Acoustical Treatments Master Thread - Page 144 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
Old 01-29-2009, 04:39 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 102
As an FYI, there is a new product (a couple actually) from Quest Acoustical Interiors (www.questai.com), ... no I don't work for them.
Perf-Sorber is a combination absorber/diffuser in a single fiberglass panel. An excellent early reflection point product speakers with good off axis response. Also, a good choice around surround speakers. The other (I forget their trade name) is a product with very good absorption down to 150Hz.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
Old 01-29-2009, 09:50 AM
Wireless member
pepar's Avatar
Quoted: 1001 Post(s)
Liked: 518
Thanks, but I could not find the Perf-Sorber.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
Old 01-29-2009, 09:55 AM
Ethan Winer's Avatar
Quoted: 265 Post(s)
Liked: 359
Originally Posted by will1383 View Post
I'm going to be hard pressed to fit anything in the front of the room
Wall-floor and wall-ceiling corners are just as good as wall-wall corners.
my speaker stands which double as bass traps (can fill them with sand).
A tube filled with sand is not a bass trap.
would you suggest moving the subwoofer to the rear of the room where I'll have a couple of bass traps in the corners
Sub location and bass trap location are not really related. If you can post a photo of your room I may be able to suggest something.
would you also recommend against a second subwoofer?
I do fine with one killer SVS sub and a huge amount of bass trapping, but some people are happy with two subs.
--Ethan
Ethan Winer is offline
Old 01-29-2009, 10:39 AM
will1383's Avatar
--Ethan
I have family down your way, and I think we are going to visit sometime in April. I should try and see if I can make an appointment to come and visit you.
Here's a basic layout of my room:
But, it is Tight around the screen and such. There's very little room in the front for bass traps.
Funny, I thought that a sand filled tube would suffice as partly a bass trap, but, I figured that something wasn't quite right about that. The two rear corners, again are going to be pretty tight, but I have more room to work with in those than in the front...
I might put 4" of 703 on the front wall instead of 2 just to help with the lower frequency absorbtion... Thoughts regarding that?
Or should I really take the time to take all the measurements of the room before doing anything?
Also, where those sconces are there are going to be 4 Cherry columns. They are wood, would mass loading the inside of them help absorb some of the low frequencies? They are not at the 1st and 2nd reflection points.
will1383 is offline
Old 01-29-2009, 04:17 PM
Quoted: 64 Post(s)
Liked: 102
Call them. It may not be up on the website yet. Works very nicely.
Old 01-29-2009, 06:22 PM
sound dropouts's Avatar
I am hoping to make a theater in the upstairs room of a house. The roof slants into the room, creating an odd shape. I am unsure how to acoustically treat the room. Attached is a rough drawing of what I hope the front will look like...where should I put acoustic treatemnts? Should I put them on the slanted parts as well?
sound dropouts is offline
Old 01-30-2009, 01:35 PM
Quoted: 265 Post(s)
Liked: 359
There's an article on the DIY TV Network site that shows how to make a "bass trap" from sand in a cardboard tube. That article is the laughing stock of the acoustics industry. I even wrote to them and explained (nicely), but they never replied and the article was still there the last time I checked.
Sure, that can only help. Especially if it's near wall-wall, wall-floor, and/or wall-ceiling corners.
Not likely.
--Ethan
Old 01-30-2009, 07:48 PM
(Berk)'s Avatar
I previously explained my concrete bunker under the garage that I am currently working on. There is only one wall that is shared with the rest of the home, the other 3 walls are fully below ground level the only thing on the otherside of them is dirt.
If I'm not worried about sound isolation, only a good sounding room, wouldn't it also work to just not drywall the bottom 48" of all the walls? Could I shove regular insulation in there, then some linacoustic (if it is needed?) and then fabric? Then I only have to drywall the top portion.
The one shared wall on the other side of the 8 inch concrete wall is 2X6 framed, and drywalled too.
Also, can anyone tell me if eggcarton shaped foam is a good idea to put on my sloped concrete ceiling?
Berk
(Berk) is offline
Old 01-31-2009, 09:39 AM
Quoted: 265 Post(s)
Liked: 359
Drywall, cement, it's all the same - reflective. If you want the room to sound good what you really need are corner bass traps, plus absorbers at the side-wall and ceiling reflection points.
