Can I have a home theater in a basement with Concrete walls? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-22-2014, 09:16 PM - Thread Starter
Liked: 0
I am moving into an apartment that has a basement, but with concrete brick walls. its an apartment so I cant add drywall and walls and crap but is there gonna be a problem with the audio mainly with it being in a concrete walled basement? If so is there any alternatives to do to the basement that doesn't call for total full on basement remodeling/construction?
traindune is offline
post #2 of 5 Old 07-22-2014, 09:18 PM - Thread Starter
Liked: 0
This is the basement as is, I plan to add carpet but will the concrete walls be a problem? I plan to paint them a relaxing beige.
http://i.gyazo.com/819ead878ce428c81dd06718a7bf0665.png
post #3 of 5 Old 07-23-2014, 04:51 AM
Quoted: 3653 Post(s)
Liked: 3103
It will be an echo chamber for sure. But you can DIY some acoustical panels and either hang them down from the ceiling joists with wire/string or give them legs and make them freestanding.
If you are planning a projector darker colors are best to avoid reflections back to the screen, I wouldn't paint the walls beige.
Without a ceiling of any type you can expect sound to travel upstairs.
The good news it is fairly sizable space and it won't be hard to block the window to control the light. You will need some outlets in the right locations.
post #4 of 5 Old 07-23-2014, 05:25 AM
Tedd's Avatar
Quoted: 1054 Post(s)
Liked: 404
Why not just hang some buy some dark drapery panels, thread them on dowels, and hang via chain from the floor joists?
You could make some acoustical panels and hang them behind the drapery panels too. Hang the screen via chain.
Hit the end of the roll carpet area, for inexpensive carpet remnants. Or you could do a DIY acoustically transparent screen.
And the wall could be screwed together and held in place by a couple of screws into the floor joists, plus a couple of dabs of
silicone under the foot plate.
Minimal work to return the basement to it's original condition.
Tedd is online now
post #5 of 5 Old 07-23-2014, 05:28 AM
Reefdvr27's Avatar
Quoted: 1578 Post(s)
Liked: 1060
It is a shame its an apartment. That would be a perfect theater
Reefdvr27 is offline
