Will this work? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Craig Peer
post #1 of 6 Old 05-18-2015, 08:16 PM - Thread Starter
JasonTell7's Avatar
Liked: 1
Will this work?
Should I even consider a projector in this room, or is it pretty much pointless? Enclosing the room in is not an option. This is an upstairs bonus room, and as you can see it lets in quite a bit of light. Is it even worth trying?
JasonTell7 is offline
post #2 of 6 Old 05-19-2015, 07:50 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
It depends on what your goal is.
Are you planning to watch in daylight? Can you paint the room? Can you hang a black curtain over that half wall to block light while you are watching? Do you have kids and need to take night-time noise into consideration?
At it's most basic, you can certainly hang a projector and get he big screen feel (or if you can't remove the cieling fan get a 70" big screen). Get a good quality 5.1 setup and you might be compeletly happy with the results. Or not. Depends on your goals.
Post a little more info and you can get more help.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 6 Old 05-19-2015, 08:05 AM
Quoted: 3286 Post(s)
Liked: 2774
this room may be a candidate for the largest flat panel TV and quality headphones you can afford unless you can address the light and sound issues.
post #4 of 6 Old 05-19-2015, 11:20 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3128 Post(s)
Liked: 3053
If you do most of your movie watching at night, the light issue will be moot. I'd always rather have a projector and screen setup - haven't been without one since 2002!
JRock3x8 likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #5 of 6 Old 05-19-2015, 11:58 AM
JRock3x8's Avatar
Quoted: 654 Post(s)
Liked: 163
unless you can completely cover those windows, you'll always struggle in daylight hours.
JRock3x8 is offline
post #6 of 6 Old 05-20-2015, 11:39 AM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Looks like light control will be impossible unless you frame in the room and put a door on it. Either a big TV or one of the ambient light rejecting screens (e.g. Seymour Screen Excellence Ambient Visionaire or Screen Innovations Black Diamond) with a PJ.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
