Theatre in a dome? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-16-1999, 05:53 AM - Thread Starter
TGroom's Avatar
Anybody know of any inherent problems with a home theatre in a dome? Accoustics, sound problems? It is still in the planning stage, but will incorporate a pool table, bar, and theatre. Probably along the lines of 26 to 28 foot diameter by 12 tall. It is concrete so will I have to use some sort of sound deadening to prevent sound from bouncing around. As you can tell I'm new to all this, but after reading this board for a while am greatly excited about it. Any and all commments appreciated. Will probably be going with a Sony 400q for now. We all know how the "upgrade" bug goes though. Thanks in advance.
TGroom is offline
post #2 of 2 Old 09-16-1999, 06:33 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
Both a dome or barreled ceiling can provide some very dramatic effects (whether in a theater of not). The real acoustic issue you need to tackle is the mathematics of the curvature of the ceiling. These types of ceilings will act as a lense. The "lense" effect can either serve to difuse the sound (good) or focus it on a listening position (horrible).
D. Erskine
DEsign Cinema Privee
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
Closed Thread Dedicated Theater Design & Construction
