I purchased a new house with unfinished basement two years ago. Here is the floor plan which I designed and thinking about hiring someone to just do the frame work. This is going to be a long term project so I want to set up the foundation first and I can wire the audio/video myself later.
I would just like to know your thoughts and suggestions before my contractor start nailing them.
AV RACK is in under the staircase and the home theater is approximately 15 x 24. The squares are the speaker locations.
Why all the open doorways? You'll have a more consistent sound field without the openings.
Also, it looks like you've got the speakers backwards - not that you would actually wire the center channel into the rear wall, but isn't that what I see?
The speaker locations are tentative at this point. Haven't decided what I should do with audio system, 5.1, 7.1, 9.1 or Dolby Atom.
And about the open doorways, I didn't wanted to close completely but if you think it would be better to close it off, perhaps put the doors? What about the bar? Should I put a door there as well?
You should also consider what soundproofing measures you are interested in, because if you are interested the contractor needs to frame differently than normal practices. He may not even know how. The thecniques invlove isolated framing so that wall vibration doesn't shake the floor above.
I don't know if I have option to move the bar to different location because that is where rough-in drain pipe is located. I would like to have a sink in the bar. I'm not a plumber so I wouldn't know if it's optional.
BTW, I'm sending you PM. I live in Loudoun County and maybe you can help?
There are options for draining a wet bar sink that are independent of a pipe in the floor. Specifically you put a mini-sump pump under the sink hidden in the cabinet and then pump the gray water up the wall and over in the ceiling to another drain in the basement. Saw your PM I will send some info.
If you put the home-theater there, and a big open space on the top left side, you’ll still have a LOT of space for storage on the lower half, no reason to worry. Not sure if the two doors on the bottom left open to the outside, but if they do, even better. It’s a dream basement, really. Congrats.
put the bar next to the bathroom and share drains. a little concrete busting may be required (one day effort) . Locate the bathroom door facing the stairs, put storage where you were planning the bar.
Silva is right. Think long and hard about how you and your wife view this basement being used in the future. Think about how many people you would want to entertain in the theater at a given time. Think about what kind of viewing it would be (movies, gaming, superbowl, kids' sleepover, etc).
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
