Cold Water Creek cinema build - AVS Forum | Home Theater Discussions And Reviews
 122Likes
post #1 of 390 Old 12-05-2015, 12:43 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
MAINS:
Oem QSC 2150s not clones bought for a really good deal off avs member cdy2179
SURROUNDS,REARS,ATMOS:
10 VOLT LX . I already had 2 in ported boxes that I bought from a local avs member and loved the sound. The rest were bought new from diysoundgroup.com
PROJECTOR:
Jvc rs 400 bought during the preorder from avscience also just ordered a chief rpma mount from them. Plugged in just to make sure everything worked fine. Was amazed the picture it produced on just a white wall. Happy JVC came out with a projector with more lumens to do the screen size I wanted.
AVR:
Going with the denon 5200 or 6200 or the Marantz 7009 or 7010
SCREEN:
165" 16:9 center stage xd acoustically transparent material . I'm going to be building my own frame out of 1x4s.
AMPS:
I nuke 6000 dsp for subs . outlaw model 5000 for LCR and 2 atmos speakers
SUBS:
4 siht18s. I'm probably going to do the full size marty sub boxes for these
ACOUSTICS:
1.5 " LINACOUSTIC RC for side walls . 1" for baffle wall and front wall. 2" on rear wall and front face of bar. Most likely 8 2x4 BAD panels
WALL COVERINGS:
acoustimac castle suede in Ruby and Dmd black. I wanted to do all dmd but they didn't have the colors that me or my wife liked and acoustimac reassured us that the dmd is only 6 percent more transparent.
CARPET:
Looked at a ton of carpet ended up going with Shaws caress line carpet style is appreciation. There's a picture on the second page only difference is were going with the black and grey.
LIGHTING:
3 zone grafik eye.this will control main lights and soffit lights . I'm still not sure what to do with third zone. The risers lips will have led strip lighting installed underneath each of them. 12 to 14 uv lights for star ceiling. These will be controlled off a light switch next to the grafik eye
BAR:
the wife wanted something flashy for the bar top so we're going to use a backsplash tile that is pictured also on page 2 plus I'm going to be doing accents behind the bar with brushed alluminum the face will be done in dmd black with theater name which is still to be determined embroidered in dmd material
Just went and bought all the wood and drywall to start my home theater. Ceilings are 16 foot cathedral but am dropping to 10 foot. With a 10 inch soffit or possibly a light tray soffit similar to the bacon theater build. Room probably isn't going to be soundproofed. Room dimensions are 32x18 unfinished. My plan is to do 1 set of 3 recliners in the front and a set of 4 on the first riser . The second riser will have a 10 foot bar behind it. Front wall will be a false wall with a 150 in AT screen. All speakers will be bought from diysoundgroup exception for the 4 siht18s in marty sub boxes. Projector is a jvc rs400 which should be here Monday.
ID:	1099850   Click image for larger version
ID:	1099858   Click image for larger version
ID:	1099866   Click image for larger version
ID:	1099874   Click image for larger version
hd0823 is online now
post #2 of 390 Old 12-05-2015, 03:03 PM
woodgieroo's Avatar
Originally Posted by hd0823 View Post
Room dimensions are 32?18 unfinished.
That. Is. Huge.
Can't wait for progress pics. Good luck with the build!
woodgieroo is offline
post #3 of 390 Old 12-05-2015, 03:34 PM
Quoted: 3277 Post(s)
Liked: 2754
Wonderful blank canvas.
the back bar can be on the same level as the second row, if it is a normal 42 inch tall bar height, the lower you keep the back bar the better surround sound for money seats. You could make the entire riser taller than needed because you have so much headroom. Not sure I would come down to 10, maybe 11.
One of my favorite theaters had a 24 inch riser and I think a 12 ft ceiling. Swizzle stick in my signature. If you are planning on using the riser as bass absorber the taller the better.
mcascio and livitup311 like this.
post #4 of 390 Old 12-05-2015, 07:45 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Big it's funny you mention that I was going through a bunch of your builds and seen the higher riser. I definitely like the idea of using the riser as a bass absorber . What is all involved in turning the riser into a bass absorber
post #5 of 390 Old 12-06-2015, 11:24 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
My biggest worry about going taller than 10 is the wall the screen is going on has the sub panel box on it. That will be a 3 foot out false wall which would put the wall right at 10 foot if I go higher my room size keeps getting a little smaller which isn't that big a deal for me . Im just not sure how to make the room look good in the back where the one window is because we're the ceiling meets the back part cathedral I'll have a few foot still showing of the cathedral. Can't think of any way to not have it like that without building another wall at the back
post #6 of 390 Old 12-06-2015, 04:22 PM
Liked: 2754
It is easy and actually more economical then some other designs.
Basically you build the riser so that it is all one connected air space, fill with cheap fiberglass insulation and add vents on the top near the side and rear walls.
Specifics: lets say you are building a 12 inch tall riser, use 2x12s for the perimeter but use 2x10s or 8s for the internal stringers leaving 2-4 inch air gap across the entire bottom. Fill with batt insulation. Cut in 4 inch by 36 to 48 inch vents where the side walls meet the riser top and two along the back wall. I add mid span supports so it doesn't get bouncy and 2-3 layers of decking with Green Glue between layers.
post #7 of 390 Old 12-07-2015, 05:25 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
thanks BIG for the advice it's crazy how much I've learned in the short time being on this forum
post #8 of 390 Old 12-07-2015, 05:56 PM
psychdoc's Avatar
Quoted: 122 Post(s)
Liked: 197
Good luck. I look forward to some pics. A nice big room like yours will be a ton of work, especially if you have not done stuff like this before. But, when you are done you won't want to leave the room.... ever.
psychdoc is online now
post #9 of 390 Old 12-07-2015, 06:16 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Also the waf is coming into play on the taller 2 foot riser she likes the 2 step more. If I do the 2 step does only the bottom riser that's along the floor need to be 4 inched off the ground
post #10 of 390 Old 12-07-2015, 06:17 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Yeah this is my first time ever doing anything like this I'm just trying to soak up everybody's advice.
post #11 of 390 Old 12-07-2015, 06:19 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Also will the front board of the riser be a 2x12
post #12 of 390 Old 12-07-2015, 07:27 PM
Liked: 2754
post #13 of 390 Old 12-07-2015, 10:12 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
post #14 of 390 Old 12-08-2015, 09:29 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
You have a great space, lots of potential!
Mfusick is offline
post #15 of 390 Old 12-08-2015, 05:18 PM
DaveClement's Avatar
Quoted: 173 Post(s)
Liked: 66
I think that your space is amazing. Looking at the ceiling, to me, it begs to be finished with the open expansive height and not covered up. It reminds me of many historical theaters that have an extremely high ceiling that is painted like the sky, or even just painted black. A great example is the Fox Theatre in Atlanta, shown in the photo below that I found with a quick Internet search. If you build a soffit around the perimeter of the ceiling to help hide the corners, and paint it a dark color, the ceiling would almost disappear from view. It would probably be a lot cheaper and easier to build it that way than having to frame in a lowered ceiling. You wouldn't need to do anything like the "old fashioned" look in the Fox Theatre. It works with any style, even ultra modern. There are plenty of home theaters with dark ceilings and night sky images, but with the lights partially on, you still see the ceiling. With a ceiling that high, it would just fade away, giving your theater a wide open expansive feel.
DaveClement is online now
post #16 of 390 Old 12-10-2015, 09:21 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Sorry for no updates been a busy week at work . I haven't got to work on the theater to much this week . Me and my father in law plan to have the lowered ceiling in by this weekend. My initial plan was to leave the ceiling in cathedral and do the soffit around but after looking at tons of home theaters I just prefer the flat look better.Also I feel like acoustically it would be less challenging to make a flat ceiling right than a cathedral. Don't get me wrong I do love cathedral ceilings most of the rest of the house is cathedral ceilings. Im just not sure about it in the theater
post #17 of 390 Old 12-12-2015, 04:23 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Looking at fabrics for the room going to go with the darker black fabric but having a hard time deciding between the grey or gold any opinions
post #18 of 390 Old 12-13-2015, 06:04 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Only got a few hours to work on the theater this weekend but got about half the ceiling up
ID:	1118818   Click image for larger version
post #19 of 390 Old 12-16-2015, 09:55 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Just thought I would post some of the new equipment coming in. Grafik eye 3 zone is on the way. Going to hold off on the receiver and speakers and seats till closer to the end. Anyone have good recommendations for seats
ID:	1123802   Click image for larger version
post #20 of 390 Old 12-16-2015, 10:15 AM
VTstang's Avatar
Quoted: 98 Post(s)
Liked: 58
and end build.....
VTstang is offline
post #21 of 390 Old 01-03-2016, 07:51 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Riser starting to come along going to pick up the plywood today and wire to get the electrical done
BIGmouthinDC likes this.
post #22 of 390 Old 03-09-2016, 10:44 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Just some updated pics of progress
ID:	1303081   Click image for larger version
ID:	1303089   Click image for larger version
ID:	1303097   Click image for larger version
ID:	1303105   Click image for larger version
ID:	1303121   Click image for larger version
post #23 of 390 Old 03-09-2016, 12:24 PM
Todd Lee's Avatar
Your room is coming along nicely. I really like the door location. Very appealing to enter from the rear center at riser height!
Todd Lee is offline
post #24 of 390 Old 03-10-2016, 12:04 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Thanks. I wish that was the entrance that's actually a window that will be covered entrance is off to the right of the riser. I wanted to enter at riser height it just wasn't possible with how my house is set up
post #25 of 390 Old 03-17-2016, 08:37 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Stage almost all framed
post #26 of 390 Old 03-18-2016, 04:22 AM
JRock3x8's Avatar
Quoted: 654 Post(s)
Liked: 163
that's one hell of a riser - i envy your headroom.
JRock3x8 is offline
post #27 of 390 Old 03-23-2016, 03:44 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Yeah I got lucky we bought the house last year. The room is above a basement garage. It was the only room that wasn't finished and the largest room also at 32x 18 with 16 foot cathedral ceilings. So I had a nice blank slate to start with . Ceilings are 10 foot flat now. With the soffit and riser built it is still about 7 feet from riser floor to soffit. Closer than I wanted to but still comfortable enough to walk around
JRock3x8 likes this.
post #28 of 390 Old 03-26-2016, 06:57 PM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Stage built about to start the baffle wall
ID:	1340962   Click image for larger version
post #29 of 390 Old 04-05-2016, 10:42 AM - Thread Starter
hd0823's Avatar
Quoted: 128 Post(s)
Liked: 147
Baffle wall started and can lights in
ID:	1359994   Click image for larger version
post #30 of 390 Old 04-05-2016, 08:01 PM
Liked: 2754
Are you planning on dry-walling this room? If yes you've build so much in this room it is going to take twice as lone to hang the rock. What you've built does look good.
