DIY AT Fabric -- Landscape Fabric? - AVS | Home Theater Discussions And Reviews
post #1 of 5 Old 05-25-2015, 10:06 PM - Thread Starter
granroth's Avatar
Quoted: 520 Post(s)
Liked: 285
Home Depot sells Scotts Landscape Fabric for dirt cheap (pun intended). It's this:
It has a few things going for it:
  • Easily passes the "blow test" (acoustically transparent)
  • Black
  • Cheap ($1.80/yard)
  • Readily available (HD)
So does it make a good AT fabric?
The Look
Up close, the fabric has a quilted pattern that's not unattractive. It doesn't stretch very much at all -- think canvas, in terms of stretchability:
It's very thin and notably see-through depending on what's behind it. Here's a quick panel I threw together with a white primed frame and yellow OC 703:
That's sort of a look in it's own right, though. It almost looks like an intended pattern in person.
If you build wall panels with it, then the see-through ability is magnified:
If you shine a light through it (even indirectly), you will see what's behind it unless everything is flat black.
Does it Burn?
Another hallmark of fabric intended for use in wall panels (like Guilford of Maine) is that they are flame spread resistance. Specifically, GOM fabric is ASTM E84 Class A rated, which is the lowest flame spread. How well does Scotts Landscape Fabric hold up in that respect?
I decided to test that out myself and posted the following video:
The TL;DW is that it is one of the fastest burning substances I've ever seen. It's made of some kind of plastic, which instantly sets on fire and burns through very quickly. It drops molten blobs of plastic the entire time it burns.
The Conclusion
I'm using it pretty extensively as a temporary fabric, but I probably will replace all of it with something a bit more safe in the final iteration of my theater. It works "okay" for now, but the thinness plus the safety factor make it less attractive to me in the long run.
ID:	737578   Click image for larger version
ID:	737586   Click image for larger version
granroth is offline
post #2 of 5 Old Yesterday, 05:10 AM
AVS Club Gold
Clarence's Avatar
Quoted: 58 Post(s)
Liked: 44
Originally Posted by granroth View Post
... it is one of the fastest burning substances I've ever seen. It's made of some kind of plastic, which instantly sets on fire and burns through very quickly. It drops molten blobs of plastic the entire time it burns.
The Conclusion
I'm using it pretty extensively...
Do you have a family in that house? I have 53 yards of GoM... way more than I'll need. How much do you need?
Or was this an arsonist's joke for the "Phoenix Theater... rising from the ashes"?
Clarence is online now
post #3 of 5 Old Yesterday, 06:05 AM
Quoted: 1076 Post(s)
Liked: 1010
We did the same test at White Oaks and were very concerned. Actually Auburn held the fabric out over the edge of his deck and hit it with a lighter, he couldn't let go fast enough and burned his fingers. Then we wrapped the OC 705 with a layer of the landscape fabric and a layer of GOM. Couldn't get it to hold a flame, melt yes, but it couldn't sustain a flame.
Our goal was to cut down the shine through of GOM and it worked.
If you like the look of the fabric you will probably like Medium Grey GOM FR701 That is a tweed mix of greys not monochromatic.
post #4 of 5 Old Yesterday, 05:48 PM - Thread Starter
granroth's Avatar
Quoted: 520 Post(s)
Liked: 285
Heh, no, but I do stress the "temporary" part of my use of it. I'm building my theater in two distinct phases ("Minimally Viable Product" and "Full") and just needed a cheap and essentially disposable fabric for some uses for my upcoming MVP release next week. It'll all be replaced with more robust fabric for my Full release.
As my wife says "no open flames in the theater!"
granroth is offline
post #5 of 5 Unread Today, 05:28 AM
Mfusick's Avatar
Quoted: 397 Post(s)
Liked: 1578
I like your threads Kurt
Mfusick is online now
