Screen hanging question - AVS Forum
 3Likes
  • 1 Post By Mr.Tim
  • 2 Post By BIGmouthinDC
post #1 of 4 Old 11-20-2014, 04:09 PM - Thread Starter
emanymton123's Avatar
Hi,
I'm starting to put together a small home theater and am trying to figure out the best way of putting in the screen I want. See attached diagram.
I'm planning to install a 105 inch wide 16:9 AT screen in front of a 10 foot wide wall. There's a window in the middle 4 feet off the floor that I have blacked out. The trouble is that there is a door off to the side that limits the distance between the screen and the wall to 12 inches. Once I attach the speakers to the wall, that gap becomes 8.5 inches.
Does this plan make sense? If it does, what's the best way of hanging a screen 12 inches away from the wall?
Name:	theater drawing.png
emanymton123 is offline
post #2 of 4 Old 11-21-2014, 04:45 AM
Mr.Tim's Avatar
Quoted: 38 Post(s)
Liked: 70
Typical goal post design should work fine. Try searching this forum for "goal post".
Tim
emanymton123 likes this.
Mr.Tim is offline
post #3 of 4 Old 11-21-2014, 07:04 AM
Quoted: 591 Post(s)
Liked: 746
BIGmouthinDC is online now
post #4 of 4 Old 11-21-2014, 09:34 AM - Thread Starter
Looks like the perfect solution, thanks for the assist.
