3D Demo Disc Reelwood 3D - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
Old 08-11-2014, 07:19 PM
vistadelloco's Avatar
I would like to keep this on my htpc and not burn to disc. but not @ 50GB
Can 3D video be compressed (not sbs or top to bottom)
?'s on Handbrake and MK3D
Edit- I see its 20 GB
vistadelloco is offline
Old 08-11-2014, 07:49 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
I would like to know this too. Using DVDFab I can reduce to 55 % so it can fit in a 25gb disc.
bori is offline
Old 08-11-2014, 09:26 PM
LastButNotLeast's Avatar
Quoted: 1352 Post(s)
Liked: 949
Originally Posted by bori View Post
Mine doesn't ask. All I get after starting is do I want to create a volume label. What version on imgburn are u using?
There must be something wrong with your BDMV folder, since this is what I get:
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 08-11-2014, 09:29 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Nope I don't get that.
bori is offline
Old 08-11-2014, 09:30 PM
duc135's Avatar
Quoted: 153 Post(s)
Liked: 219
I think that's the problem. He doesn't have a Certificate folder in the same directory. It was never downloaded. That's why it's not prompting him. This is the reason why I said he can just create an empty folder. There is nothing special about it that creating it won't work.
duc135 is offline
Old 08-11-2014, 10:34 PM
Archaea's Avatar
Quoted: 2626 Post(s)
Liked: 2264
Darn my Verizon mifi. It apparently blocks torrents. I'll have to get a friend to download this.
Archaea is offline
Old 08-12-2014, 02:27 AM
ippodrome's Avatar
Have it fully downloaded now and will keep seeding at 30mb/s currently uploaded 142GB!
THX for putting this together! Masterpiece!
pjvader likes this.
ippodrome is offline
Old 08-12-2014, 02:34 AM
thetifosi's Avatar
Liked: 0
does anyone have problems playing this?
i rtied playing the disc image in my dune base 3D -> only got a black image. what is weird is that the dune player does not append a "3D" next to the details 1080p in the playlist of files as it usually does for other 3D discs. i am suspecting that my player is playing this as a 2D file as it cannot be identified as a 3D file. is there a flag i must set?
i tried playing just the m2ts file. no go too.
any advise will be appreciated.
thanks.
thetifosi is offline
Old 08-12-2014, 06:55 AM - Thread Starter
pjvader's Avatar
Quoted: 73 Post(s)
Liked: 124
hope it's all going ok? i've uploaded 35.4gb to somewhere lol
Please Visit My 11.2 3D Home Cinema Shed http://www.readersheds.co.uk/share.cfm?SHARESHED=2744 as featured in home cinema choice magazine! Check out my blu-ray THX WOW! demo disc here
pjvader is offline
Old 08-12-2014, 10:46 AM
ippodrome's Avatar
Well it's all there but I can't get any 3D!!
Can't output anything but 2D to my Sony HW-50 from my HTPC running XBMC, have also tried PowerDvd 14 but no luck!
Old 08-12-2014, 11:15 AM
Ronald Epstein's Avatar
Quoted: 103 Post(s)
Liked: 92
Yeah, same problem....
It's all there. Burned perfectly with Roxio Toast. Just in 2D not 3D.
Any solution?
By the way, it appeared as a single BDMV video on my Mac. Just dragged it into Roxio Toast and burned as a BD Movie.
Ronald Epstein is offline
Old 08-12-2014, 11:24 AM
Quoted: 103 Post(s)
Liked: 92
Tell you what...
Perhaps someone can post a step-by-step tutorial on doing this.
I can do this on Windows via Parallels virtual machine so a Windows tutorial with the needed software and step-by-step instructions would be helpful.
Also...
This is only one file. There is some confusion about a certificate folder that needs clearing up as well. Not sure if that is an additional download or not.
Thanks again for putting this all together. It's just that some of us are not having much luck with it.
Old 08-12-2014, 11:37 AM
ippodrome's Avatar
I just wanna add that my setup works excellent with SBS and over/under 3D usually but not with this disc...
Just shows 1080P and dts....
Hope it solvable!
Old 08-12-2014, 11:52 AM - Thread Starter
pjvader's Avatar
Quoted: 73 Post(s)
Liked: 124
Red face
Originally Posted by Ronald Epstein View Post
Tell you what...
Also...
