The Foyer Theatre - AVS | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ashdot1111
post #1 of 10 Old 03-30-2015, 05:55 AM - Thread Starter
ashdot1111's Avatar
Another Aussie Home Theatre
Well it begins! We've decided on a HT provider (Electronic Living in Brisbane, Australia) and the carpenter has started to raise the floor at the rear of the room. 2 windows should be framed up within days and the doors should arrive within the next 2 weeks. Pre-wiring for AV and lighting is due to start this Thursday.
The budget for the AV side of things came in just a tad over $18k installed (including most products, labor and programming). Due to budgets, we were not too focused on sound proofing. We concentrated on getting a solid door (but not anything commercially rated) with quality acoustic seals. The side/rear windows are being filled in and going to be filled with acoustic insulation. The big (rear of room) window faces the street so unfortunately is not going to have anything except a large curtain over it.
Sound treatment is going to consist of on the wall panels and will be decided upon later due to door being positioned in a "prime" spot.
Room to be painted a very dark bluey/grey, just a tad off black.
Equipment list:
  • Epson TW9200 Projector [existing equipment]
  • Peerless projector mount + extension pole
  • 130" 16:9 projector screen (Majestic EVO) [existing equipment]
  • Apple TV [existing equipment]
  • Roku media player
  • NAS network storage – rack mount
  • C-Bus 4-way fully programmed
  • Blu-ray player [to be determined]
  • Sanus 15RU AV equipment rack
  • Cool Components rack ventilation system
  • Thor A-12B power & surge 8-way power board
  • Integra DTR50.6 AV surround receiver
  • Aaron CC240 centre speaker
  • Aaron ATS-4 main speakers
  • Aaron SS-200 bi-pole surround speakers [middle speakers]
  • Current Audio CS654DBFL dipole/bipole rear surround in-ceiling speakers [in-ceiling due to window positioning]
  • Sunfire SDS12 subwoofer
  • RTI XP-3 control processor
  • Apple Extreme router
To be decided:
  • Blu-ray player
  • Curtain, carpet and paint colour
  • Air conditioning (split system or floor mounted)
  • Seating
ID:	635122   Click image for larger version
ID:	635130   Click image for larger version
ashdot1111 is offline
post #2 of 10 Old 03-31-2015, 12:00 AM
Jonny5nz's Avatar
Quoted: 29 Post(s)
Liked: 89
What are your room dimensions, and what size screen are you going for?
Jonny5nz is offline
post #3 of 10 Old 03-31-2015, 12:11 AM - Thread Starter
ashdot1111's Avatar
It's approximately 4 metres (13.1') wide and 5 metres (16.4') long. The rise 2 metres (6.6') from the back wall. Going for only 1 row, plus some bean bags on the floor area in front of the lounge.
Screen size is 16:9 at 130".
post #4 of 10 Old 03-31-2015, 11:20 AM
Jonny5nz's Avatar
Quoted: 29 Post(s)
Liked: 89
Nice. I look forward to seeing your progress.
Jonny5nz is offline
post #5 of 10 Old 03-31-2015, 11:10 PM - Thread Starter
ashdot1111's Avatar
We have decided to ditch the front "row" of bean bags and extend the rise forward to ensure there is enough room behind for a 7.1 set-up. We'll be sitting closer to the 130" screen so might have to upgrade in the future if it gets too close.
Can anyone recommend a good distance to be from the rear surround speakers?
post #6 of 10 Old 04-01-2015, 12:40 AM - Thread Starter
ashdot1111's Avatar
Here are some photos of the extended platform with centre step as well as the two windows in the room we are blocking. The other side of these boards is just plain white.
The screen wall with a window being blocked out
The platform being extended with a step in the centre
The side window which is also being filled in
ID:	639057   Click image for larger version
ID:	639065   Click image for larger version
post #7 of 10 Old 04-01-2015, 04:54 AM - Thread Starter
ashdot1111's Avatar
Hi all!
The pre-wiring is getting done tomorrow morning so I'd LOVE some feedback on the downlight locations!
Zone 1: Screen wash
Zone 2: Rear curtain wash
Zone 3: 2x above floor area and 2x above seating
Zone 4: LED rope lighting under platform edge
Any and all feedback would be much appreciated!
post #8 of 10 Old 04-01-2015, 09:18 AM
jimim's Avatar
Quoted: 121 Post(s)
Liked: 30
Originally Posted by ashdot1111 View Post
Hi all!
Zone 1: Screen wash
split zone 3 into two zones on dimmers. so you can control over seating vs floor if you want
jimim is online now
post #9 of 10 Old 04-01-2015, 04:14 PM - Thread Starter
ashdot1111's Avatar
Good idea. I've decided to split the two sets of downlights mid room and over seats into two separate zones. I'll combine the screen wall and rear curtain wall into one zone as I am limited to four zones.
post #10 of 10 Old 04-18-2015, 12:46 AM - Thread Starter
ashdot1111's Avatar
Here's a little update for you all!
The ceiling rose removed and a new manhole added (it's not centred due to beam)
The doors leading into the theatre (not yet painted)
Side of the room yet to be painted (this used to be a window)
The screen wall before painting (note: window used to be on the left-hand side)
First or second coat of black paint to darken walls/ceiling
Finished walls/ceiling - it's just a few shades under black
Another view of the finished colour (it's a bit brighter due to direct sunlight from window)
ID:	672065   Click image for larger version
ID:	672073   Click image for larger version
ID:	672081   Click image for larger version
ID:	672089   Click image for larger version
ID:	672105   Click image for larger version
Jonny5nz likes this.
