Acoustical Treatments Master Thread - Page 392 - AVS Forum | Home Theater Discussions And Reviews
 241Likes
post #11731 of 11737 Old 02-14-2017, 01:11 PM
drunkpenguin's Avatar
Quoted: 1149 Post(s)
Liked: 1094
Originally Posted by 12B4A View Post
One thing you could try is modifying your absorption panels with BAD-style diffusers as exampled here: DIY Sound Diffusers
1/8" hardboard is ~$6 per 8'x4' sheet. Cutting the right holes in in might be a chore unless you know someone with a CNC machine for wood.
THats a thought! I like the design. I'll have to read up on those "bad" boys.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #11732 of 11737 Old 02-14-2017, 03:02 PM
ereed's Avatar
Quoted: 771 Post(s)
Liked: 350
Or you could do something like GIK alpha panels which are absorption panels with wood slats in front of it that does the diffusion part. Make regular panels and get some 1/8 inch wood with vertical slats and glue to front of panel. But I recommend talking to GIK to see what they say about their advice on what you should do. Its free service and you don't have to actually purchase anything.
Main theater: Sony 45es, 120 inch ST screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13-Ultra x 2
Loft theater: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is online now
post #11733 of 11737 Old 02-18-2017, 05:12 PM
thecloneranger's Avatar
Quoted: 74 Post(s)
Liked: 57
hi i have a small game/ theatre room i would like to treat since ive been reading on the importance of properly treated room. and since i have quite a bit of money invested i wanna do this before upgrading anymore. any way ill include a pic of my room and maybe i can get some suggestions are where to start. i have a umik coming in this week so i can started on rew. but just wanna get some ideas from you guys. for example i want to treat the ceilng and the walls were speakers are at maybe some bass traps for the corners. any help would be appreciated thanks.
Epson 5030ub,Onkyo 818,Samsung bd player,Xbox One,Ibuypower gaming pc
Ascend Acoustics sierra 2s l/r,Ascend Acoustics horizon center w/raal upgrade
Ascend Acoustics cbm 170 x4 surround duty,PSA dual s3000i
thecloneranger is online now
post #11734 of 11737 Old Yesterday, 10:14 AM
ereed's Avatar
Quoted: 771 Post(s)
Liked: 350
With those 3 subs you will have alot of bass buildup in the corners so start with corner bass traps first. Floor to ceiling is optimal and do all corners if you can. This will absorb low frequencies that is bouncing around in the corners and then bounce back around in the room, the traps will absorb it so resulting in tighter, cleaner bass with improved decay. I see your wall art....are they acoustic panels? If not, you can get acoustic panels with same art work you have if you want to keep same theme in the room.
ereed is online now
post #11735 of 11737 Old Yesterday, 01:59 PM
Quoted: 74 Post(s)
Liked: 57
alright thanks for the advice. i will definetly start there
post #11736 of 11737 Old Yesterday, 03:44 PM
jhermsmeyer's Avatar
Quoted: 68 Post(s)
Liked: 42
Treatments & Calibration Sanity Check Request
I was hoping someone could take a quick look at the following post, and let me know if I am doing anything silly.
The post contains pics of my treatments and a bunch of measurements.
Interior Room Dimensions:
Length: 21’ 9”
Width: 15’ 3”
Height: 8’ 10”
post link
thanks!
jhermsmeyer is offline
post #11737 of 11737 Unread Today, 04:27 PM
Quoted: 74 Post(s)
Liked: 57
the art work is canvas shouldnt that be good acoustics or would it be better to have real acoustic panels?
Fv15hp Subwoofer , Denon , Audyssey
