We started by removing the roof off the house. Then we took down the walls. This is our old garage. Tomorrow We'll saw cut the floors and remove the slab.
No we are building a theater room out of the old garage (but bigger), while also building a laundry room, office, bedroom , and a new garage. All will be on the same level. We don't really have basements in Southern California.
We finished demo. The dogs think we're ready to set forms. Hopefully we will be trenching Monday for the slab.
You can see the old garage in red and the new addition that will be built. There are few items I've changed on the floor plan, but most items are correct.
Can you explain the 30 inch pony wall with 12 inch clear railing on top behind the first row of seating and the 42 inch wrought iron partitions at the front of the theater? Do you have a proposed layout of the theater room with seating and screen size/placement?
You are already planning on running plumbing why not include at least 1/2 bath supporting the new bedroom and the theater?
The 30" pony wall is mandatory for code due to the 14" drop off (which is where seating will go). I'm going to run power in the pony wall for the motorized recliners and conduit for bass shakers. Ignore the 42" wrought iron partitions. We had some trouble with building codes, but there will be a complete wall there.
We have a bathroom in our current house near the theater. The wife an I didn't want to budge on other items. The bedroom will most likely be her art room. We are also running out of space on our lot. We have large setbacks in our area and we have an easement at and angle behind us which is why the garage is shaped the way it is.
I haven't settled on a screen size yet but I'm leaning towards a 2.35 130-140 diagonal. Seating distance will depend on screen wall thickness. I still need to determine the speakers and the layout. I'd like to make the screen wall as thin as possible to increase the seating distance.
I would only have the pony walls in place cheaply made for the inspection then remove them after the occupancy inspection.
In this theater there was a 24 inch drop and a hand rail was installed during construction, it was removed before the carpeting and and chairs installed and later the inspector had no issues.
I'm subscribed and looking forward to watching your project come along. Once your past the initial construction and more into the setting up of the theater, depending on where your at in So Cal, I'd be glad to possibly help out if you need an extra set of hands.
Eventually I'm going to be building my own dedicated theater room, so lately I've been spending much more time in this part of the forum, and trying to learn everything I can / figure out what I like for my own setup.
Anyhow, send me a PM if you need any help down the road.
Now I have to finish running conduit before getting our concrete forms inspection. I am trying to figure out the best way to supply electrical (power recline) and speaker cables (tactile transducers) under the seats. I am thinking about installing these Raco floor boxes: https://www.lowesforpros.com/electr...nd-plastic-electrical-box-cover_g2496501.html
Anyone out there have power recline on their seats? How many outlets do they take? I wrote it down when I went to Seatcraft but I forgot, I think it was two.
I feel your HVAC pain. My HVAC guy wants to use Daikin, but the Daikin rep supposedly isn't getting back with him. Its been two weeks and I still don't have a plan or a quote. I may be moving on to plan B tomorrow.
No worries. I can get Fujitsu after all. I also want to get another manual J calc. I think they guy that did the first one miscalculated something. He's showing 38,000 BTU's cooling for the addition (1,163 sqft) which seems really high to me.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