It depends on the quality and thickness of the foam. Generally speaking, better treatments are made from rigid fiberglass.
--Ethan
Old 01-31-2009, 10:06 AM
(Berk)'s Avatar
--Ethan
So if drywall and cement are both reflective, there is no benefit to drywall the areas that will be covered up with treatments anyways?
Okay thanks, that will save me some time and money.
(Berk) is offline
Old 01-31-2009, 10:19 AM
eugovector's Avatar
Keep in mind that you want the room to be insulated for heat/ac as well as sound. Don't want to be sweating/freezing while you're watching movies.
Listen to the Real HT Info Podcast at http://realht.info, including video reviews at my YouTube Channel: http://www.youtube.com/user/realhtinfo/videos
eugovector is offline
Old 01-31-2009, 10:24 AM
ScruffyHT's Avatar
Berk
Are you going to have the room inspected by the city ? ( electrical etc ? )
ScruffyHT is offline
Old 01-31-2009, 11:05 AM
(Berk)'s Avatar
No, I'm not planning having inspections done.
(Berk) is offline
Old 01-31-2009, 11:08 AM
(Berk)'s Avatar
I'm definitely going to insulate still, but I'm thinking of saving the bother of putting drywall on top of the insulation, only to add more insulation for accoustics.
(Berk) is offline
Old 02-01-2009, 09:41 AM
Quoted: 265 Post(s)
Liked: 359
Yes, assuming you mean using Liquid Nails etc to glue drywall flat onto the cement. In that case it's bunch of work for no acoustic gain. But making a new stud wall inside the cement wall can help (a little) with acoustics, and that can add thermal insulation too as eugovector said.
--Ethan
Old 02-01-2009, 01:53 PM
(Berk)'s Avatar
--Ethan
No, I have a 4 concrete walls that I've framed a new stud walls inside which will be fully insulated.
I am asking if it is okay to drywall only the top half of the walls and put fabric wrapped linacoustic (without drywall) on the bottom 48"? My thought is, what is the point of putting drywall on the bottom 48" if I'm going to cover it with accoustical treatment anyway? I'm not concerned about sound isolation.
(Berk) is offline
Old 02-01-2009, 02:06 PM
Wireless member
pepar's Avatar
Liked: 518
Resale value?
pepar is online now
Old 02-02-2009, 09:53 AM
will1383's Avatar
I guess in theory you could, but you are only going to be saving maybe $100-150 on a several $1000's build. IMO, it's not worth saving in this case. Build a studded wall inside the concrete walls, and decouple that wall. Put Drywall on the whole thing, and then go from there. It'll be the best bang for the buck.
When I did this, I actually glued insulation onto my concrete walls, to help with both environmental and acoustics. Whether or not it made a difference acoustically, I have no idea.
will1383 is offline
Old 02-02-2009, 01:59 PM
Quoted: 265 Post(s)
Liked: 359
In that case you'll do well to pack the entire space behind the drywall with fluffy fiberglass. Leaving off the bottom sheet rock will help a lot acoustically, because that gives substantial bass trapping along all the wall-floor corners. I agree with pepar about resale value, though maybe the next owner will want a good sounding room too?
--Ethan
Old 02-03-2009, 10:07 AM
Erik Westlund's Avatar
Originally Posted by pepar View Post
Those here with the knowledge and experience who could put something like that together are professional consultants, with "professionals" meaning "they work for money." That they answer questions at all for free is greatly appreciated. I am afraid that you will need to research this material on your own - like the rest of us have - or step up and hire a pro.
Thanks Pepar for your response. But I feel you have misinterpreted my message a little. It would not intend to weaken the consumer/client relations. I think it would enrich it.
I am in the A/V retail sales industry. And I have been for years. I see with both a consumer-client point of view (it's my hobby) AS WELL as the sales side of things. I always appreciate a more knowledgeable client when I meet one. It makes for a better level of communication. Even if they have the basics down... just a little. I can better understand their motives and interests. It also makes their efforts easier, as well. Since this is a technology based language. It seems obvious to me that one must understand the basics before they can communicate with a more experienced individual.
