Running Cable Exterior Wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-14-2014, 09:29 PM - Thread Starter
wagsgt's Avatar
Hello,
Im trying to run a new outlet in exterior wall(side of house). This is on the second floor with access to the attic. I have done this on interiors,etc but never dealt with exterior walls.
I realize I will have to fight insulation but Im not sure where to drill from the top? It looks like drywall runs under the 2x4 . Are the studs against the vertical 2x4 and then come out another 1.5 on the one laying flat?
Thanks in advance.
wagsgt is online now
post #2 of 4 Old 08-15-2014, 05:05 AM
Quoted: 3823 Post(s)
Liked: 3258
When in doubt drill a really small hole and stick a straightened out coat hanger up through the ceiling. That will give you a reference point to measure from above and below. Then patch the hole and paint.
post #3 of 4 Old 08-15-2014, 03:42 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Or (from above) look for an existing hole where the power goes through.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 4 Old 08-16-2014, 01:29 PM
ctviggen's Avatar
Quoted: 119 Post(s)
Liked: 33
Your guess is probably pretty good. Big Mouth in DC has a good plan, though, as you can drill a very small hole and patch the drywall pretty easily. I'd say that if you drill within the 2 or so inches from the edge of 2x4 on the outside wall, you should hit the stud bay (and of course measure well so you don't hit a stud). Note that there are probably two 2x4s for a header, so you'll need to drill through 3 inches or so.
Bob
ctviggen is offline
