Riser Frame construction ? - AVS | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By BIGmouthinDC
  • 1 Post By BIGmouthinDC
post #1 of 29 Old 10-11-2014, 03:50 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Question Riser Frame construction ?
Hi,
I'm building a riser for my second row. It will be 30 cm (1 foot) high, 120x220 cm (4x7feet).
I will be using OSB for top/side. It is not clear to me however what is the best design for the inner frame: should it be a closed box-like (including struts/beams on floor) or built like a chair with "legs". I do not mind wasting a bit of work/wood if it makes it more sturdy.
Does anyone has a drawing/picture of the inside frame of a raiser ??
doctorG4 is online now
post #2 of 29 Old 10-11-2014, 04:29 AM
Quoted: 1013 Post(s)
Liked: 968
first think of a deck hanging off the back of your house, build the frame just like that with long legs then cover it with a skin so you can't see under it. So to answer your question, Chair with legs, with exterior skirting to look like a closed box.
BIGmouthinDC is online now
post #3 of 29 Old 10-11-2014, 04:31 AM
Liked: 968
A riser that high is going need a railing. Are you sure 4ft deep is enough for your seating and an ample walkway? Got to say I've never seen a riser that high.
post #4 of 29 Old 10-11-2014, 04:50 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
The original post had incorrect unit conversion!! It was 1 foot not 3.
Thanks for the answer on the construction. The reason I asked if joists needed to be connected horizontally on the floor as well is exactly because it is indeed a high raiser so I think I need some stringer somewhere half height to give some torsion rigidity (maybe diagonal ?)
30 cm height comes from the calculator and simple geometry. The first row head height is 1.25 cm and the distance between two rows is 1.16 cm. I tried sitting on a chair and the riser height needed is correct to clearly see the screen. The size of the aisle is approx 50 cm which is OK with the chairs on floor.
I have plenty of this woolly glass fiber insulation material left over from walls. Should I also fill the raiser with it to avoid drum effect ?
Name:	Screen Shot 2014-10-11 at 13.37.49 .png
ID:	305458   Click image for larger version
Name:	2014-10-01 09.26.00.jpg
post #5 of 29 Old 10-11-2014, 09:39 AM
Liked: 968
for a foot high riser, I would build the perimeter out of 2x12s which are 11 1/4 inches tall. Think of building a sandbox just a perimeter box of the 2x12s. Then put 2x8s stringers spanning the short distance front to back simply hanging off the front and back 2x12. That should be strong enough but if it has too much spring add mid span supports, Cover the riser with two layers of 3/4 plywood or OSB board (Chip board)
Pictures from a foot high riser, I used 2x10 stringers but you can use 2x8s or 2x6s for your size riser.
ID:	305850   Click image for larger version
ID:	305858   Click image for larger version
ID:	305866   Click image for larger version
ID:	305874   Click image for larger version
mikela and doctorG4 like this.
post #6 of 29 Old 10-11-2014, 03:35 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Great thanks!
Is there any advantage building the raiser up to the back wall vs stopping immediately after the last row and leave a 40 cm/1.5 feet lane at normal floor height ?
Inviato dal mio iPhone utilizzando Tapatalk
post #7 of 29 Old 10-11-2014, 06:04 PM
Liked: 968
cleaning and safety.
doctorG4 likes this.
post #8 of 29 Old 10-11-2014, 09:14 PM
Bill97Z's Avatar
Quoted: 27 Post(s)
Where did you get that "fake" arm for your love seat?
Bill97Z is offline
post #9 of 29 Old 10-12-2014, 03:24 AM
Liked: 968
it is a feature of the Fusion line of seating. Rtheaters.com. RSH on the forum. It has a fin that slides down between the seats that holds it in position.
post #10 of 29 Old 10-12-2014, 03:39 AM
blah450's Avatar
Quoted: 81 Post(s)
Liked: 130
Of course, AWESOME finished HT, BIG.
Why the blocks attached mid-joist?
edit: never mind...i now see they extend down until flush with floor for additional support.
blah450 is offline
post #11 of 29 Old 10-12-2014, 09:35 AM
ctviggen's Avatar
Quoted: 37 Post(s)
Why the insulation but no way for sound to get into the riser? Or can sound get under the front?
Bob
ctviggen is offline
post #12 of 29 Old 10-13-2014, 01:36 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
The acoustic vibration will be transmitted anyway via the walls of the enclosure so the riser will resonate at drum frequencies, that is why insulation will dampen it and reduce internal resonances. Of course if there were holes in the riser that will make it more effective to "capture" and dampen the sound (mostly low freq).
In my case I'm not so in favour of punching holes in the riser, I'm not convinced that the effectiveness of riser as bass trap outweight the hassle of making the holes, put nice grill/acoustic fabric on it etc but I might be wrong here..
post #13 of 29 Old 10-13-2014, 05:16 AM
Liked: 968
they just don't show in my pictures
post #14 of 29 Old 10-14-2014, 12:47 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
OK. Thanks to all comments. I have started the construction...:-)
Regarding bass trapping should I really do something for this (i.e. holes somewhere)
or is my plan to simply fill it all with insulation enough ?
