insulating 2x6 staggered studs 24OC - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 4 Old 03-11-2016, 01:36 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 928 Post(s)
Liked: 228
I recently framed my basement with 2x4 studs on a 2x6 plate staggered 24OC (each side).
What is the proper way to insulate? Are there any pictures? I don't think "weaving" is the preferred method.
Should I use R19 23" and carve out peices or am I better off simply insulating each side with R13 in between the respective cavities. What I don't want to do is ruin the decoupling by compressing the insulation.
JOe K.
tjcinnamon is offline
post #2 of 4 Old 03-11-2016, 03:22 PM
Quoted: 74 Post(s)
Liked: 59
I dont know if this is the 'normal' method. I did 16oc 2x4 (meaning that there was a stud every 8"). I took 16" insulation and cut a split almost to the kraft paper so the insulation would go over the side of the 'middle' stud as apposed to compress. It didnt need much of a split because it already had some clearance because it was offset.
I dont like cutting insulation but with a 2x4 to compress and use as a straight edge...it went pretty fast.
~JH
Jonny Hotnuts is offline
post #3 of 4 Old 03-11-2016, 03:40 PM
Quoted: 3255 Post(s)
Liked: 2743
any method that doesn't compress the insulation will be fine
tjcinnamon likes this.
post #4 of 4 Old 03-13-2016, 08:06 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 928 Post(s)
Liked: 228
does it matter if I use kraft facing? Also, should the paper touch the drywall or will the sound get to the insulation via the top and bottom plates?
basement , framing , insulation , staggered-studs
