3D Demo Disc Reelwood 3D - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #31 of 338 Old 08-01-2014, 01:18 PM
James Freeman's Avatar
Quoted: 517 Post(s)
Liked: 341
Originally Posted by bori View Post
I don't get what I am doing wrong. When I view the video all I get is 2d video not 3d. I tried it on my ps3 and LG.
I had the same issue, here is what fixed it:
Re-run the HDMI settings and select Automatic.
James Freeman is offline
post #32 of 338 Old 08-01-2014, 02:27 PM
superleo's Avatar
Quoted: 82 Post(s)
Liked: 303
If you are going through a receiver. PS3 > Receiver > 3D TV. Your receiver must be HDMI 1.3 of higher otherwise you need to go from the ps3 directly to the 3D TV.
If you have a PS4 you are SOL, the PS4 does not support 3D bluray.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is online now
post #33 of 338 Old 08-01-2014, 03:10 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
I have the ps3 directly connected to my 3d projector. All other 3d movies play fine.
bori is offline
post #34 of 338 Old 08-01-2014, 04:02 PM
Archaea's Avatar
Quoted: 3076 Post(s)
Liked: 2691
PS4 recently started supporting 3d through a firmware update I thought?
Archaea is offline
post #35 of 338 Old 08-02-2014, 02:11 PM - Thread Starter
pjvader's Avatar
Quoted: 74 Post(s)
Liked: 128
sorry i didn't know anyone had replied! (i thought it would let me know automaticaly but clearly not!)
i will add a torrent asap but i just got a 3d clip from guardians of the galaxy and i'm working on a better cap 2 clip so i'll update the disc accordingly
glad people are enjoying it it's taken along time to get to this point
Archaea likes this.
Please Visit My 11.2 3D Home Cinema Shed http://www.readersheds.co.uk/share.cfm?SHARESHED=2744 as featured in home cinema choice magazine! Check out my blu-ray THX WOW! demo disc here
pjvader is online now
post #36 of 338 Old 08-02-2014, 02:43 PM
bluer101's Avatar
Quoted: 374 Post(s)
Liked: 293
Thanks, I signed up and tried the Mega link but it keeps crashing or getting interrupted.
Maybe the torrent will help. I'm going to use in on a USB stick with my Oppo103d since I don't have a BD burner.
bluer101 is online now
post #37 of 338 Old 08-02-2014, 02:47 PM
cbatc's Avatar
Quoted: 90 Post(s)
Liked: 34
I had multiple failures on three different computers using chrome. I installed the latest version of firefox on my oldest laptop and it worked on the first try.
cbatc is online now
post #38 of 338 Old 08-03-2014, 05:52 AM
shepP's Avatar
Quoted: 39 Post(s)
Thanks for the incredible amount of work you have put into this. I can't even begin to calculate all the people that will now enjoy this as a 3D demo. Any chance of a newsgroup release after torrent?
pjvader likes this.
shepP is offline
post #39 of 338 Old 08-03-2014, 06:24 AM
superleo's Avatar
Quoted: 82 Post(s)
Liked: 303
To my surprise the ps4 now supports 3d BD. I'm not sure if it was the very last firmware update or the one before it, but it had to be very recently.
Just re-watched gravity 3d but this time using the PS4.
Thanks for the head up Archaea.
pjvader likes this.
post #40 of 338 Old 08-03-2014, 08:22 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
What app are you guys using to burn to disc? Is not an image file so how do you use image burn?
bori is offline
post #41 of 338 Old 08-03-2014, 05:16 PM
WIKED's Avatar
Quoted: 80 Post(s)
Liked: 47
When I started downloading it on MEGA when it was first posted I too had problems on my MBP as it would stall at around 8%. I went to my PC and downloaded it as a ZIP file and it went through fine in about 2hrs.
I just put it on a USB and plugged it in into my Oppo 105 and works like a charm. Thanks again pjvader!
pjvader likes this.
WIKED is offline
post #42 of 338 Old 08-03-2014, 06:13 PM
superleo's Avatar
Quoted: 82 Post(s)
Liked: 303
ImgBurn can burn pretty much any format, it is not only for ISO/IMG files. You can choose to burn the actual folder structure, just make sure you choose UDF 2.5
There are several "how-to", or you could look for a youtube tutorial.
post #43 of 338 Old 08-05-2014, 03:29 AM
BackQuack's Avatar
I successfully made 2 coasters trying to burn this. It won't play in my Panasonic or my LG. Not sure what I'm doing wrong. I've never created a BR with ImgBurn using folder structure before but I looked at a couple tutorials online and it seemed pretty straightforward. The disc will play in my computer (in 2D) using VLC. Any ideas? Thanks.
