what to do with speaker wire? - AVS Forum
post #1 of 4 Old Today, 12:03 PM - Thread Starter
j4str's Avatar
Im not sure what i should do with my speaker wire that is ran in the walls for my 5.1 speaker system. The speakers will be small and surface mounted. Maybe something similar to this:
Should i put them in to a single gang plastic box and plan on putting a plate on it like this:
should i just stub them out of the wall? Is there a better way that im not knowing about?
j4str is online now
post #2 of 4 Old Today, 12:23 PM
oman321's Avatar
Quoted: 36 Post(s)
Liked: 39
Depends how much of a perfectionist you are. You can do the plates as you show or simply pull thru a small hole which you can either patch or caulk. At the other end where all the wires come back to the receiver you can use a bulk cable wall plate or a multi speaker wire plate as well.
http://www.monoprice.com/Product?c_i...seq=1&format=2
or if you need power as well.
or if you want the speaker terminal type.
oman321 is online now
post #3 of 4 Old Today, 12:39 PM
Swervepf's Avatar
or even cheaper, coil some slack in the wire into an electrical box, put a coax blank plate (without the actual connector on it) on the wall, and pull as much speaker wire out as needed to reach the speaker. Minimalist, direct connection between amp and speaker, easy, cheap, etc
Swervepf is online now
post #4 of 4 Old Today, 12:42 PM
Glimmie's Avatar
Quoted: 185 Post(s)
Liked: 253
Looks a lot cleaner than a jack/plug set too IMO.
Glimmie's HT Page
Being redone - comming soon!
Glimmie is online now
