Rustic Theater & Basement Build - AVS | Home Theater Discussions And Reviews
post #1 of 4 Unread Today, 07:43 AM - Thread Starter
mt0trip's Avatar
Starting our theater and basement finish today. Bought the start of all our supplies today going to be fun. Hoping the theater and theme of basement looks similar to this.
mt0trip is offline
post #2 of 4 Unread Today, 07:51 AM - Thread Starter
mt0trip's Avatar
I guess my first question, roofing felt under the riser and stage? This will be going over concrete. I didn't buy PT wood. Should I put down a layer of roofing felt?
mt0trip is offline
post #3 of 4 Unread Today, 05:26 PM
doublewing11's Avatar
Quoted: 108 Post(s)
Liked: 353
Good luck......
If your room turns out close to attached render, it'll be a sight to behold!!!!!
Love it.........
If you're building wall on slab........Pt is a must for bottom plate and will be code across all 50 States.
doublewing11 is offline
post #4 of 4 Unread Today, 07:55 PM
Tedd's Avatar
Quoted: 188 Post(s)
Liked: 96
And if you are not in the US, then you might want to research the use of pressure treated lumber in an interior application.
Tedd is online now
basement , build , rustic , theater