BackQuack is offline
post #44 of 338 Old 08-05-2014, 11:54 AM
termite's Avatar
Quoted: 158 Post(s)
Liked: 48
When you give the folder into Imgburn it automatically recognizes that you're tring to burn a blu-ray disk and
tells you that it needs UDF 2.5 and ask if you want imgburn to set that for you. Click yes and that's pretty much it.
termite is offline
post #45 of 338 Old 08-05-2014, 12:00 PM
04rex's Avatar
Quoted: 132 Post(s)
Yeha, I tried downloading it as well, and it kept stopping. I am using Chrome. A torrent would probably be the best I think.
04rex is offline
post #46 of 338 Old 08-05-2014, 12:51 PM
Ronald Epstein's Avatar
Quoted: 104 Post(s)
Liked: 93
Need a torrent link, please.
Also, instructions for a Mac using TOAST, though I think I might be able to figure it out.
Ronald Epstein is offline
post #47 of 338 Old 08-05-2014, 12:57 PM - Thread Starter
pjvader's Avatar
Quoted: 74 Post(s)
Liked: 128
torrent will be asap just adding a few more clips, and adjusting a few previous ones (i lost some of my master files along the way!) shouldnt be too long i'm going as fast as my pc allows
post #48 of 338 Old 08-05-2014, 01:01 PM
raynist's Avatar
Quoted: 1542 Post(s)
Liked: 1504
Great!
I tried safari, chrome and Firefox on a Mac and could not get it downloaded. Tried IE on a laptop with no luck either.
raynist is online now
post #49 of 338 Old 08-06-2014, 04:18 AM
BlueChris's Avatar
Quoted: 236 Post(s)
Liked: 108
1st thx for this great demo... no words man....
Does anyone knows a way that i can see this without burning it? i mean i dont have a burner...
My tv is a LG 55UB950v and i got a Samsung BD-H6500... also a PC with XBMC and i have in it PowerDVD but i never had sucsess playing a 3D movie with it...
pjvader likes this.
BlueChris is offline
post #50 of 338 Old 08-06-2014, 05:14 AM
Quoted: 104 Post(s)
Liked: 93
Was the torrent ever posted?
post #51 of 338 Old 08-06-2014, 08:18 AM
termite's Avatar
Quoted: 158 Post(s)
Liked: 48
You can try coping the BDMV folder into an empty USB drive and plug that into your 3D blu-ray
player or TV directly to if they can recognize it.
termite is offline
post #52 of 338 Old 08-06-2014, 08:54 AM
cbatc's Avatar
Quoted: 90 Post(s)
Liked: 34
Does your LG TV have a Plex app? Or maybe your Samsung player? My Samsung smart TV has the Plex app. I just added the folder to my Plex library. The only down side is I don't have any menus. Just one continuous two hour film.
cbatc is online now
post #53 of 338 Old 08-06-2014, 09:42 AM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
Not yet. See post below.
pjvader likes this.
duc135 is offline
post #54 of 338 Old 08-06-2014, 11:50 AM
BlueChris's Avatar
Quoted: 236 Post(s)
Liked: 108
Thank you both. Now i saw your replies.. in the mean time i passed it with MakeMKV and then with TSMuxer to save it as .m2ts and its ok now.. i got 1 big file but Samsung bluray plays it fine... i will try the Plex solution though..
Thx again.
post #55 of 338 Old 08-06-2014, 07:16 PM
LastButNotLeast's Avatar
Quoted: 1779 Post(s)
Liked: 1397
Are you getting hi-def audio? I had better luck going from m2ts to tsmuxer to a bd folder, which creates bdmv and certificate folders.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #56 of 338 Old 08-06-2014, 07:51 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Can someone help me out here. How does this video show when playing it on you BD player? Does it automatically change to frame packing? Or is it SBS or Top to bottom? Then you have to manually change ur tv to 3d? Cause I get regular 2d video displaying 3d video.
bori is offline
post #57 of 338 Old 08-07-2014, 04:09 AM
BlueChris's Avatar
Quoted: 236 Post(s)
Liked: 108
I will see that tonight when i get home from work...
post #58 of 338 Old 08-07-2014, 04:14 AM - Thread Starter
pjvader's Avatar
Quoted: 74 Post(s)
Liked: 128
it should just play like a normal 3d-bd what player are you using?
post #59 of 338 Old 08-07-2014, 06:48 AM
Radikus's Avatar
Liked: 0
Can someone test this disc using Playstation 4?
The one I burned jumps to menu after play, but these seem to work fine on PS3.
Radikus is offline
post #60 of 338 Old 08-07-2014, 08:28 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Ps3
bori is offline
