Advice on setting up my system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-01-2014, 09:40 AM - Thread Starter
Liked: 0
Hi,
I was wondering how would you set up my connection to get the best sound.
samsung UE46H7000 (taking the delivery in 2 days)
Samsung HWH751 soundbar(4.1 ch)
Sony blueray player(dual hdmi video/audio)
xbox one
virgin tivo
I can connect blueray, xbox and virgin to tv hdmi ports and run a hdmi arc to sound bar...does it give out 5.1 for all the devices connected to it via the soundbar ? i mean if the feed is also 5.1, not sure if xbox or virgin(sky movies) comes out in 5.1.......if it does come is the sound bar going to downgrade it to 4.1 ?
connection also available via bluetooth and toshlink , but dont they only output stereo ?
Doe it make a difference connecting blue ray to sound bar since my player got an extra hdmi ?
what about Connecting all the inputs to kinivo 510BN and then connect to soundbar ?
sorry am thinking too much here being a novice to sound.. could anyone guide me to the best set up pls answering my questions above..
Using less remotes will be handy too
thank you for your patience
strawsun1233 is offline
post #2 of 7 Old 08-01-2014, 11:23 AM
Crash11's Avatar
Quoted: 23 Post(s)
The Kinivo seems like your best bet. You'll need 5 hdmi cables. 3 for each of your devices into the Kinivo, 1 from the Kinivo to the audio in on the soundbar, and 1 from the audio out of the soundbar to the tv. The literature on the soundbar is kind of weak, but I'm assuming it has the hdmi out to pass through the video to a display.
If you don't use the Kinivo, you're talking about a lot of different cables and a lot of input switching. You'd basically choose whatever device you use the most, pass it through the soundbar with hdmi cables. Then the other devices would get hdmi cables run to the tv for video, and separate audio cables to the other 2 inputs on the soundbar. Everytime you switched a device you'd have to switch the input on the tv and the soundbar.
Crash11 is offline
post #3 of 7 Old 08-01-2014, 12:33 PM - Thread Starter
Liked: 0
Thank you for your prompt response Crash.
So Kinivo is the easiest option without much switching and 5.1 is coming via hdmi arc for all the devices connected including 3D +1080p ?
The only other port on soundbar is optical so the only changing needed is the hdmi port on tv if i directly connect all devices directly to the tv as you would connect the sound bar via optical. so if 5.1 comes of hdmi arc or optical what benefit is there using kinivo ?
Sorry just checking before I buy a kinivo ...
post #4 of 7 Old 08-01-2014, 12:55 PM
Crash11's Avatar
Quoted: 23 Post(s)
I'm not sure I understand what you mean? Are you suggesting you back-feed the audio from the tv to the soundbar?
Crash11 is offline
post #5 of 7 Old 08-01-2014, 01:41 PM - Thread Starter
Liked: 0
sorry..I am just trying to see the benefit of having a kinivo
soundbar ports : hdmi in, hdmi out and optical
TV ports : 4 hdmi and optical
so if I connect 3 devices( xbox, virgin and blue ray) to tv and use the hdmi arc to connect to sound bar...wont be I getting a 5.1 surround ?
if am getting roku as well I occupy 4 hdmi ports on tv, will I get 5.1 output connecting the optical between tv and soundbar ?
Above all how do I check if am getting stereo or surround on my 4.1 samsung sound bar ?
post #6 of 7 Old 08-01-2014, 02:32 PM
Crash11's Avatar
Quoted: 23 Post(s)
I'm not sure how you could test it, but I'm pretty sure you will not get any more than 2 channel audio from your tv. I actually dealt with this exact issue years back and ended up buying an AVR because I found out that tv manufacturers don't like to pay for the rights to output anything more than the 2 channels they already have attached to the tv itself. All of those stickers you see on devices that read "DTS-HD, TrueHD, Dolby Digital, etc" all cost money.
Crash11 is offline
post #7 of 7 Old 08-01-2014, 03:22 PM - Thread Starter
Liked: 0
Thank you, so it doesnt make a difference really..
so using Kinivo would be handy as it automatically switches to your powered hdmi device as opposed to directly connecting to tv and using remote to change the source ?
