Any interference or problems with running wires alongside support I-beams? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2014, 05:44 PM - Thread Starter
kronin's Avatar
Quoted: 23 Post(s)
Liked: 5
We are in the process of building a house. There will be a theater in the basement and I'm mapping out wiring. The easiest run from front to back (speaker wire, coax for subs, HDMI) would be right in the channel alongside a support I-beam.
Has anyone run wire like that before? Any downsides? I can drill holes and run it through the joists instead, just thought this would be easier (plus have the benefit of being able to easily pull additional wire if needed).
kronin is offline
post #2 of 4 Old 07-05-2014, 06:13 PM
HopefulFred's Avatar
Quoted: 309 Post(s)
Liked: 281
HopefulFred is offline
post #3 of 4 Old 07-06-2014, 04:26 AM
Quoted: 1222 Post(s)
Liked: 1107
BIGmouthinDC is online now
post #4 of 4 Old 07-06-2014, 06:07 AM - Thread Starter
kronin's Avatar
Quoted: 23 Post(s)
Liked: 5
Thank you. That was my first thought as well, but with enough uncertainty to drive me to ask anyway.
kronin is offline
