Help with product name. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-29-2014, 09:23 AM - Thread Starter
joeybutts's Avatar
What is the name of this channel that is in the picture that is being used to build the soffit? I'd like to use it to build mine. I couldn't find anything like it at Lowe's/HD. Thanks!!
joeybutts is offline
post #2 of 6 Old 07-29-2014, 10:54 AM
Quoted: 3908 Post(s)
Liked: 3338
1 5/8 steel track, what you see I've found at Home depot in the steel studs section. Not my project but looks similar.
post #3 of 6 Old 07-29-2014, 03:29 PM - Thread Starter
joeybutts's Avatar
Thanks Big. I have a couple other HD's around, I'll have to check them out. This method looks great for building soffits.
post #4 of 6 Old 07-29-2014, 04:52 PM
Liked: 3338
print this out and take with you, If HD doesn't stock it in your location look for a local building supply company that specializes in drywall, they will have metal framing supplies and there is a high probability they will stock this item
http://www.cavobuilderssupplies.com/...inch-track.pdf
post #5 of 6 Old 07-30-2014, 09:45 AM - Thread Starter
joeybutts's Avatar
Thanks again Big. Yup, no luck at any of my HD/Lowes. only 3-5/8". I'll make some calls or see if they can order it.
post #6 of 6 Old 07-31-2014, 04:56 PM - Thread Starter
joeybutts's Avatar
Found a distributor who has it in stock for 2.75 a 10ft piece. Might get a chance tomorrow to pick it up! Thanks again Big!
