Haasienda Theater Build Thread
I am re-purposing this thread I started to be a general build progress thread.
Here is a link to the first major update with framing (nearly) finished: Framing Progress
Original Post:
Hello, I'm trying to plan the layout for my currently unfinished basement. Due to some difficult locations of stairs, mechanicals, etc, it has put some limitations on what area I have available for the theater. My current plans have the theater around 18'x14'. However as you can see in the attached files, it is an odd shape. I'm planning on a screen size somewhere around 100" wide, and I would like to have at least a small second row, but not necessarily reclining. I'm looking for some thoughts from more experienced people on this. Does it seem like the room has enough size to support 2 rows? Can I fit 4 seats in the front row? I don't necessarily have to have "theater seats" as I think an appropriate couch could be acceptable. Thanks in advance.
Note, in the plans, the brown rectangles are stairs.
Original Post:
