Acoustical Treatments Master Thread - Page 368 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #11011 of 11021 Old 08-30-2015, 05:58 PM
WereWolf84's Avatar
Quoted: 105 Post(s)
Liked: 44
What are the room dimensions - a diagram is often easiest/best.
The living room is 14.5ft x 16.5ft x 8ft with windows, door and open area to kitchen
WereWolf84 is online now
post #11012 of 11021 Old 08-30-2015, 06:58 PM
HopefulFred's Avatar
Quoted: 371 Post(s)
Liked: 317
Okay, it doesn't look like those nulls are related to modal resonances. Instead, IMO, they look like single reflections from three separate nearby surfaces - spaced 60 inches away for the lowest frequency null, then 48 inches and 40 inches for each of the next two.
I'm still inclined to question whether or not they are actually audible.
If they are a nuisance, moving the listening position would be my first recommendation and absorption after that.
HopefulFred is online now
post #11013 of 11021 Old 08-31-2015, 05:32 AM
myfipie's Avatar
Quoted: 41 Post(s)
Liked: 58
The Q looks pretty narrow so I would tend to agree.
Glenn Kuras
GIK Acoustics
http://www.gikacoustics.com
myfipie is online now
post #11014 of 11021 Old 08-31-2015, 06:03 AM
WereWolf84's Avatar
Quoted: 105 Post(s)
Liked: 44
in other words, which means I can ignore these nulls? please correct me if I'm wrong
I feel lack of those chest thumping mid bass
post #11015 of 11021 Old 08-31-2015, 07:47 AM
Quoted: 371 Post(s)
Liked: 317
Right. If you can't hear them, ignore them.
I'm not very confident in saying this, but I think you're looking at the wrong band if you're chasing chest thumping. That tends to be a little higher. If you have the system headroom, try some eq in the 120-150Hz neighborhood.
post #11016 of 11021 Old 08-31-2015, 08:09 PM
FriscoDTM's Avatar
Quoted: 74 Post(s)
Liked: 32
I built several 703 panels and super chunk style bass traps, and I'm ready to finish them off and am wondering if I should cover them with something before applying the fabric. I see some commercial products that include a layer to reflect some of the high frequencies - which materials are recommended to mimic this type of effect? Would something simple like a layer of brown craft paper or pink floor protection paper do it or do they use much more advanced materials to get the acoustic effects?
TV 2013 Samsung 75" UN75F6300
AVR 2013 Denon X2000 w/ Audyssey XT
7.2 DIY 1099s (LCR), Yamaha NS-IC600WH (SL, SR), DIY OS-MTM (BL, BR)
Subs Two 19Hz DIY Ported UXL-18s + FP14k + MiniDSP 2x4 Balanced
Calibration CALMAN5, REW, UMIK-1
FriscoDTM is offline
post #11017 of 11021 Old 09-01-2015, 05:19 AM
batlin27's Avatar
Quoted: 41 Post(s)
The dip at 100Hz doesn't show up with 1/3 octave smoothing, so I would forget it. There's a good chance it is related to a standing wave between the floor and ceiling and will be tough to treat anyway. The ringing below 45Hz is unclear, since we don't see it tail off in your plot. If you can extend the time in the diagram, you may find that this is just your room's noise floor.
Thank you!
Check out my theater build thread Theater on the Fairways Build
batlin27 is offline
post #11018 of 11021 Old 09-01-2015, 10:26 AM
pittsoccer33's Avatar
Quoted: 415 Post(s)
Liked: 321
Given how massive this thread has become, can anyone point me to a quick start guide to properly assessing acoustic treatment needs? I could start sticking that Corning stuff or foam all over my basement, but I really don't know what would actually help me.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #11019 of 11021 Old 09-01-2015, 02:19 PM
WereWolf84's Avatar
Quoted: 105 Post(s)
Liked: 44
start with REW measurement for your room
post #11020 of 11021 Unread Today, 05:52 AM
myfipie's Avatar
Quoted: 41 Post(s)
Liked: 58
Yes using something like craft paper will work. Keep in mind though you do not want panels with a membrane (the craft paper) in the any of the early reflection points.
http://www.gikacoustics.com/video-ea...ection-points/
Glenn Kuras
GIK Acoustics
post #11021 of 11021 Unread Today, 05:55 AM
myfipie's Avatar
Quoted: 41 Post(s)
Liked: 58
All small rooms need lot of bass trapping in corners, so that is a given. Testing is great way to see the progress but also great for making sure you have the speakers set up right also. Here is a video on using REW.
http://www.gikacoustics.com/room-eq-wizard-tutorial/
Glenn Kuras
GIK Acoustics
Fv15hp Subwoofer , Denon , Audyssey