Name:	2014-10-14 08.20.48.jpg
ID:	310762   Click image for larger version
Name:	2014-10-14 08.21.11.jpg
ID:	310770   Click image for larger version
Name:	2014-10-14 08.21.26.jpg
post #15 of 29 Old 10-14-2014, 08:11 AM
rprice54's Avatar
Quoted: 81 Post(s)
Liked: 43
starting my riser this week, I'll tag along for the ride. I like the 2x12s with 2x8 stringers idea for my 14'x7' riser.
rprice54 is offline
post #16 of 29 Old 10-15-2014, 01:19 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Question Riser: work in progress
OK here the frame completed.
I'm still missing reinforcements on the place where I will screw in my cinema chairs.
Can Jeff or anybody comment on how to make holes and cover them for making a bass trap ? Which size ? which position ?
Name:	2014-10-15 09.11.52.jpg
post #17 of 29 Old 10-15-2014, 05:21 AM
Liked: 968
There are two schools of thought on the holes. One is to place them at the wall riser instersections. The other is on the front face. The wall riser placement ususally uses 4x36 or 4x48 inch grills. The calculations of size and whether you have the required volume is something beyond my training.
post #18 of 29 Old 10-15-2014, 07:20 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
I found in meanwhile tons of posts (sic!) regarding how to turn a riser in a bass trap which have been interesting to read with fanatic followers armed with acustic spectrum analysers and so....;-)
(see Riser Bass Trap, not against walls)
Anyway 2 basic methods:
A) Helmholz Resonator (complicate as it needs to be tuned to specific frequencies with same kind of calculations like is done when building a loudspeaker). I discarded investigating this as results from forum all seemed bot complicate and ineffective.
B) Broad band absorbers, working of principle to dampen (i.e. not reflect) any inpinging acoustic (bass) wave, basically a big box full of suitable absorbers (glasswool or similar) with holes. Also here there is alot of theory, but basically the space under the raiser should not be partitioned but open to allow the absorber to do its work.
With my frame design (which is open with horizontal and vertical struts, the only thing I have to do is to put grating. It has been suggested to use aluminium HVAC ones which indeed can be found for good price, so I will put 2-3 in front and 2-3 on the back (on the floor). Which also has the side benefit to allow me to access some electrical socket that happens to be there should I need it.
Doing it is cheap, if it does work good, otherwise not a big deal.
post #19 of 29 Old 10-15-2014, 07:42 AM
rprice54's Avatar
Quoted: 81 Post(s)
Liked: 43
Wouldn't carpet be considered acoustically transparent- it passes the breath test. I'm wondering if I shouldn't cut holes in the platform and face, but then just install carpet over said holes. I would have to make sure they don't put pad over those holes. It would be a cleaner look as opposed to a bunch of AC register vents. I could take my 4" hole saw and go along the perimeter of the platform against the walls.
Thoughts?
rprice54 is offline
post #20 of 29 Old 10-15-2014, 11:30 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
I have read of others doing exactly that. Simple circular holes 10 cm diameter. It would indeed be simpler...
post #21 of 29 Old 10-16-2014, 01:27 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Last night I cut the OSB boards for the top to check the position of the seats stands so I can put a reinforcement underneath and while I wait for dust to settle on best approach for holes to build a bass trap.
Name:	2014-10-16 08.52.57.jpg
ID:	314434   Click image for larger version
Name:	2014-10-16 08.52.40.jpg
post #22 of 29 Old 10-16-2014, 05:55 AM
Liked: 968
One ticket for seat 12 please.
post #23 of 29 Old 10-18-2014, 02:50 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Not yet..:-)
post #24 of 29 Old 10-18-2014, 02:52 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Completed the sides.. The making of the step proves not to be trivial...thinking...
post #25 of 29 Old 03-10-2015, 01:14 AM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Now that I completed my soffits and the installation of Atmos speaker on ceiling I'm back to my riser...
I decided to put some vents on the back side (against the wall) some 3 times 10x30 cm and to open circular holes 10cm diameter on the front side. This should allow basses to get into the riser and be absorbed by the glassfiber/rockfiber filling. I do not know how effective will be but In any case it will at least avoid the raiser becoming a resonating drum.
post #26 of 29 Old 03-15-2015, 04:29 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Today big progress, opening and grids done, filled with glasswool/rockwool done....
ID:	604505Click image for larger version
ID:	604513Click image for larger version
post #27 of 29 Old 03-15-2015, 04:31 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Forgot the photo of the grids near the back wall
post #28 of 29 Old 05-02-2015, 01:24 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Completed the top and carpet being place on the riser. Working slowly but progressing..
.Click image for larger version
post #29 of 29 Unread Today, 03:51 PM - Thread Starter
doctorG4's Avatar
Quoted: 18 Post(s)
Carpet layed on the floor and surround speaker mounted.
To be continued..
