Recessed lighting, blown insulation? - AVS | Home Theater Discussions And Reviews
post #1 of 8 Old Today, 10:55 AM - Thread Starter
Gouie's Avatar
Quoted: 20 Post(s)
Not specifically a theatre build question but related to my basement project and heck, can't think of another forum with a brighter membership. Before I finish off the ceiling to my theatre I'm wanting to deal with sound issues in the adjacent room. The joists are accessible from one end, the remainder of the ceiling is finished. I realize that I will never achieve amazing sound isolation without tearing down the ceiling but I would like to, at the very least, insulate it. My plan is to blow insulation in from the open end. Not a challenge accept for the 3 pot lights. I do not know if they are insulation proof cans so I'd like to assume the worst in that they are not. Question is, if I replace the traditional incandescent lights with LED to keep the heat down will I be fine in blowing insulation around the cans?
Gouie is offline
post #2 of 8 Old Today, 11:19 AM
jautor's Avatar
Quoted: 536 Post(s)
Liked: 480
Regardless of LED or not, you should only do that with "IC" rated (In-Contact with insulation) fixtures. If you can see the fixture or get a photo of it in the ceiling, it's pretty obvious if it's an IC or non-IC model...
There are retro-fit ("old work") cans in both IC and non-IC, so choose carefully if you want to upgrade/replace them.
PS - If the existing lights were installed by a builder, very likely those will be non-IC, as they're like $2 cheaper!
jautor is online now
post #3 of 8 Old Today, 12:04 PM
drunkpenguin's Avatar
Quoted: 304 Post(s)
Liked: 300
Look inside the cans from inside the room. Some brands have a sticker to identify them as IC rated. Otherwise they should have a sticker on the attic side if u have access.
Dont just put led lights in and cover them without knowing. What happens if the next guy moves in and wants traditional bulbs?
drunkpenguin is online now
post #4 of 8 Old Today, 12:21 PM
Stereodude's Avatar
Quoted: 1161 Post(s)
Liked: 823
Those probably won't be available by then.
Stereodude is online now
post #5 of 8 Old Today, 12:45 PM
Quoted: 977 Post(s)
Liked: 952
you could put warning stickers inside the cans, but I would replace them before you put in the insulation.
BIGmouthinDC is online now
post #6 of 8 Old Today, 12:58 PM
tlogan6797's Avatar
Liked: 37
Interestingly enough, I was in the Dollar Store last week and found a whole cache of 100w incandescents, from a major manufacturer in what appeared to be new packaging, which I thought were not allowed to be made any longer.
Tom Logan
Need motivation? Get LOGANED
An as-yet un-named theater designed by Big-WarrenP-BritInVA
tlogan6797 is offline
post #7 of 8 Old Today, 05:23 PM - Thread Starter
Gouie's Avatar
Quoted: 20 Post(s)
Appreciate the quick replies everyone. Great point about the next potential owner throwing in traditional bulbs. I'll pull one of the fixtures and take a peek. The lights are not in the attic, they are in the basement ceiling so the best I'll be able to do is look from underneath. I'll report back soon.
Gouie is offline
post #8 of 8 Unread Today, 07:22 PM
Quoted: 304 Post(s)
Liked: 300
If u can post pics.
