Radical Flooring suggestions - AVS | Home Theater Discussions And Reviews
post #1 of 9 Old 01-18-2015, 06:25 AM - Thread Starter
sschantz's Avatar
Love going thru this thread and seeing everyone's great designs/theaters..
Right now have a simplistic home theater in the basement and will be upgrading this year. My main problem is flooring.
Have carpet now but during spring and summer, very musty (no a/c but have dehumidifier) as carpet absorbs the musty-ness. So first and foremost, time to replace the carpet It is uneven so hardwood/laminate is out of the picture.
Wife wants to do a painted floor, like you do in a garage with the sprinkled in flecs as I feel this is too sanitary and cold during winter months.
I was thinking gym flooring, those rubber mats that interlock, nice and cushy on the feet.
Long story short, anyone have something "radical" on their floor.
Make it a Great Day,
Shawn
Epson 8350
Carada 96' Screen
Onkyo 609
Sony BDP350
Polk CS1 Center channel
Polk Monitor 60
(4) Yamaha Satellite
Yamaha and Sony Subs
sschantz is online now
post #2 of 9 Old 01-18-2015, 07:44 AM
Tedd's Avatar
Quoted: 188 Post(s)
Liked: 96
Any minor leaks in the basement?
Seal the floor and do a Dricore subfloor perhaps?
Tedd is offline
post #3 of 9 Old 01-18-2015, 07:25 PM - Thread Starter
sschantz's Avatar
Appreciate the insight. No moisture to my knowledge. House is 25 yrs old. Carpet was changed in 06. Again just musty.
Going to try and steam clean with vinegar which was recommended by a few sites but thinking long term
post #4 of 9 Old 01-19-2015, 10:02 AM
SebaGuerrero's Avatar
Liked: 0
Interesting Italian material
Hello Shawn,
I live on a house 120 years old that was constructed on a swamp. The engine that did it left a 50 cm air gap between foundation and basement floor, so we still have humidity coming up but it dries completely after 2 to 3 days. All the architects that I consulted wanted to do a completely new floor, but I disagree, since this is working well for 120y.
The I found this material from Geoplast in Italy. It's called Mini modulo. It something like the DRIcore subflorring but the advantage on my opinion is that they just provide de plastic mushrooms.
50X50 cm plastic tiles with a mushroom format that will leave either a 3, 6 or 9cm gap between your floor and the mini modulo. You'll also need a chimney pointing to the south and other to the north, connected to the gap between floor and mini modulo. The system works by difference on air pressure, so humid air is push out by one chimney wile it sucks fresh air from outside on the other one.
After this you do a new flooring as normal:
Contret - 2 to 3 cm
Vapour barrier - just a plastic sheet to avoid any humidity to come up.
Insulation
OSB - (Oriented Strand Board)
New flooring
This is the link to the material, I just don't know if it's available on the US.
geoplast . it and look for mini modulo. I still cannot post links....sorry
Cheers,
Sebastian
SebaGuerrero is offline
post #5 of 9 Old 01-19-2015, 10:15 AM
scraejtp's Avatar
Quoted: 13 Post(s)
Moving from carpet to hard concrete. Sound issues and comfort will seem to be an issue.
I don't have a lot of experience, but cork flooring may be worth looking at.
scraejtp is offline
post #6 of 9 Old 01-19-2015, 11:31 AM
BasementHT5's Avatar
Stained concrete
You can do a stained concrete to make it colorful and then throw down some large area rugs.
http://etchedinstonedesigns.com/Stained_Concrete.html
Here's some examples.
Gear: Visio 70" M701d-A3R LED TV | Onkyo TX-SR606 | Sony BDPS5100 (blu ray) | SONY PS3 | Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk RC65i (L/R rear Surround) | Polk RC80i (L/R Surround) | SVS PB-2000 (Subwoofer)
BasementHT5 is offline
post #7 of 9 Old 01-23-2015, 10:26 PM
JohnstownFlood's Avatar
Quoted: 21 Post(s)
I'm going to be taking the DRICore, then pad and carpet route. The "musty-ness" you describe is the moisture coming up from the concrete slab floor. The DRICore will act as a barrier for the vapor, and add an R value of insulation.
Since you asked for "radical," I've seen the OSB top of the DRICore stained and poly'd and that was the first thing that came to mind. For a home theater though, I'd definitely recommend throwing a pad and carpet on top for sound...although I know that isn't very radical.
JohnstownFlood is online now
post #8 of 9 Old Yesterday, 09:28 AM
eikon's Avatar
Quoted: 14 Post(s)
if you have moisture problems from the floor isn't it a bad idea to put dri-core over the top? Won't you trap a ton of moisture under the subfloor and get massive mold under there? Maybe it's ok though since it's trapped underneath?
eikon is offline
post #9 of 9 Unread Today, 05:55 AM - Thread Starter
sschantz's Avatar
All great recommendations, thank you!
Shawn
Epson 8350
Carada 96' Screen
Onkyo 609
Sony BDP350
Polk Monitor 60
