2 rows...5.1 or 7.1 with back row close to wall...Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 07-14-2014, 04:16 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Hi...
Trying to decide 5.1 or 7.1
I have 2 rows in a 20ft long by 16ft wide room.
Second row is within 4-5 inches from the back wall (which enables the chairs to recline)
second row head position is 19ft from front screen which will place ears about 15 inches from back wall .
The back row has 5 chairs which are about 16 inches to side wall (or about 30 inches to ears from side wall )wall
front row is 4 chairs and will be 12.5 from front screen...Attached is a rough schematic from 3d renderings I did from overhead and sides...I just drew the chairs as a bench but they are actually separate chairs.
I fear I did not leave myself much room behind the back row...
a) should this be a 5.1 or 7.1 set up?
b) what type of speaker should I be using for the rear? A satellite or a surround (one of the flatish speakers that fire have speaker angles at 45 degrees ...
I was all set to go with a Triad system (silver) in Room LCR with silver in room satellites but noticed this issue of the back row and speaker placement .. I wanted to be able to have upgrade path for Atmos with out moving speakers around.....SHould I be getting Triad Surrounds instead? I see SVS has a surround that has a Duet mode....it can function as two separate speakers in one box.....Maybe that would be a solution .....Anyways, trying to solve this last issue...was about to order when I noticed this...DOH!....any help?
Name:	Theater render overhead.JPG
ID:	161081   Click image for larger version
Name:	theater render side.JPG
danrudy is offline
post #2 of 21 Old 07-14-2014, 04:26 PM
sdurani's Avatar
Quoted: 5136 Post(s)
Liked: 3618
With your main row of seating away from the back wall, you are an ideal candidate for a 7.1-speaker layout.
Place the Side speakers directly to the sides of the main row, mounted a couple of feet above ear level. The Rear speakers should go on the back wall, spread at least 9 feet (60 degrees) apart, also mounted a couple of feet above ear level (firing over the heads of listeners in the back row, so it won't be distracting).
This should give you wrap-around envelopment and excellent rear-vs-side separation in the surround field, which just wouldn't be possible with only 2 surround speakers.
Sanjay
sdurani is offline
post #3 of 21 Old 07-14-2014, 05:14 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Sanjay...
Thanks for quick reply...
WIll the back row folks get the benefit of the rear speakers on the back wall or will it just go over their head. ALso, on the side, since the speakers I am leaning towards are about 7-8 inches deep, I prefer to have them about 7-8 ft off the floor (so no one bumps their head as they walk under them and for aesthtiques....the ceilings are 10ft high in my room), Will that height be ok?
danrudy is offline
post #4 of 21 Old 07-14-2014, 05:58 PM
sdurani's Avatar
Liked: 3618
Listeners in the back row will benefit from the Rear speakers to the extent that they will hear those sounds AND those sounds will be distinct from what they hear coming from the Side speakers.
As for Side speaker height, I mounted mine just above 6 feet, for the exact same reason you mention (keep guests from banging their heads). A foot higher than that will be fine.
Sanjay
sdurani is offline
post #5 of 21 Old 07-14-2014, 07:01 PM
thestoneman's Avatar
Quoted: 133 Post(s)
Liked: 49
If your room has exposed studs then I would go at least 7.1. I have a similar sized room and I'm wiring for 9.2.4. Dolby Atmos could very well take off and I am going to wire for it.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
post #6 of 21 Old 07-14-2014, 07:13 PM
awblackmon's Avatar
Quoted: 50 Post(s)
Liked: 59
This is exactly what I did in my room. I don't have regular full time seating in the very back row but when we add additional chairs for the overflow crowd in the room the effects Sanjay says will occur is exactly what happens in my room. I usually sit in the overflow to be a good host.
Mitsubishi 3800. Marantz 8802A Sound ably handled with Minimus 7 LCR speakers in a baffled wall behind AT screen. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 77. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide, overhead speakers and back surround. Kenwood Basic M1D doing Subwoofer work. Sound is 9.2.2.
awblackmon is offline
post #7 of 21 Old 07-14-2014, 07:56 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
How large is your screen going to be.
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #8 of 21 Old 07-14-2014, 09:25 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Have a 140 inch 2.35
Plan is to put CC above the screen angling down to have direct line of sight to both rows
danrudy is offline
post #9 of 21 Old 07-14-2014, 09:29 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Thanks again!!
Feel much more confident about setting room up now for speakers. Honestly, I thought my rears were suppose to be in the corner side....I feel much better having a plan to put them on the back wall ! Ithought I was going to be doing a compromise setup. I am glad that it is "ideal" for a 7.1
danrudy is offline
post #10 of 21 Old 07-14-2014, 09:35 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
I think I will get the wiring done for the 7.1
I plan to have 4 ceiling speakers. I will have easy access for that so I can add the ceilings at any time. SO endgame will be 7.1.4 or 7.2.4
But this will require a 11 channel AV receiver.
