Great White North HT Build - Pioneer Peak - AVS | Home Theater Discussions And Reviews
post #1 of 17 Old 12-01-2014, 04:41 PM - Thread Starter
sirjaymz's Avatar
Pioneer Peak Pictures
First of all, I would like to extend a HUGE Thank You! to the leaders of AVS forums for all the inspiration and knowledge you have shared. BigMouthDC!, Cinemar, Dennis Erskine, and the rest. Without you all, i would definitely would not have had the ideas to do what i am doing. Thank you!
Second, Life happens. We all have grande ideas of what we would like to see in our own rooms. Time and Money. that's what it takes. Devotion of every day going in and making it happen when you are a one person show, with outside help every now and then, and of course, the wife, kids, the dreaded work obligation, snow shoveling, and fun. Hang in there.
This is my 3rd year building, this being an on again and off again project. I had to build a shed, build a 24 x 32' addition at the parents house. Remodel a rental property, and finally have found time in the recent past to devote to the HT effort i began 3 years ago, and pretty much moth balled the HT until recently. I still read all the forums though. That has inspired me to pick it up again, that, and a little money in hand.
Started in 2011. cleared the room. built a riser. then thought, "I should do some research... "... and some more.. and some more... and...and...
So here goes.
Did a layout of stuff about 10 times. still need to update as of 12-1-2014.
ill post from the beginning and where i'm at as of now.
Name:	Media Room December-1-2014.jpg
ID:	396042   Click image for larger version
ID:	396082   Click image for larger version
ID:	396090   Click image for larger version
ID:	396098   Click image for larger version
ID:	396114   Click image for larger version
ID:	396130   Click image for larger version
ID:	396138   Click image for larger version
Denon AVR-X7200W
Klipsch RC-64II - Klipsch RF-82II - Klipsch RS-41
Klipsch R-112SW - Klipsch CDT-3650-CII - Emotiva UPA-700 - Klipsch CDT-3650-CII
Pending Purchase 4k TV- Sony XBR-79X900B or a Samsung UN85HU8550FXZA
My HT Build
sirjaymz is online now
post #2 of 17 Old 12-01-2014, 05:36 PM - Thread Starter
sirjaymz's Avatar
Front Wall
I have changed directions on the display. I was originally going with the 106" multi-format screen from monoprice along with a Epson 3050, or similar, with having a 50" Samsung Plasma as the daily watcher on a movable cart in front, or using the soffit as a swing down screen. All that got nixed.
The wife was not going to have a 50" screen in front, with a 106" screen in the back, just sitting there not getting used.
So, I am now looking at one of the 2 displays in my signature.
Bout more about the wall preparation...
I am planning to build a 2x4 wall flush against the existing wall, and put CO Safe40 in the main cavities. have a large piece of plywood to attach the mount to, approxmate 36" x 48".
this allows me to run the cables, hdmi, speaker, network, etc, in the soffit and then down to the TV and speaker locations.
then i was going to attach a layer of 1" linacoustic, and then cover with the GPower frames with additional linacoustic in those.
Assistance: Are there other suggestions that i should be doing? i was not planning on drywalling the front wall at this point.
Side walls / angles
planning on Gpower frames for the most part on all slants and main reflection walls.
in the alcove, i am planning on a diffuser on the back wall, and a gpowers panel on the frontwall, paint on the window side.
Stage
double layer of 2x6 construction, construction adhesive between both vertical layers of 2x6 to add tightness. i had already purchased and cut the 2x6's prior to actually reading how Big MouthDC builds them. Could not justify rebuiling, or throwing away the wood. tried to follow Bigs and Dennis' build designs to the best i could.
felt on the bottom
Stage is filled with insulation
screwed and glued to framing.
waiting on GG before adding second layer of 19/32" plywood.
was not going to do a 3rd layer.
Riser
Same build method as stage.
Any other thoughts i should be doing? please advise.
Additionally, i'll add more photos of my build process thus far.
ID:	396186   Click image for larger version
ID:	396202   Click image for larger version
Denon AVR-X7200W
My HT Build
post #3 of 17 Old 12-01-2014, 06:34 PM - Thread Starter
sirjaymz's Avatar
Following the Cinemar build info, here's my version of info.
SEATING
* FRONT ROW: 3 Curved Klausner Black Leather Motorized Recliners
* BACK ROW: Pending
SPEAKERS
* CENTER: Klipsch RC-64 II
* FRONT LEFT/RIGHT: Klipsch RF-82 II
* FRONT WIDE LEFT/RIGHT: Klipsch RS-41
* SURROUND LEFT/RIGHT: Klipsch RS-41
* SURROUND BACK LEFT/RIGHT: Klipsch RS-41---UPDATE 12-6-2014: Upgraded to Klipsch RS-42 II when picking up the gear.
* SUB1: Klipsch R112SW
* SUB2: Klipsch R112SW
* ATMOS TFR: Klipsch CDT-3650-CII
* ATMOS TFL: Klipsch CDT-3650-CII
* ATMOS TRR: Klipsch CDT-3650-CII
* ATMOS TRL: Klipsch CDT-3650-CII
ROOM DIMENSIONS & MEASUREMENTS
* IN the RAW 28' Deep x 22'3" Wide at Largest measurements.