I do apologise about this but i guess we are like guinea pigs in a way as we have no idea what will and won't play a homebrewed 3d disc
i have personally tried it and got it playing in 3d on-
panasonic 110
panasonic 310
toshiba 3d player (can't recall model no. sorry)
total media theatre 6 (PC)
powerdvd 13 (PC)
am i to understand that the torrent is not including the "certificate" folder? if it is not there (probably because they are empty) you can create your own
step 1-
create a new folder named CERTIFICATE
step 2-
create another empty folder, name it BACKUP and place it inside the CERTIFICATE folder
step 3- it should now look like this
BDMV
CERTIFICATE
if you open certicate it should have just a backup folder which is also empty
BDMV
CERTIFICATE
----BACKUP
if you go into the STREAM folder situated inside BDMV there should be lots of .m2ts files numbered from 0000.m2ts to 0099.mts
some players will happily play without the certificate folder if you have problems and have a spare bd-rw (i have found this to be invaluable whilst testing and downloading other home made demos) try burning one with a certificate folder and one without just incase the other one works
pjvader is offline
Old 08-12-2014, 12:37 PM
Quoted: 103 Post(s)
Liked: 92
I don't know if this is a problem or not, but I am re-encoding it from PAL to NTSC.
Old 08-12-2014, 01:45 PM
ippodrome's Avatar
Nah... Don't think so, same for me though I'm europan and a PAL-guy....
Old 08-12-2014, 01:47 PM
Quoted: 103 Post(s)
Liked: 92
I am giving up on this.
Don't want to keep wasting blank BD-R discs.
This time I actually opened the contents of the file, created a CERTIFICATE folder and placed the BACKUP in there.
Then burned all the files on the disc.
Did this on a Mac via Roxio Toast.
Same results. 2D picture. It's all there, just not in 3D.
Old 08-12-2014, 02:13 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Ok I finally got imgburn to work. I Uninstalled the app. Then reinstalled it. Once I did that I added the certificate folder inside the BDMV folder. Then started the imgburn and all went well and it created the BD. I downloaded the torrent if that makes a difference and burned it to a 25gb BD.
bori is offline
Old 08-12-2014, 05:01 PM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
First of all thanks for the great effort for giving this treat to the forum members and everyone else. I really enjoyed the first one you uploaded.
My downloaded file is only 20.3gb I dont know what happened to the other 15.1gb
vikgrao is offline
Old 08-12-2014, 06:09 PM
Liked: 949
He means that he has continued to seed, like a good chap.
That's the whole point to a torrent.
pjvader likes this.
Old 08-12-2014, 06:20 PM
04rex's Avatar
Quoted: 105 Post(s)
Liked: 26
How can i urn this into an .ISO file for my media player to play directly?
04rex is offline
Old 08-12-2014, 06:58 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 61
landshark1 is offline
Old 08-12-2014, 07:22 PM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
Ha ha got it! I did not read properly lol!
pjvader likes this.
vikgrao is offline
Old 08-12-2014, 08:54 PM
termite's Avatar
Quoted: 133 Post(s)
Liked: 43
There's absolutely no need to do this.
There's no issue related to PAL/NTSC here. My player is NTSC only (US) and it plays just fine
as is.
termite is offline
Old 08-12-2014, 08:56 PM
termite's Avatar
Quoted: 133 Post(s)
Liked: 43
You can use ImgBurn to create an ISO also from the folders you download.
What's your media player? Can it hande 3D blu-ray ISO?
termite is offline
Old 08-12-2014, 09:50 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Really excited to sit down and watch this demo. 😃
bori is offline
Old 08-12-2014, 11:19 PM
thetifosi's Avatar
Liked: 0
those peeps with 3D issues, i suspect that a flag was set wrongly - and certain players detect this as a 2D media file. I have tried playing the m2ts and ISO directly on my Dune player to no avail but works well on TMT software on my PC.
anyone care to comment?
Old 08-13-2014, 12:17 AM
Quoted: 103 Post(s)
Liked: 92
I am going to give this one more shot using imgburn.
When I select a Folder, what exactly am I putting into Imgburn?
It won't let me select the BDMV folder itself.
It wants a particular file.
Thanks for the help.
Old 08-13-2014, 12:48 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
You can drag and drop the BDMV folder to the window. I made and added a certificate folder and put it in the BDMV folder. Not sure if that made a difference but it worked for me. I made 2 coasters prior to it working on the third try.
bori is offline
Old 08-13-2014, 01:13 AM
Quoted: 103 Post(s)
Liked: 92
Hi Bori!
Not allowing me to drag the folder into the window.
I am using Windows via Parallels on a Mac. However, that shouldn't make a difference.
