Paint - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2014, 09:49 AM - Thread Starter
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Paint
Hello,
I am going to begin painting. I did a search and I getting all kinds of different suggestions from people. I am planning on grey primer and I am painting the ceiling black as well as the front wall. I will do the sides grey with grey carpet. I like the combination. Now I thought that most used flat black, but now I am seeing people say satin black. How about the sides, should they be satin also? Can I get some suggestions for a brand of black paint and what finish is indeed best. I have several paint stores here. Sherwin Williams and Duron are right here in town.
Reefdvr27 is offline
Old 07-29-2014, 11:56 AM
helmsman's Avatar
Quoted: 42 Post(s)
Liked: 32
I used flat black on my ceiling and screen wall, a different color in satin for walls. The problem with flat black is that it will show scuffs whenever you touch or rub up against it, but not an issue for a screen wall or ceiling. Quick cell phone picture attached but it doesn't show the ceiling. Not quite finished yet, still awaiting black speaker enclosure screens and movie poster acoustic panels for some wall treatment and decoration.
helmsman is offline
Old 07-29-2014, 12:15 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
Originally Posted by helmsman View Post
I used flat black on my ceiling and screen wall, a different color in satin for walls. The problem with satin black is that it will show scuffs whenever you touch or rub up against it, but not an issue for a screen wall or ceiling. Quick cell phone picture attached but it doesn't show the ceiling. Not quite finished yet, still awaiting black speaker enclosure screens and movie poster acoustic panels for some wall treatment and decoration.
My thought was flat black. I went over to Sherwin Williams and got some swatches of colors. They also suggested the flat. Theater looks great by the way.
Old 07-29-2014, 12:25 PM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
I used SW Tricorn Black in flat for my ceiling. Pretty happy with the results but I did do 3 full coats after the base dark primer. You can see the dark primer that I used on the left wall below the acoustic cotton.
As helmsman stated, the flat will smudge with about any touch and you really can't fix it (without repainting) so I would limit that to locations that most people won't reach. Satin is probably your next best bet for walls since it will be a lower sheen but not mark as easily as a flat paint would.
vanice is offline
Old 07-29-2014, 12:38 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
I actually took a swatch of Tricorn Black. Glad you chimed in as that is what I am probably going to go with. Did you use SW primer. The guy there suggested P6 ?
Old 07-29-2014, 12:52 PM
BllDo's Avatar
Quoted: 575 Post(s)
Liked: 373
Rosco Supersaturated Velour Black is often considered the deepest black you can get.
The blackest, most flat paint. Period.
Others have used Mouse Ears Black from big orange. I believe it is no longer a listed color, but you should be able to ask for it at the paint counter.
BllDo is offline
Old 07-29-2014, 01:10 PM
helmsman's Avatar
Quoted: 42 Post(s)
Liked: 32
Fixed my typo and yes, I meant that FLAT black scuffs easily.
I took a look at your build and noticed that you're using what appears to be 6 inch cans for your recessed lights. I also had 6 inch cutouts before my theater remodel but wanted to go with pinhole lights, so when I painted my ceiling flat black I found a black pinhole trim kit that converted my lights to pinholes (needed new/different bulbs, of course). I like the look so much better and it's far more dramatic for a theater, and works well with a black ceiling.
Here's the link: http://www.totalrecessedlighting.com...hole-trim.html - just a thought.
helmsman is offline
Old 07-29-2014, 01:29 PM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
Yes, I used SW primer. It was their basic drywall primer with as much black tint as they could do for me. I would assume P6 would be similar since it is their darkest gray tinted primer. Believe it or not the color on my walls is supposed to be gray. It looks more brown in person but I didn't care as long as it was dark since mine is getting covered up/painted over.
vanice is offline
Old 07-29-2014, 03:35 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
I read about this last year and forgot about it. Thanks for bringing it to my attention.
It all looks good. We are out there sanding now and hopefully I can start painting by tomorrow or Thursday. I was just laughing at the color I like and it is called Greyish :roll eyes: Who are these people that name these colors.
