Acoustical Treatments Master Thread - Page 351 - AVS Forum
 38Likes
post #10501 of 10507 Old 10-26-2014, 06:01 AM
cgott42's Avatar
Quoted: 64 Post(s)
How is rigid foam - like this?
I have some extra 2" boards (thinking I can glue together to make 4") and want to treat my baseboard (where floor and wall intersect) behind the front speakers (also perhaps in a ceiling/wall intersection above the speakers)
ellisr63 likes this.
cgott42 is offline
post #10502 of 10507 Old 10-26-2014, 08:47 AM
ellisr63's Avatar
Quoted: 195 Post(s)
Liked: 250
Originally Posted by archiguy View Post
What's the best way to attach the Linacoustic to the back wall (painted drywall on 2x6's at 16" O.C.)...?
I believe that some people are using screws (long), and fender washers... I have also seen some screws and washers made specifically for it but I can't remember where.
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, MiniDSP 2x4s, (4) Klipsch HIPs, (2) Klipsch KP3002s, PS3, XBox 360, (3) Intel NUCs, Monoprice Redmere, Monster HTPS7000, 2 SUPER SPUD subs, Panasonic AE8000us SeymourAV 180 (195" diagonal) scope screen, Yamaha P7000s (for the subs), (2) Yamaha P2500s amps for the front (3) bass bins.
ellisr63 is offline
post #10503 of 10507 Old 10-27-2014, 07:15 AM
myfipie's Avatar
Quoted: 22 Post(s)
Liked: 43
That sort of foam has NO acoustic value at all to it. Basically it would be waste of funds. Look for rigid fiberglass or mineral wool. If using foam then you want open celled foam and honestly don't look for it to do wonders. Most of the "real" acoustic foam is to thin or small to be all that effective.
http://www.gikacoustics.com/comparin...44-bass-traps/
Glenn Kuras
GIK Acoustics
myfipie is offline
post #10504 of 10507 Old 10-27-2014, 08:21 AM
Jacob B's Avatar
Need OC703 rigid fiberglass in Europe?
If any Northern Europeans are interested in OC703, I have 5 boxes of 2" rigid fiberglass boards for sale in the classified section:
Jacob B is offline
post #10505 of 10507 Old 10-28-2014, 07:12 PM
Maklar's Avatar
Quoted: 21 Post(s)
Would using foam over insulation impact the effectiveness of the insulation? I want to do tufted acoustic panels and thought of using foam over the insulation to help keep the rigidity of the tufts.
Maklar is offline
post #10506 of 10507 Old Yesterday, 12:28 PM
thestoneman's Avatar
Quoted: 58 Post(s)
DIY Schroeder diffuser panels
I have access to a CNC router and I am planning DIY Schroeder panels. Does anyone have dimensions I can use so my material is deep enough and cuts are affective?
Also, any thoughts on the effectiveness using expanded PVC (Sintra) with a painted finish?
My Theater Build
Equipment List: Epson 6030, Panamorph U480, Oppo-103, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears & front wides, DefTech DI5.5R Atmos overheads, Grafik Eye 3106....more to come
thestoneman is offline
post #10507 of 10507 Old Yesterday, 08:29 PM
BasementBob's Avatar
Quoted: 31 Post(s)
Liked: 76
knowing there were online calculators for this out there, I googled.
This is the first one I found
http://www.subwoofer-builder.com/qrdude.htm
(There are skyline numbers elsewhere)
An amateur built the Ark. Titanic was built by professionals. Of course Noah took a little advice.
BasementBob is online now
Fv15hp Subwoofer , Denon , Audyssey
User Tag List
