Home Theater Acoustic solutions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-10-2014, 03:00 AM - Thread Starter
Liked: 0
Lightbulb Home Theater Acoustic solutions
Hello, I am building my home theater and looking for room acoustic solutions. I want to partly cover walls (they are concrete).
I was looking for wall panels for a month and finally found a manufacturer of custom acoustic panels. They allow me to choose from different dimensions and depths, plus, they can built me custom dimensioned panels. They also allow to print customer's ideas on them - graphics or photos, what I think is very welcome to personalise my own theatre and by looking at technical data, they are very effective in comparison to foam panels. Unfortunately they do not offer bass traps at the moment.
I wonder if bass traps are even needed in home theatres ??
The manufacturer is called RW Acoustics (just google it) if it helps anybody.
I do not want to add any object in my theater later, I want to find everything in advance.
Thank you very much for your answer.
Mario
MarioR is offline
post #2 of 16 Old 07-10-2014, 03:13 AM
Berland's Avatar
Quoted: 50 Post(s)
Liked: 32
short answer; bass-traps are always needed
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D - 2*Schiit Yggdrasil - 2*Audiobyte Hydra Z/ZPM - 2*iFi micro iUSB 3.0 - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is offline
post #3 of 16 Old 07-10-2014, 03:19 AM - Thread Starter
Liked: 0
Thanks for quick answer, so I am going to search for bass traps further
MarioR is offline
post #4 of 16 Old 07-10-2014, 09:57 AM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
If you want the sound to be smooth (non muddy with punch) on the low end then yes you need bass trapping and a lot of them.
http://gikacoustics.co.uk/video_bass-traps/
We also do prints on the front of panels. Just make sure they are not using screen printing, but using a dye sublimation process. It is important that the sound can travel through the fabric, not reflect.
http://gikacoustics.co.uk/product/gi...oustic-panels/
Glenn Kuras
GIK Acoustics
http://www.gikacoustics.com
myfipie is offline
post #5 of 16 Old 07-19-2014, 07:56 AM - Thread Starter
Liked: 0
I already saw gik products, but here is the problem that i came to - the price.
I own home theatre equipment that costs 120.000$. I can not imagine to full equip my room with panels that costs up to 3.000$. It just does not make sense to have such an expensive system and relative low budget panels.
I believe gik are working great, but I want best quality products in my room, just like my system - and it seems that RW Acoustics are the only one that are making high end acoustic panels, just look at the details of their products. I believe every user of high end system will confirm this.
I think i will look for custom made bass traps that can be hidden.
Thanks for your answers!
Mario
MarioR is offline
post #6 of 16 Old 07-19-2014, 02:39 PM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
We also do a lot of custom size things for "picky" customers and have customers that have spent WAY more then 150k on equipment. Needless to say my point was if you plan on using prints on the fronts just make sure they use dye sublimation printing vs screen printing. I most say that RW's wood trim panels do look pretty nice. The others are just common fabric wrapped panels.
Best of luck on your room.
Glenn Kuras
GIK Acoustics
myfipie is offline
post #7 of 16 Old 07-20-2014, 08:35 AM - Thread Starter
Liked: 0
I think there will be acoustic expert needed to define how and where to build bass traps. Was looking something about helmholtz type of them, don't know yet..
I checked and they use digital print directly to acoustic fabrics, so i believe it does not effect the sound?
Well, they are not just common fabrics wrapped panels, although basically this is it. Panels are precisely finished with rear aluminium frame, offering to mount them with distance from the wall, some kind of side perforation too.. A lot of additions after all..
I don't have any wooden furniture plans in my room, so Luxury series is not my wish, but they do look pretty amazing, i agree
MarioR is offline
post #8 of 16 Old 07-20-2014, 09:30 AM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
Perhaps have them send you a sample of something printed. You could then try the "blow" test to see how transparent the fabric is. Basically hold it up to your mouth and blow through it. If it is hard to breath through then it might not be the best way to go. You want the fabric to be as transparent as possible.
Nothing wrong with something tuned but small rooms have nulls, peaks and decay throughout the lows and mids. Generally I would recommend a good dose of broadband and then follow up with something tuned if you still have problems.
http://www.gearslutz.com/board/7597560-post146.html
Here is a few things that might help you further understand how low end reacts in a room.
http://gikacoustics.co.uk/understand...bass-trapping/
Glenn Kuras
GIK Acoustics
myfipie is offline
post #9 of 16 Old 07-20-2014, 10:10 AM - Thread Starter
Liked: 0
They already have their data of absorption on their page, but I will do that anyway.
Thanks for links too. So I will probably buy panels first, then add some bass tuned system if needed, but I will need measurement anyway I think..
I also found LED Backlight in Professional series of RW Acoustics panels very useful to make ambient lighting in my theatre
Hard job to combine everything...
Mario
MarioR is offline
post #10 of 16 Old 07-20-2014, 10:32 AM
Berland's Avatar
Quoted: 50 Post(s)
Liked: 32
Keep in mind that even though RW Acoustics are built in higher quality. The acoustic properties of GIK are better (they have more advanced options and performance). In short, GIK performance are better than RW Acoustics.
Berland is offline
post #11 of 16 Old 07-20-2014, 11:24 AM - Thread Starter
Liked: 0
Very hard to say about performance if you did not try both products, because they use same absorption material and by looking at technical data they are very close, rw even better at low frequencies.. I believe the effect is almost the same. I really do not see any "advanced" options in broadband range of gik panels while rw has spacers and side perforation, if you call these "advanced"options..
I think your answer is more like "preferring gik over rw for reason that I don't know".
I need high quality broadband panels first and then i will look at lower frequencies just likeGlenn said.
Don't get me wrong, but high quality is important for me (after all I will have these panels forever, i hope), even the effect is almost the same and RW really have high end quality products.
Mario
MarioR is offline
post #12 of 16 Old 07-20-2014, 02:06 PM
Berland's Avatar
Quoted: 50 Post(s)
Liked: 32
For standard GIK acoustics plates; performance is close; but on GIK you can add built in scatter plate (built in; for diffusing high fequencies in addition to absorbing them... giving a more natural end result.
In addition GIK got a large selection of products for bass-traps in addition to other types of products. From what I`ve seen; these selections can not be found in RW acoustics products.
Berland is offline
post #13 of 16 Old 07-20-2014, 02:33 PM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
We actually build in the air gap which is one of the reasons why they do perform better then most.
There products do not look bad at all but I stand behind ours being high quality also.
Good luck with your room!
Glenn Kuras
GIK Acoustics
myfipie is offline
post #14 of 16 Old 07-21-2014, 12:40 AM - Thread Starter
Liked: 0
I am not saying gik has bad quality, not even close, really. But there are differences in final finish and precision in build as I saw.. I know about air gap at gik, rw went even further with spacers. There are details which count here (well, for me it is important).. Thanks for help Glenn
MarioR is offline
post #15 of 16 Old 07-21-2014, 01:54 AM
CinemaAndy's Avatar
Quoted: 706 Post(s)
Liked: 139
http://www.auralex.com/theatre.html Auralex is who i have used for years on the commercial side of cinema. Great company great products.
CinemaAndy is offline
post #16 of 16 Old 07-24-2014, 02:45 AM - Thread Starter
Liked: 0
I know about auralex, but they have foam acoustic solutions, not so effective that i need.
Thanks anyway
I just got the printable sample from RW and the fabrics is just like Glenn described, so it is OK. I think I will order panels from RW Acoustics and then call someone to measure my room to find out about bass traps..
Glenn, thanks for your help again! Can you please tell me some more about gik bass traps?
MarioR is offline
