Acoustical Treatments Master Thread - Page 375 - AVS Forum | Home Theater Discussions And Reviews
 161Likes
post #11221 of 11227 Unread 01-31-2016, 04:11 PM
bgtighe23's Avatar
Quoted: 871 Post(s)
Liked: 378
Originally Posted by myfipie View Post
I have had customers cut the wire too two short pieces, attach to the eyehook, make a loop on the other end then hang that on a hook on the wall. I may give this some thought and come up with other options for customers though. The french cleat is great but it still will not be flush to the wall.
But they stay put during LFE/ULF scenes of HT and music. Mine constantly shift to one side, then, due to physics, continue falling to one side. The far left panel fell against the ATS panel, so they didn't completely fall over.
ATS uses 4 total french cleats, but they are about half the size of the ones y'all stock up on (assuming they are the same as the ones I requested after having these issues). They also include a template and hardware for mounting. They are a millimeter or two from the wall at the most. They don't use slanted french cleats.
One of my wires broke today. About a quarter way from the left eye-hook if you're facing the back of the panel. Still can't figure out how - they're mounted using smooth nails
Name:	Screen Shot 2016-01-31 at 5.08.17 PM.png
ID:	1222778   Click image for larger version
Name:	Screen Shot 2016-01-31 at 5.08.48 PM.png
ID:	1222786   Click image for larger version
Name:	Screen Shot 2016-01-31 at 5.08.33 PM.png
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
HTD Level 3 Review
Receiver : Denon x4100
Speakers : Martin Logan Motion 40s/Motion 15 (center)/HTD Level 2 (surrounds)
Subwoofer : Dual UM-18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
post #11222 of 11227 Unread 01-31-2016, 09:17 PM
HiFiGuy1's Avatar
Quoted: 36 Post(s)
Liked: 25
Originally Posted by erwinfrombelgium View Post
1" is never enough. Hence the 2", it wil deal with one lower octave. 4" is better!
Interestingly, Dennis Erskine said (13 years ago in this thread) to cover the front wall with 1" InsulShield, and that 1" InsulShield is preferable over 2" treatment. Said the 2" is too absorptive. I am paraphrasing.
You have to hand it to Venus de Milo..., otherwise she would starve.
Computers have abundant memory, but no imagination.
HiFiGuy1 is offline
post #11223 of 11227 Unread 02-01-2016, 12:09 PM
bass addict's Avatar
Quoted: 353 Post(s)
Liked: 425
It's interesting how things have changed over the years. When building my first theater the advice was; 1" linacoustic on the front and sidewalls up to just above ear level, and poly batting on the rest of the walls above that.
Fast forward to today and most will recommend a minimum of 2" on the front wall and 4" plus on the rear wall, with 2" on the sidewalls from floor to ceiling with some diffusion and reflection points mixed in.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #11224 of 11227 Unread 02-02-2016, 10:15 AM
myfipie's Avatar
Quoted: 56 Post(s)
Liked: 66
If you would like please feel free to send me a email and I can send out some french cleats. Not a problem at all.
Glenn Kuras
GIK Acoustics
http://www.gikacoustics.com
myfipie is offline
post #11225 of 11227 Unread 02-02-2016, 02:22 PM
bgtighe23's Avatar
Quoted: 871 Post(s)
Liked: 378
I explained in the post you quoted me on that I had already requested some after having these issues. They have been delivered, will be installed this weekend.
HTD Level 3 Review
post #11226 of 11227 Unread 02-03-2016, 09:36 AM
Quoted: 21 Post(s)
Liked: 2
I haven't gotten any feedback in my build thread, so I figure I'll ask here as well. I am currently working on my first theater. Rather than being a dedicated room, it is more of a nook off a living room. Obviously not ideal at all for sound, but sometimes you just need to make the best of what you have.
The room is 12' from the rear wall to the screen, and 10'11" wide, and has about a 6'6" opening along one of the walls. Now I realize I won't ever be getting an amazing sounding theater, but I am hoping I can improve the audio quality somewhat with the use of some strategically placed acoustic treatments. I would like to have all the walls lined with fabric panels, but am guessing that the optimal layout may have sound absorbing material behind some of the panels, but not others. I have my list of questions in my build thread, here. Further up in the thread, there is a more detailed drawing of the room layout with dimensions, etc. Any feedback would be greatly appreciated (feel free to answer here, or in my build thread).
MarkLT1 is offline
post #11227 of 11227 Unread Today, 11:09 AM
DonnyKerabatsos's Avatar
Quoted: 66 Post(s)
So, after discussions with the WAF counsel and looking at locations of can lights and smoke detectors, it looks like the only things I could swing in the room would be (diffuser) panels on the back wall between the doors and maybe bass traps higher in the rear corners. Will doing only that be worthwhile/make a noticeable difference?
Originally Posted by DonnyKerabatsos View Post
Hey all, seeking advice as to whether I could get any improvement in the sound by treating my room. It sounds good to me, much better than my old den, which was open to a dining room, a stairwell, etc.
Running a Denon 1913 AVR with a pair of NHT absolute towers, TwoC Center, and Absolute Wall surrounds. Sub is a Definitive Technology Prosub 1000 for now, but I intend to upgrade soon, likely to a Rhythmic LV12R. I did the sub crawl in the locations where the sub made sense aesthetically and for running the cable. Audyssey has been run.
As you can see, I'm somewhat hamstrung as to where I can put panels due to lay out (windows) and decor, but I wasn't sure if corner bass traps, ceiling panels or rear wall panels might be of any appreciable benefit. Dimensions are 15'10" W x 17' L, with ceilings that slope up from 9' to 11' (from the front of the room, where the towers/TV are, to the back).
Any suggestions appreciated.
Like to imgur album: https://imgur.com/a/1lP2J
DonnyKerabatsos is online now
Fv15hp Subwoofer , Denon , Audyssey
