Dedicated vs Open theater room - AVS Forum
Old 12-22-2014, 11:10 AM - Thread Starter
BADASS03SVT's Avatar
I have this in the other section too but wanted the dedicated theater guys opinions on space I have and light problems. Here is a video of my basement form last week
the kitchen is now gone and the middle wall is just about gone making it a complete open basement. Here is a sketch of what I will have for dimensions. Im guessing either way (open or closed room) I'm going to have to remove a window or two. Id really like something 100"+ as i have a 75" TV in the living room upstairs.
Jake
BADASS03SVT is offline
Old 12-26-2014, 07:35 PM
Tedd's Avatar
Quoted: 153 Post(s)
Liked: 83
What's the layout of the bath room? Could the door be moved over?
If so, then you could create an aisle space outside of the columns (assuming that is what they are).
So you could have a dedicated room that is about 13' wide by 22.5' long. And you could employ an
acoustically transparent screen to accommodate a large screen.
Tedd is online now
Old 12-26-2014, 08:23 PM - Thread Starter
door cannot be moved
Jake
Old 12-26-2014, 08:27 PM
Tedd's Avatar
Quoted: 153 Post(s)
Liked: 83
Ok.
Then something along these lines perhaps?
Name:	dedicated theater.jpg
Tedd is online now
Old 12-26-2014, 08:41 PM - Thread Starter
Ok.
maybe I should have put the staircase.....woops. Lower right is the stairs into the basement from the 1st floor
Jake
Old Yesterday, 05:09 AM
Tedd's Avatar
Quoted: 153 Post(s)
Liked: 83
Well that just doesn't work.....
So what is on the other side of the south wall? More information
beyond the room itself, sometimes is helpful with relocating an entry,
or reworking circulation space.
And what is your seating wants and your seating needs?
And while I am at it, how tall is the room? And is there any restricted
headroom due to ductwork or other obstacles?
Tedd is online now
Old Yesterday, 05:51 AM
Tedd's Avatar
Quoted: 153 Post(s)
Liked: 83
Could you see yourself with a high performance four seat room?
A baffle wall and scope AT screen wouldn't eat up much room depth,
and could be the basis for a high output sound system, in the smaller space.
Of course you could widen the space, and/or rotate it ninety degrees, but I was
trying to keep the second sliding door. Another thought is to remove the sliding
door and take 3-4' of width, and then install a window.
And then there's a "remove the sliding door and plug the windows" monster version.
Not sure how deep that space is, though.
Name:	4 seat dedicated.jpg
ID:	443706   Click image for larger version
Name:	larger and wider.jpg
ID:	443714   Click image for larger version
Name:	taking over much of the space.jpg
Tedd is online now
Old Yesterday, 07:55 AM - Thread Starter
this is why I wanted to post in here. I didn't realize the options I would have and that you really needed to see EVERYTHING to get a good idea of what to do. Let me do a full basement layout as the utilities are down there also behind that south wall.
Jake
Old Yesterday, 08:28 PM
mtbdudex's Avatar
Quoted: 77 Post(s)
Liked: 327
What are you trying to accomplish?
A sporting/party room with a bar?
Or a dedicated HT space, with soundproofing and appropriate acoustic treatments to give you a subperb cinema experience at home?
I say this because back in 2007 I was all set to go to a dedicated HT space, then went to a friends home and he had a huge basement sporting/party room with a bar and HT in a open corner.
I decided to have a 6 foot door opening to my rec room, that was 2008 thru now,
I'm just now going to a 4 foot door because we do like the sporting/party room for big events and rest of the time the dedicated HT we desire to better contain the sound, both lower noise floor inside and less sound coming up stairs.
mtbdudex is online now
Old Today, 09:19 AM - Thread Starter
I think there is enough room for both and over the last few days looking at HT setups on here Im leaning towards the dedicated setup. There is working plubing down there which I don't mind plugging up but could be useful. I also have a pool table in another part of the house I'd like to put down there. Here is a complete layout of the basement floor. Where the posts are there is a beam the whole length of the basement. Right now the closet hides 1 post and the beam in that part. But between the closet and the bathroom the beam is hanging down form the ceiling. Ceiling is 7.5' and the beam hangs down 11"
Jake
Old Today, 09:22 AM - Thread Starter
the 2nd and 3rd images that Tedd posted is what I first had in mind for the space but was looking at every option. Do i have the space for 2 rows and a riser? How about 2 rows and a sit bar in the back? Thats all Im really unsure on i guess.
Jake
Old Today, 09:35 AM
ctviggen's Avatar
Quoted: 21 Post(s)
What software are you using to make these pictures?
Bob
ctviggen is offline
Old Today, 10:02 AM - Thread Starter
did a google search and found a couple online. Thats Homestyler
Jake
Old Today, 07:13 PM
Tedd's Avatar
Quoted: 153 Post(s)
Liked: 83
relocate the water?
Tedd is online now
