Acoustical Treatments Master Thread - Page 383 - AVS Forum | Home Theater Discussions And Reviews
 178Likes
post #11461 of 11473 Unread 09-18-2016, 02:49 AM
erwinfrombelgium's Avatar
Quoted: 330 Post(s)
Liked: 155
Interesting stuff, new to me. It's says that "The black surface provides a visual barrier with an aesthetic appearance, in both wall and ceiling applications." Hence you do not wrap it, as long as you apply these without the sides in sight (so wall-to-wall). Looks cool, but maybe not for formal living spaces. The heaviest and thickest quality is best of course.
Slowly building a 9.2.6 HT: ◤SEOS-24◥ BMS 4594ND/dual Beyma 18P80Nd [tri-amped LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX [6 Atmos] • LLT Mal-x 18" subs [2] • miniDSP 4x10HD [2] • XPR-5 • MM8003 [2] • XMC-1 • PT AT6000E • 130" Seymour Center XD • Oppo 103EU
My build
erwinfrombelgium is offline
post #11462 of 11473 Unread 09-19-2016, 01:59 AM
Quoted: 27 Post(s)
Liked: 2
Question Riser Bass trap
Please share thoughts/ Theory or experience on Riser bAss trap build.
Will be building a riser soon and would like to make it more functional for any bass trap use
nandkisham is offline
post #11463 of 11473 Unread 09-19-2016, 03:22 PM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
I did some research on this and in the end, decided it wasn't worth the trouble and expense, as always, YMMV
nandkisham likes this.
healthnut is online now
post #11464 of 11473 Unread 09-20-2016, 11:17 AM
pingas6's Avatar
Hello everyone.
Excuse me .
I would like to use anthem (arc) by measurements of acoustic treatment put in my room, is it possible? or I have to use another way?
Thank you very much.
Regards
pingas6 is offline
post #11465 of 11473 Unread 09-21-2016, 12:37 PM
grendelrt's Avatar
Quoted: 109 Post(s)
Liked: 53
Figured I would ask here first before making a new thread. If I am building a backer box for a ceiling speaker, I know the correct cubic feet volume, does it matter how close the back of the speaker is to the box as long as the volume is correct? For instance I only have 6.25 inches of room and the speaker is 5" deep, so it is only 1.25" of room behind the speaker but plenty of room on the sides.
grendelrt is online now
post #11466 of 11473 Unread 09-21-2016, 04:26 PM
climber07's Avatar
Quoted: 321 Post(s)
Liked: 1328
So long as the driver doesn't touch you're good to go.
grendelrt likes this.
climber07 is offline
post #11467 of 11473 Unread 09-21-2016, 05:06 PM
grendelrt's Avatar
Quoted: 109 Post(s)
Liked: 53
Awesome thanks!
post #11468 of 11473 Unread 09-22-2016, 03:08 PM
ddigler's Avatar
Quoted: 394 Post(s)
Liked: 133
Can someone with experience tell me what the average HT treatment panel thickness is? 2"?
I don't have a budget to support a professional design for treatments in my new HT. just curious, can I get away with 1-2" thick panels?
ddigler is offline
post #11469 of 11473 Unread 09-22-2016, 07:28 PM
Liked: 1
I NEED HELP ....
I have a separate wood outbuilding ...now insulated and it has a partially vaulted ceiling in the theater area and an open area opposite a solid wall.
I'm sure I should have some sound absorption on the wall and not sure about the slanted ceiling on the one side.
ID:	1677825   Click image for larger version
BeerandBread is offline
post #11470 of 11473 Unread 09-22-2016, 07:54 PM
Liked: 1
pic update for last post indicates a wall height of 8 ft and a rise in ceiling of 4" in 12 " for 6 ft then a flat ceiling of 8 ft panel...at 9ft 6 inch high.
I don't have a wall for a reflection point on the one side.
post #11471 of 11473 Unread 09-23-2016, 08:17 AM
climber07's Avatar
Quoted: 321 Post(s)
Liked: 1328
It depends entirely on the materials used. OC 703/705, Roxul Rockboard 60/80. It also depends on the frequencies you are looking to eliminate at reflection points. Most use 2" panels and are happy.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
post #11472 of 11473 Unread Today, 10:29 AM
Horta's Avatar
Quoted: 26 Post(s)
Liked: 26
Hello friends
Quick question. My theater is getting built now. I will be using Quest Track to cover the acoustic panels with fabric myself. My question is, does anyone have the tools needed to do this job. The kit new is over $225 and a person only uses it once.
So do any of you all have it, that would like to sell it for a decent discount? Or have an affordable alternative? I know sounds silly we spend thousand for a room but then get cheep on a silly thing like a tool, but this project is already beyond expensive....
Jerry
Horta is offline
post #11473 of 11473 Unread Today, 11:25 AM
BllDo's Avatar
Quoted: 552 Post(s)
Liked: 338
Originally Posted by Horta View Post
Hello friends
Jerry
Not entirely sure what is in the Quest package, but you may be able to rent what you need here:
http://fabricmate.com/product/profes...rnable-version
Is it solipsistic in here, or is it just me?
BllDo is offline
Fv15hp Subwoofer , Denon , Audyssey
