Rope LED; Smarthome Insteon Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-16-2014, 07:43 AM - Thread Starter
jjensen9971's Avatar
Here is what I want to do:
- I own a LampLinc - INSTEON Plug-In Lamp Dimmer Module (Dual-Band), 2-Pin
http://www.smarthome.com/2457D2/Lamp...d-2-Pin/p.aspx
- The above Lamplinc module will be controlled by INSTEON Keypad Dimmer Switch (Dual-Band), 6-Button, Gray
http://www.smarthome.com/2334-238/IN...on-Gray/p.aspx
I need to buy a 50' LED cool white rope light to install in my soffit over my home theater and I want the above items to be able to dim this LED rope light.
What LED rope light will work?
Where do I buy it?
Thank you.
J. Jensen
jjensen9971 is offline
post #2 of 2 Old 07-16-2014, 12:39 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 75
You'll want to buy the LED rope light that plugs into a standard wall outlet. If you get any of the stuff that requires a separate power supply, you won't be able to use the Insteon dimmers. Amazon has a number of items listed under LED rope light, as does Home Depot or Lowes. Just do a quick google search.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
