Use recessed wall for sub or seal it up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-24-2016, 11:29 PM - Thread Starter
nathanieljla's Avatar
Quoted: 17 Post(s)
I'm about to have my water heater moved which leaves me with a question of what to do with the space. I'm inclined to just put a wall up. However I remember reading a pretty long thread, probably a decade ago, discussing the idea of putting a sub inside a recessed area of the wall. I don't recall the conclusion, but I think it was from the audio theory forum so there was a lot of...theory/pros/cons.
I've got a down firing sub. Would it be worth sealing up the top half and keeping the lower half for a sub to sit in? If I had to guess, the answer is "don't do that!", but I just wanted to double check before close it up.
Thanks for the input,
Nathaniel
nathanieljla is offline
post #2 of 7 Old 05-25-2016, 05:53 AM
Quoted: 3256 Post(s)
Liked: 2743
Just finished building bumpouts for subs, not down-firing though. Placement in the room will infuence the quality of the result. Better to have multiple subs.
post #3 of 7 Old 05-25-2016, 08:09 AM - Thread Starter
Quoted: 17 Post(s)
Just finished building bumpouts for subs, not down-firing though. Placement in the room will influence the quality of the result. Better to have multiple subs.
Is the purpose for acoustical benefits or due to room constraints? I.e. If you could have as much room as you want behind a screen would people still add these "bumpouts" ?
post #4 of 7 Old 05-25-2016, 12:05 PM
Liked: 2743
it is more about conserving space.
post #5 of 7 Old 05-26-2016, 12:05 PM - Thread Starter
Quoted: 17 Post(s)
Like always, thanks for sharing the knowledge.
post #6 of 7 Old 05-26-2016, 12:11 PM
dmarcink's Avatar
Quoted: 135 Post(s)
Liked: 91
Nathaniel
Looks like a great space for an in-wall Middle Atlantic equipment rack.
"Every time I put the line in the water I said a Hail Mary and every time I said a Hail Mary I caught a fish." - Fredo
dmarcink is offline
post #7 of 7 Old 06-01-2016, 09:21 AM - Thread Starter
Quoted: 17 Post(s)
No need for that in my case, but thanks for the thought!
