Starter
hydrovac's Avatar
Liked: 6
My wife finally parted with a portion of her terrace garden and let me build a home theater.
First off all I find myself very fortunate to build a room that can be dedicated to music listening and watching movies. The room will be 3.96 meters wide, 7.38 meters long and a height of 2.7 meters. So with a little more than 29 m2 it's not a big room at all.
We live in a duplex penthouse (5th & 6th floors with terrace rights). So, traditional construction methods are a bit difficult. I plan to take the prefab route.
Proposed HT Room area.
Columns set and trusses on.
hydrovac is offline
post #2 of 32 Old 07-03-2014, 08:15 PM - Thread Starter
hydrovac's Avatar
Liked: 6
The progress in construction of the prefab wall panels.
hydrovac is offline
post #3 of 32 Old 07-04-2014, 04:44 AM
Quoted: 3898 Post(s)
Liked: 3333
I admire your dedication to consume a nice terrace for your theater!
those steel spanners must have a story to tell, looks like they were cut out of another building. Hope your guy knows how to weld.
post #4 of 32 Old 07-04-2014, 08:16 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Hi BIGmouthinDC,
Keen observation and rightly pointed out! The trusses were salvaged from an existing structure, which was in front of my 5th floor duplex penthouse supporting a shade.
I have built a new structure and converted it into a sky deck and usable space. You can see the old structure below the new one.
The old trusses are shifted to 6th floor to support the composite slab of my HT. So load bearing is not an issue.
Cheers!
hydrovac is offline
post #5 of 32 Old 07-07-2014, 07:53 PM - Thread Starter
hydrovac's Avatar
Liked: 6
The 3 pics are of the composite decking sheet being fixed.... in fact yesterday...the plasterers were skimming the walls and pouring the concrete slab....
hydrovac is offline
post #6 of 32 Old 07-07-2014, 08:15 PM
BassThatHz's Avatar
Quoted: 2386 Post(s)
Liked: 2161
Gujarat?
How will you prevent the bass from rattling the metal roof?
BassThatHz is offline
post #7 of 32 Old 07-08-2014, 07:55 PM - Thread Starter
hydrovac's Avatar
Liked: 6
Originally Posted by BassThatHz View Post
Gujarat?
Gujarat? nay... newly formed state Telangana!
That is not just metal roof Bass...It's going to be composite slab of 3" thick concrete laid on top of the decking sheet.
In addition, will be doing thermal insulation to the ceiling from below and acoustic panels to tame the bass.
hydrovac is offline
post #8 of 32 Old 07-08-2014, 08:38 PM
Liked: 3333
keep the construction pictures coming, we don't get to see many theaters from your part of the world.
post #9 of 32 Old 07-10-2014, 12:29 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Started laying of electrical, speaker and signal cables. The cabling work is being carried out by a local guy and someone from my work giving him a hand.
To reduce hum and noise I want to install a dedicated line with only a single ground from the audio / home theater system to the electrical service panel. Don’t want to attach anything other than the A/ V system to this special dedicated line.
Expecting the result to be noise and hum free power with a 'deep black background'.
By this stage of the project, I have already identified the following :
  • Placement of all speakers
  • Placement of A/V components
  • Placement of video source
  • Lighting needs
  • Possible future enhancements
  • Thermal Insulation & Acoustic Treatment
BTW I have provided a frame also…for supporting the screen.
I will try and post pics if there's interest...as soon as i work out how to do it....!!
I have all the kit i need already for this…mix of new and from old lounge... not top end by any means...but works for me...
hydrovac is offline
post #10 of 32 Old 07-10-2014, 12:44 AM
sdurani's Avatar
Quoted: 5135 Post(s)
Liked: 3614
What kind of panels?
Sanjay
sdurani is offline
post #11 of 32 Old 07-10-2014, 04:59 AM
Liked: 3333
Interesting screen frame, are those vertical pieces the width of the screen? is so why are they off center in the room?
Just another thought at this stage had you considered an acoustically transparent screen a little larger and then you could tuck the speakers behind the screen? I see a couple of pedestals and assume those are for your speakers.
post #12 of 32 Old 07-10-2014, 05:05 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Hey interesting build, where are you located?
NicksHitachi is offline
post #13 of 32 Old 07-10-2014, 08:12 PM - Thread Starter
hydrovac's Avatar
Liked: 6
Planning to treat the corners with bass traps. I am also looking into membrane type bass traps which will absorb only lower frequencies. This won't absorb the high frequencies and still retain liveliness of the music.
hydrovac is offline
post #14 of 32 Old 07-10-2014, 08:23 PM - Thread Starter
hydrovac's Avatar
Liked: 6
The steel is just to support the screen frame and also to act as additional bracing to the prefab wall panels.
I am going for a 154” X 69” AT screen with 2.35:1 aspect ratio…which will be 1’ away from the front wall to accommodate behind the screen speakers.
