Spray-on Expanding Foam Insulation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-15-2000, 01:55 PM - Thread Starter
haysdb's Avatar
I've read several posts about gluing drywall between the ceiling joists and even attaching sheets of lead to ductwork, but what about hiring an insulation contractor to spray expanding foam all over the underside of the floor and over the ductwork and everything before hanging rock on the ceiling? I would think this could be very effective, but...?
haysdb is offline
post #2 of 2 Old 02-15-2000, 07:43 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 101
It can be effective BUT you must use an open cell type foam. If not, it's not very effective at all.
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
Closed Thread Dedicated Theater Design & Construction
