10x13 room Theater Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-07-2014, 08:00 AM - Thread Starter
xmattxman's Avatar
I am buying a house soon and always wanted a home theater but the rooms in the house are on the small side. The room I would put it in is only 10x13. I was wondering if its at all possible to put a home theater in a room this size. What is the biggest screen I should get with such a small setup? What type of projector is good for a small room? I have about 1500 budget and I already have a surround sound system. I am new to this so any helpful tips would be greatly appreciated!
xmattxman is offline
post #2 of 4 Old 08-07-2014, 09:07 AM
krakhen's Avatar
Completely possible
Small Theater Build Threads
Dimensions are not multiples of a common number(good for acoustics). May be very difficult to accomodate two rows, but that will depend on size screen and personal preference. At almost 17' in length, I squeezed two rows with a 110" screen. Some find the front row too close, I don't... although I usually use the back row anyway(we are only three living in the house and there are 5 seats total).
Shouldn't need much power(lumens) in a small room but will also depend on light control and environment. I use an Optoma HD20, with a black shade on the window and dark walls.
__________
Krakhen
krakhen is offline
post #3 of 4 Old 08-07-2014, 09:29 AM - Thread Starter
xmattxman's Avatar
Originally Posted by krakhen View Post
Completely possible
Awesome thanks for the input. I will check out that thread!
post #4 of 4 Old 08-07-2014, 11:36 AM
Movie78's Avatar
Quoted: 857 Post(s)
Liked: 255
Check my build similar size.
Film noir theater
OLD SETUP:http://www.avsforum.com/forum/15-gen...r-theater.html
NEW SETUP: http://forum.kodi.tv/showthread.php?...856#pid2506856
LG 75UH8500 3D DOLBY VISION HDR | SONY 43 ANDROID TV HDR
XBOX ONE S UHD BLU-RAY | PS4 PRO 4K HDR GAMING
MARANTZ SR7011 DTS X | ATMOS 5.1.4 | Auro-3D 9.1
Movie78 is offline
