green glue or franklin international sound sealant? - AVS Forum | Home Theater Discussions And Reviews
Old 04-03-2015, 09:08 AM - Thread Starter
WildWolf's Avatar
Quoted: 79 Post(s)
Liked: 25
Is there a big difference in quality? there is a big difference in price!
WildWolf is offline
Old 04-03-2015, 09:35 AM
jautor's Avatar
Quoted: 934 Post(s)
Liked: 641
Are you talking about the Green Glue *SEALANT* vs. Franklin's sealant? They seem to be about the same price.
If you're trying to compare Green Clue (the soundproofing compound, not the sealant) to a sealant - they are totally different products - do NOT use a sealant as the dampening compound between drywall sheets!
jautor is online now
Old 04-03-2015, 09:38 AM - Thread Starter
WildWolf's Avatar
Quoted: 79 Post(s)
Liked: 25
Thx. Yes...i am looking for the compound. I need 14 tubes. I can get a case (12 tubes) for $190 but an extra 2 tunes will cost me $45 with shipping!!!!
WildWolf is offline
Old 04-03-2015, 11:24 AM
jautor's Avatar
Quoted: 934 Post(s)
Liked: 641
Ok, just to be clear then - the Green Glue compound is not the same as a sealant, so do NOT use that Franklin product for those last two tubes.
If that $45 is the killer - use slightly less compound per sheet to stretch your 12 tubes. But also - did you check pricing with thesoundproofingcompany? (I assume you're getting the case via Amazon currently - note that someone offers a half-case for $100 - a better deal than 2@$45 and you can sell the extras on craigslist)
Old 04-03-2015, 12:04 PM
eikon's Avatar
Quoted: 59 Post(s)
Liked: 55
If you have a Menards home center anywhere near you, you can get them for $14.69 each. I think they are currently running a 11% off everything through mail in rebate deal.. so you would be at $157 a case plus tax. Plus you can buy individual tubes.. no need for case by case purchase
eikon is offline
Old 04-03-2015, 12:07 PM - Thread Starter
WildWolf's Avatar
Quoted: 79 Post(s)
Liked: 25
Do any of the big box stores carry green glue? Do I have to order online?
WildWolf is offline
Old 04-03-2015, 12:48 PM - Thread Starter
WildWolf's Avatar
Quoted: 79 Post(s)
Liked: 25
Closest Menards is 420 miles away
WildWolf is offline
Old 04-04-2015, 06:14 AM
Quoted: 2420 Post(s)
Liked: 2070
I order green glue by picking up th phone and talking to Ted or John at Soundproofingcompany.com . You can't order via a click of the button, they like to talk to you. Many times they have told people to don't bother their plans weren't sufficient to achieve their goal. Like just doing one wall, or doing just the ceiling. Or not using isolation methods.
14 tubes is enough for 7 sheets of drywall, you must be doing just a ceiling.
BIGmouthinDC is online now
taboola here
