Can MIDDLE ATLANTIC AXS series racks be disassembled? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-29-2014, 03:50 AM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
I have just got my rack and it looks as though it won't fit through a section in the house and I have no square head bits to try and take it apart, so can MIDDLE ATLANTIC AXS series racks be disassembled?
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #2 of 7 Old 08-29-2014, 06:13 AM
jautor's Avatar
Quoted: 1332 Post(s)
Liked: 854
Did your dealer assemble it for you? The AXS come flat packed in pieces (top/bottom plate, side rails, etc.). But yes, the AXS comes apart. Look for the bolts in the top/bottom corners.
(and to be sure - the AXS series are the pull-out racks)
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 7 Old 08-29-2014, 07:22 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Jeff
+1
Like playing with Legos putting together.......suspect same taking apart.
doublewing11 is offline
post #4 of 7 Old 08-29-2014, 04:41 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
It came assembled from Middle Atlantic.
It is one of these. but it has solid sides, not open ones. To be sure it is a pull out rack and not a pull out swivel rack.
http://www.middleatlantic.com/produc...k-4425axs.aspx
It looks like this, but does not rotate.
http://www.middleatlantic.com/produc...ting-rack.aspx
My build thread
post #5 of 7 Old 08-30-2014, 08:44 AM
jautor's Avatar
Liked: 854
Oh, you mean the one with the steel enclosure... Different model, different story. The AXS rack itself can be disassembled, but the ERK enclosure (which I think is the model you have) is "Fully welded construction for strength"... Not going to come apart...
post #6 of 7 Old 08-30-2014, 11:35 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
I am in trouble. The sides are welded. Thanks for the help.
My build thread
post #7 of 7 Old 09-02-2014, 05:02 AM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
OK, I drilled the welds out and I am able to take the rack apart. Hopefully I will be able to get this thing to fit.
My build thread