That is the other remaining issue for me. Is anyone making a 11 channel Atmos enabled receiver. I want to buy a receiver now as well as my wife want this project completed ASAP! I would rather buy one upgradeable receiver then have to swap one out in 6 months....I see Yamamah 3040 will have firmware update. But, is that a 9.2 or 11 channel speaker? BEst I can tell it is 9 and can use an additional two channels with another amplifier....
danrudy is offline
post #11 of 21 Old 07-15-2014, 12:11 AM
sdurani's Avatar
Liked: 3618
You need to pre-wire for the speakers in yellow (Top Fronts and Top Rears).
Sanjay
sdurani is offline
post #12 of 21 Old 07-15-2014, 10:13 AM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Thanks, Again very helpful.
I purchased the 7 speakers this morning...Hoping to take delivery in about 7-10 days.
With regard to the sides which are suppose to be level with first row.
As you can see on the diagram on prior posting and the attached pic on this one, my AV cabinet is about at the level of the first row in side wall. Actually, more of an AV niche. This precludes me simply handing it on side wall as their is an opening there for the AV closet niche.
I suppose I can place the side speaker just forward to the niche which would put the sides just anterior to the first row. Alternatively, I can place it in the niche and hang it on the wall. I envision a little shelf along the wall of the niche that is towards the front of the room. I would do it so it was flush with side wall and not recessed into the niche. THis way it is above the cabinet height and not recessed into the niche. I figure since this is a satellite speaker and is sound waves only out the front there will be no effect from the niche opening behind it to mess up the effects. Is that a correct assumption?
Is either preferential to the other?
danrudy is offline
post #13 of 21 Old 07-15-2014, 10:39 AM
sdurani's Avatar
Liked: 3618
That might end up being a bonus rather than a problem, since placing those speakers slightly forward of the listening position will add spaciousness.
Sanjay
sdurani is offline
post #14 of 21 Old 07-15-2014, 12:22 PM
Nyal Mellor's Avatar
Quoted: 462 Post(s)
Liked: 342
Sanjay are you not concerned with being too far vertically off axis if the speakers are mounted that high? Speakers generally have pretty narrow operating window vertically due to interference between vertically stacked drivers. Personally I would have suggested mounting the rears lower and in wall and using a coaxial of some kind.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is online now
post #15 of 21 Old 07-15-2014, 01:34 PM
sdurani's Avatar
Liked: 3618
Nyal, with the back row 4-5 inches from the back wall, my main concern was that the rear speakers not be a constant distraction to those listeners. In-walls mounted lower would be very close to their ears. Hence the suggestion to have bookshelves fire over their heads.
Also, with that row being so close to a wall, I figured it would be used more how Alan described a few posts up, as overflow seating rather than for critical listening.
As for off-axis response, the speakers can be tilted and/or toed-in towards the listening area. My side speakers are around ±80° from centre, mounted 6 feet up (to clear the heads of most guests) and pointed at the listening area (actually, cross-toed to the person at the opposite end of the couch).
If you've got alternate suggestions, now is the time (before the OP starts nailing speakers to the wall).
Sanjay
sdurani is offline
post #16 of 21 Old 07-15-2014, 02:39 PM
dhendriksen's Avatar
Quoted: 25 Post(s)
Liked: 31
The way your describing your room, it is much like mine!
Check out the thread in my signature. I have the same number of seats, in the same configuration, and the same room depth.
I went with 7.2 and it's AWESOME! You can see more about how it laid out in my thread about the build.
dhendriksen is offline
post #17 of 21 Old 07-15-2014, 03:25 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
My room is 16x17 with back row few inches off wall. I have 7.3 and sound great. Back row is used for if we have guest but with 4 of us it's usually front row. My rears are episode 500's in the ceiling and in side wall.
Cksqurd is offline
post #18 of 21 Old 07-15-2014, 07:07 PM
Quoted: 462 Post(s)
Liked: 342
No you are spot on, I did not properly read the initial post and missed the 4-5" thing. It's not easy to aim a Triad in wall as it's designed for in wall installation with dog legs to hold it to the sheetrock. However you could use their in ceilings with the angled baffles to point the speaker down towards the seating area.
post #19 of 21 Old 07-15-2014, 07:39 PM
sdurani's Avatar
Liked: 3618
Is the OP using in-walls?
Sanjay
sdurani is offline
post #20 of 21 Old 07-15-2014, 07:43 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
Good idea, IF the OP is using in-walls, then the angled in-ceiling speakers (mounted in the wall) would be better than using their in-walls for surrounds (and eventually on the ceiling for the OP's next major upgrade).
Hi guys,
I purchased and am awaiting delivery inRoom silver Triads.
This includes the triad silver LCR and 4 silver satellites http://www.triadspeakers.com/products/irssat.html
The center channel will be made to be horizontal by triad as a minor upgrade.
Am at work so will respond more fully when I get home a little later.
I have no issue nutting these in brackets and putting them at an angle.
However, I am not sure where my prime seating postion will be. I suspect for 16.9 content I will prefer front row but I may prefer second row for 2.34 given the image size....I am putting in a 140 diagonal 2.35 screen to use in constant image height which should be about a 110 diagonal 16:9
danrudy is offline
post #21 of 21 Old 07-15-2014, 07:46 PM - Thread Starter
danrudy's Avatar
Quoted: 33 Post(s)
No...inRoom....these are not in wall. That is not a real option given the space...the walls are not amenable to placing an in wall....they will have to be attached to the wall
danrudy is offline