* SLANTS OF CEILING/WALL PROHIBIT USAGE OF ~25% of the room.
* Front Row: ~13'0" from Front of Seat to screen
* Back Row: ~18'0" from Front of Seat to screen
EQUIPMENT
* RECEIVER: Denon AVR-X5200W
* AMP: Emotiva UPA-700
* BLU-RAY PLAYER: Pending
* GAMING: PS3
* POWER CONDITIONER: Pending
* STORAGE: Synology DS1813+ (8x2TB, RAID5)
* TV: Pending Purchase 4k TV- Sony XBR-79X900B or a Samsung UN85HU8550FXZA
* TABLET/iPAD/PHONE USER INTERFACE: iRule
* REMOTE CONTROL: Pending Purchase Harmony Something, must be "Wife Friendly"
* LIGHTING CONTROL: Insteon
* THERMOSTAT CONTROL: Proliphix NT-20E Thermostat
CARPETING
* Pending Purchase from Carpet World
FABRIC & PAINT
* Paint - Sherwin Williams 7673 Pewter Cast and Sherwin Williams 7647 Crushed Ice.
* Wall Frames - Accent Color TBD
* Wall Frames - FR701 GOM Style 2100 (#408) Black Fabric
* All soffit and ceiling panels will be covered with GOM once color is choosen.
SOUND PROOFING
The room is above a 3 car garage and on the far side of the house. Most walls will be treated with minimum 1" linaccoustic with GPower Frames.
Front wall and rack closet and bar wall all Roxul insulation inside.
stage and riser full insulated with R-21 per Erskines designs. second floor prohibits sand in stage.
PAINTED STAR CEILING
* I wish...
VIRTUAL MOVIE POSTER
* A 32" LED TV mounted in Portrait displays the Cover Art of the currently movies along with statistics like: Number of Movies watched in theater, Minutes remaining of playing movies, movies coming soon. This came from meyer64 on AVS forums.
D-BOX MOTION PLATFORM
Not to be installed, but conduit installed for front row when price is more affordable.
Denon AVR-X7200W
My HT Build
Last edited by sirjaymz; 12-08-2014 at 12:46 PM. Reason: Updated the gear while picking it up.
post #4 of 17 Old 12-02-2014, 05:56 AM
rms8's Avatar
Quoted: 141 Post(s)
Liked: 63
Shaping up to be a very nice build!!! Bet your so excited it's moving forward now!
## DIY Rustic ConcreteBunker HT Build w/8 x 18" IB subs & 25KW ##
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
Supercharged 10 second II
rms8 is online now
post #5 of 17 Old 12-02-2014, 09:41 AM - Thread Starter
sirjaymz's Avatar
Yes, i am very much so. I bought most of the gear in the last 45 days and all of it's coming in... there doesn't seem to be as many hours in the day to get this done faster.
Denon AVR-X7200W
My HT Build
post #6 of 17 Old 12-02-2014, 05:13 PM - Thread Starter
sirjaymz's Avatar
For those of you wondering why i call the theater Pioneer Peak Pictures in The Great White North.
I live up here in Alaska and it's typically white, aka allot of snow.
Pioneer Peak is out my back door.
http://postimg.org/gallery/ovk0w2c6/
Denon AVR-X7200W
My HT Build
post #7 of 17 Old 12-03-2014, 01:50 AM
Silva741's Avatar
Quoted: 43 Post(s)
Liked: 32
Wow, that's a beautiful view! I hate cold weather, but for such a sight it's almost worth it.
The room looks promising, congrats. Having the first row at 13' is a bit more than most builds here, but since it's not a projector and a fully dedicate theater it makes sense.
Silva741 is offline
post #8 of 17 Old 12-03-2014, 06:04 AM
empirebuilder's Avatar
Looks like a great plan and a great start. If I am reading correctly you are designing to use the new Atmos system so I am very interested to see what you think of it once more Atmos movies come out.
empirebuilder is offline
post #9 of 17 Old 12-03-2014, 06:28 AM
rms8's Avatar
Quoted: 141 Post(s)
Liked: 63
That is a speechless view!
rms8 is online now
post #10 of 17 Old 12-04-2014, 12:32 AM - Thread Starter
sirjaymz's Avatar
I will share what ever I can gleam of feedback.
Atmos seems to be pretty nice overall for the immersion aspect. I just wish receivers had more than a .4 support, not that my space could handle that, but always want to see a little more I guess.
The reference system at the front of the Dolby Atmos guide seems to show a rather large system, aka commercial.
What about the HT that say have a 3rd row seating that would need a little more processing for front,middle, and rear?
I guess we will see overtime between Atmos and Auro3d as far as adoption.
Denon AVR-X7200W
My HT Build
post #11 of 17 Old 12-04-2014, 12:49 AM - Thread Starter
sirjaymz's Avatar
Received the box of GG today. I was hoping to finish the riser, then move back to working on the stage with th GG and the second layer, of plywood but just ran out of time.
What was Completed today.
