acoustic panels for sound deadening in apartment? - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2003, 01:42 PM - Thread Starter
Agilitine's Avatar
I live in an apartment and want to keep noise from getting out. Im not too concerned with the sound quality, just sound deadening. I dont mind turning off the sub at night. Are my voice, guests voices, and surround sound frequencies in the range of cheap DYI acoustic panels, like the ones made of fiberglass and burlap? Maybe putting some hard mass on the back of the panel and keeping it 4 inches off the wall would make the sound waves work harder (more abrupt changes)? My room is @20x12x9, with two full size couches side to side against the long wall (my neighbor is on the other side) slightly angled to the soon to be screen. I figure lining the wall behind me with these things all the way to the top, and some around/on top of the screen would keep things quiet. What do you guys think?
sleep = less anime
Agilitine is offline
Old 01-12-2003, 11:17 PM
cowtown's Avatar
Would throwing a second layer of drywall on that wall out?
You could also try hanging a large carpet on that wall, like a persian or whatever. The sub is typically what you have to worry about the most. I guess I was lucky because the apartment I was living in for the past 3 years was all concrete and I had my Home Theatre pounding some nights with nary a complaint, and I rarely heard anyone else either. I didn't buy a sub for my home theatre until I moved into my house though since I did have a little respect for them. :P
I'm not sure how but this both sucks and blows...
cowtown is offline