What you see is a pair of old DIY bookshelf stands.
hydrovac is offline
post #15 of 32 Old 07-10-2014, 08:25 PM - Thread Starter
hydrovac's Avatar
Liked: 6
I am from Hyderabad...India.
hydrovac is offline
post #16 of 32 Old 07-11-2014, 12:42 AM
Liked: 3333
I am going for a 154” X 69” AT screen with 2.35:1 aspect ratio…which will be 1’ away from the back wall to accommodate behind the screen speakers.
Good choices, but that big of a screen will need bright projector, what do you have planned?
post #17 of 32 Old 07-11-2014, 01:26 AM - Thread Starter
hydrovac's Avatar
Liked: 6
I have an Epson EMP-TW2000, which can project diagonal images 30in. ~ 300in. (76.2cm ~ 762cm)...with 1600 lumen and near dark HT room brightness won't be an issue.
https://www.epson.com.au/products/pr...2000_specs.asp
Anyways... this is only a bridge gap arrangement till i setup an Anamorphic lens and video processing for a 2.35:1 image.
hydrovac is offline
post #18 of 32 Old 07-11-2014, 05:23 AM
Liked: 3333
post #20 of 32 Old 07-16-2014, 09:40 PM
ClemsonJeeper's Avatar
Quoted: 233 Post(s)
Liked: 145
yikes.
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #21 of 32 Old 07-17-2014, 08:33 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Sorry for that
Framing work completed and AV cabinet in place….cabling almost done but for one sub signal cable. Got 30 Rock wool bags delivered yesterday.
There was a leak from one point of the slab joint side…. getting the pressure grouting done today.
Entry door to the theater on the left:
Bags containing Rock wool slabs:
AV cabinet built into the window:
Ceiling panels getting ready:
Insulation panels being fixed :
Ceiling Panels fixing:
hydrovac is offline
post #22 of 32 Old 07-17-2014, 09:01 AM
Liked: 0
That looks like serious work. How will you dampen the sound?
HarlequinFloors is offline
post #23 of 32 Old 07-17-2014, 05:14 PM
rob black's Avatar
nice
rob black is offline
post #24 of 32 Old 07-22-2014, 08:35 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Thanks Harlequin Floors and rob black,
I will measure the room response once the paneling is done. Will treat the room accordingly.
Paneling of rock wool frames almost done:
Steel trusses being enclosed in wooden beams:
hydrovac is offline
post #25 of 32 Old 07-22-2014, 12:23 PM
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 265
Wow, nice progress! I too am looking forward to the accoustic treatments.
DougUSMC is offline
post #26 of 32 Old 08-08-2014, 09:51 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Back row riser in place:
Front row riser:
hydrovac is offline
post #27 of 32 Old 08-23-2014, 11:24 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Got few sample seats today... my folks liked the red one, the design part of it and not the fabric though. Actually it is wider by 2” and comfortable than the other two.
Decided to order seven seats with individual arm rests… and different cloth material which I have to select.
hydrovac is offline
post #28 of 32 Old 09-27-2014, 08:09 PM - Thread Starter
hydrovac's Avatar
Liked: 6
Slow progress, but progress nonetheless. Tough to get things done when you are on carpenter’s schedule, but I'm grinding along. Got most of the ceiling done, preparing bass traps and acoustic panels…
bpassman likes this.
hydrovac is offline
post #29 of 32 Old 12-18-2014, 10:06 AM - Thread Starter
hydrovac's Avatar
Liked: 6
Hey guys!
Here is an update on the build… I have spent countless hours on there reading and learning since I started trying to figure out what I wanted to do 6 months ago. It’s like a fun project for me... The entire room needs a good deal of sound work. Even still, I'm happy with how it sounds to my ears after watching a couple movies... I just need to contain it better for now.
It's the old saying of "measure twice, cut once"… live it, learn it, love it the downside to that is since I have never done anything like this before who knows what I missed or what I underestimated on.
bpassman and Cymark like this.
hydrovac is offline
post #30 of 32 Old 04-30-2016, 03:47 AM - Thread Starter
hydrovac's Avatar
Liked: 6
After a long gap... here is an update.
The past few months I've been gathering some more things to move forward. Here are a few goodies that were dropped off:
Video:
Panasonic DMP-BDT 360GA
DUNE HD MAX
Sony Playstation 3 (500GB)
Projector: Panasonic PT-AE8000U Full HD 3D Home Theater Projector
Screen: Screen Research 165” diagonal AT woven custom frame
Electronics:
Pre Processor: SherbournPT-7020A preamp processor
Power Amps: DIY TDA7293 based parallel design
I decided to try out tactile transducers for my home theater. Spent a lot of time researching and reading feedback from users and forums. Ended up getting two of these,
Screen frame assembly:
Grommets eyelets and Bungee tension ties:
Here is a trial fitting and assembly of the screen frame...
This is how my existing screen looks:
Existing Speaker setup:
New Screen fixed:
hydrovac is offline