Often times, a client may not have the full or correct information from what they have learned. But that's OK if they have not executed that idea yet. After talking with a professional, they will be more aware and appreciative of their help and knowledge. They will realize that there is a whole lot more to know. When the client has taken the initiative to attain some knowledge on their own. They then realize it can't be done on their own if they want to do it right and/or done in a reasonable amount of time.
With the intent of this "outline- a/v bible", most of these basics can be covered. This should minimize a level of forum redundancy and advance beginners to intermediate in little time.
no?
Erik Westlund is offline
Old 02-03-2009, 11:46 AM
Wireless member
pepar's Avatar
Liked: 518
no?
Nice thoughts, but it would still be a lot of work on a complex subject with many aspects that lack 100% consensus . . with no immediate . . and perhaps simply no . . return.
You're in marketing, aren't you?
pepar is online now
Old 02-03-2009, 08:06 PM
Triaxtremec's Avatar
Where is a great place to get rigid fiberglass so I may make my own panels? Also are foam panels bad to use?
Triaxtremec is offline
Old 02-03-2009, 08:22 PM
elee532's Avatar
Quoted: 78 Post(s)
So, I was thinking about trying these, or maybe just a plain old absorption panel, at my side reflection points. However, my room has a 6" ledge and then a window about 4' up the wall. The right side wall has no similar constraints. How would I position a panel on this wall?
Here are some photos (see particularly the last one of the bunch):
http://www.avsforum.com/avs-vb/showp...postcount=2825
elee532 is offline
Old 02-04-2009, 07:50 PM
Perhaps you are right. There are a lot of good books out there to begin with, as well.
p.s. no. I'm not in marketing.
p.s. I've been reading the latest posts. I just would like to throw this out.
If anyone is thinking of putting up a lot of sound treatment on the walls. Be careful of what type of material you use to keep the maintenance low. Mainly mold. For instance. If you live in a humid place and you want to put up something like cotton in a basement wall, consider your options first. You also might want to keep this spider free, too.
ew
Old 02-04-2009, 08:04 PM
bravo36's Avatar
Here's where I got mine in Dallas: http://www.spi-co.com/index.html
And guess what...they have a location in Omaha: SPI (Specialty Products and Insulation Co.)
5010 I Street
Omaha, NE***68117
402-827-3880
402-827-3882 FAX
omaha@spi-co.com
Great, friendly folks to deal with at my location. I bought 1 1/2" 3# ridgid panels for about $90.00/case (16-2x4 sheets). Worked like a champ.
bravo36 is offline
Old 02-04-2009, 08:20 PM
AnthemAVM's Avatar
Anyone have a good place to buy Guilford of Maine fabric?
I have some GIK panels that need to be recovered in a new color.
thanks
AnthemAVM is offline
Old 02-04-2009, 11:56 PM
(Berk)'s Avatar
--Ethan
Thanks Ethan,
I'm more interested in the accoustic results than the resale value, but I'm not sure how anyone would notice that there isn't any sheetrock behind the bottom section if the fluffy fiberglass is covered with fabric wrapped rigid fibreglass panels. What do you think about using painted Tectum board for the bottom section instead of the rigid fibreglass? It would still be on top of the fluffy fibreglass.
Thanks for your input.
(Berk) is offline
Old 02-05-2009, 06:33 AM
Wireless member
pepar's Avatar
Liked: 518
thanks
The best price I had found when I built my treatments is here. Every online seller that I found was very "proud" of this product (read: it ain't cheap), but it works and has safety aspects that stuff from the local fabric shop lacks.
pepar is online now
Old 02-05-2009, 07:50 AM
nathan_h's Avatar
Quoted: 1067 Post(s)
Liked: 661
thanks
GIK sells GOM fabric separately from the panels for about $15 per yard which seems to be the standard price.
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
Old 02-05-2009, 08:31 AM
Wireless member
pepar's Avatar
Liked: 518
I'm pretty sure that I paid substantially less at the place I linked, but that was some years ago. The poster should compare prices for himself.
pepar is online now
Fv15hp Subwoofer , Denon , Audyssey