1st layer completed and bass trap ports cut. 2nd layer of plywood all cut to shape on the riser and the edges were routered. Now I have to pull off all the plywood again and mark the bass trap ports and cut them out on the second layer only.
Back at it tomorrow after work. Hopefully the commute home isn't 90 minutes again. Summer time is only 50 minutes door to door.
Denon AVR-X7200W
My HT Build
post #12 of 17 Old 12-05-2014, 11:50 AM - Thread Starter
sirjaymz's Avatar
Well.. worked on pulling off all the layers of plywood to cut the top layer venting into it. Dennis E. i think says to use the 4x10" vents, however, i used 2x10" vents for the much smaller riser than his traditional bass trap riser designs are.
I am not sure how to go about recalculating the frequency response on this now, but i think it will be more broad spectrum based on what i have been reading.
Additionally, we have all the colors samples. Stopped at Carpet World to get new samples of carpet, as Home Depot stopped carrying the original selection we had chose.
I ended up getting 21 different GOM samples. all within the color pallet we have choosen.
We narrowed it down to a handful of choices, but, still becomes a difficult choice. I have a new respect for those that have a minds eye to coordinate all of these types of colors and actually make it look good on some of the DIY shows you watch. At least my daughter and I had a good time selecting all the choices.
Also received the "step lights" from amazon. Royal pacific lights. suppose to be able to fit in the 1-gang electrical box(8905WH), however, what they sent were the much larger "step lights" (8904SL LED). i was kinda shock on how i was going to fit this light in. oh well.. guess i'll send them back and have them ship me what i ordered..
Denon AVR-X7200W
My HT Build
post #13 of 17 Old 12-06-2014, 01:57 PM
Jacob B's Avatar
Quoted: 35 Post(s)
I know all about delays and having to do other projects in the house. I just restarted after a four year break :-)
I will follow your thread, since you are doing some of the same things as I am doing, like bass trap in riser and Atmos.
I envy you on the GOM color picking process - mine was so rushed since I was moving back to Denmark from Alabama and wanted to order enough GOM for the project before my container was shipped... I ended up having Bryan Pape pick them for me, based on my two requirements of dark (for picture quality) and classic. I now have a roll of burgundy and a roll of black. It will work, but I might have picked something else after spending 100+ hours more on avsforum :-D
Cheers,
Jacob
Jacob B is online now
post #14 of 17 Old 12-07-2014, 11:52 AM - Thread Starter
sirjaymz's Avatar
Very productive day yesterday.
My wife and I finished the riser and the stage yesterday with the GG and top layer of plywood. Green checks on the project list is always a win.
Then we moved onto painting the front wall and the 2x4"'s. Not that we expect to see any of this wood once the front wall is completed, however, if something happens to show through, I didn't want any raw colored wood appearing. Plus it has an appealing affect when it's all black on what the final product is going to look like anyway.
Had to wait for paint to dry. So we decided to head to Image Audio, the local electronic dealer, and happens to be the company I bought amost of all my speaker gear from. Needed to get a mount for the new TV. Wanted to have that in hand.
The guy I was working with for the last 3 months was gone. So at that point, I wanted to pick up all my gear, definitely did not want them to lose sight of that.
So what great moment it was.
Such a thing of beauty!
Upgraded the surround back left and right to RS-42's. Better balance with 5.1 content I'm thinking.
I got the OK to move it in the bedroom. I quickly did that before she saw the wall of speakers, and changed her mind.
thrak76 likes this.
Denon AVR-X7200W
My HT Build
post #15 of 17 Old 02-06-2015, 11:41 AM - Thread Starter
sirjaymz's Avatar
x7200W was ordered it this past Monday. 5 benjamins off normal price.
pulled in 4 sets of wires for LCR and Sub#1 to the front, along with 3 HDMI cables. Wanted to make sure i had enough connectivity to the screen for different direct inputs, though most content will run through the new x7200w.
construction of the frames has started. using both types. some of the trickier ones around outlets and in the odd shapes will be made with the GPowers design and the others that are just standard rectangles will be the speed frames. or at least thats the plan.
going to be pulling in more of the speaker wires this weekend, and hopefully should get some additional photos up.
Denon AVR-X7200W
My HT Build
post #16 of 17 Old Today, 11:57 AM - Thread Starter
sirjaymz's Avatar
Received the x7200W on Friday 2-20. Yay. only took 3 weeks, but worth the wait.
Continued the build of the front wall. working with on the slanted wall for the stage. difficult at best with a compound angle in the x,y,z axis. what a PITA. went a bought a new saw because of it. old saw had better days and it was time for a new one. Dewalt DW717. lacking some bells and whistles, but a solid saw overall. nice a smooth on the cuts.
Slow going on the progress, but GOM is also on order, so that will allow for others to assist with putting together the acoustic panels when the GOM arrives.
every other room in the house has something that goes into the media room at this point, so it's getting cluttered and definitely starting to visually see the end room in site.
Denon AVR-X7200W
My HT Build
post #17 of 17 Unread Today, 04:31 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3404 Post(s)
Liked: 1158
NorthSky is online now
Gear in this thread - XBR-79X900B by PriceGrabber.com
